Marks on Ceiling
Marks on Ceiling
My sunroof was barely tilted and i didnt know. It rained and now the the sliding cover for the sunroof has a round circle of the outline of the puddle of water it held from getting in the car. Its just the outline of the puddle, not a filled in circle. On top of that, i have some other random marks on the parchment ceiling. What is the best way to get rid of marks in the ceiling?
The Old Grey Whistle Test
Water stains
If there is a stain because the water has dried in the middle of a piece of fabric and it has a clear point of demarcation to the rest of the fabric; reduce that point of demarcation by wetting the entire area out to a seam or edge.
Take a bowl of room temp water and a clean sponge, soak the sponge, wring it as dry as possible and starting at the spot dampen the fabric and move the sponge to the edges, allowing the moisture to become less and less as you get further from the spot.
Do not scrub, just gently wipe.
Do not soak the fabric just get it damp enough at the stain to release the stain and wet the rest of the fabric so that the entire area can dry uniformly across the area rather than in that one spot.
rockyboy
12-06-2022 02:29 PM
