Long day after detailing - no 56ker
Kang Ho
This is the first time I use the UDM. Patrick, thanks for overnight pads. I'll get this out of the way first. I am somewhat satisfied, but not overly excited. I guess I didnt use the right combination of pads/polish. I can still see swirls directly under the sun. The car is so bright that I cant look at it too long. Here's the product I use:
Meguiar Gold Wash
Duragloss Aquawax on wheels
3M painter tape on certain area
Optimum Compound/Orange Pad (speed 3, then 5)
Optimum Polish/White Pad (speed 3, then 5)
Danase Wet Glaze/White Pad (speed 1)
Four Star UPP by hand w/ microfiber
Black Wow (question on this later)
Stoner Invisible Glass
Total time: 8 hrs
I dont know how to use Black Wow. After applying it, I thought it was suppose to dry? When I put my finger on it, it feel greasy. I didnt wait for the DWG to cure, I just apply UPP right after that. I will apply another layer of UPP tomorrow and then 2 more layers of Meguiar NXT 2.0. I figure NXT 2.0 is less expensive and I want to see how it will turn out. Good idea or bad? I need some feedback on the polishing product/pads. I want to get rid of these swirls. Here are the pictures:
Before
Before polishing:
After:
Here's a picture out in the sun today:
Meguiar Gold Wash
Total time: 8 hrs
Before
Before polishing:
After:
Wow!! Really nice.......... you sure let you car go a bit before this detail. Great job though. I'll let the experts comment on the pads/products and what you need to do get rid of the swirls. You car looks great
Kang Ho
dont waist your time putting two more coats of nxt on top of the upp...you have upp and dwg, i would put another coat of one or both of thoes, but you can now ditch the nxt since you have thoes two products...
speed 3 with your udm and your orange pad and compound isnt very effective....you need speed, and you probably could have used a yellow pad on that paint or atleast another full pass with the orange/compound....
still, i bet your results were pretty good....
1 Post
Over all looks like your car turned out very nicely. The white pearl is a beautiful color and very reflective so you should be hard pressed to see any of the remaining swirls. Nice job.
Kang Ho
Kang Ho
Originally Posted by conan777
I think he meant that he spreads his polish on speed 3 and then polishes on 5. I would recommend that you polish on speed 6 and if you are still seeing scratches then you prob just want to add a couple more drops of compound and hit the area again and repeat until the scratches are gone. Note I said "Scratches" not marring. The compound will usually leave marring on the paint and you can tell because they go in a circular pattern obviously caused by the buffers circular/orbital motion. these should be taken care of with the Optimum polish although I'm not a huge fan of OP. You may have been good simply by doing another pass or two of the OP on the white pad. Most of the mistakes people make is using way too much polish and not working the polish long enough to break it down. A good rule of thumb is you can't really work OP too long. Better too long than not long enough. When its pretty easy to wipe off the residue then you know you worked your polish long enough and it has broken down.
forget youtube videos
go to UDMs homepage and they have their Pro using the UDM in a couple of scenarios- shows how much product, how to apply products to the pads, and the best patterns to use for polishing.
Getting the feel of of the motion and letting the tool do the work -- it takes a few times doing the car- you get more aggressive as you get skills, and scratches go away faster.
I used the Hyper compound on low speed and was impressed- did the whole car with 3 levels of products on 1-2 speed, thinking- better safe than sorry
Car looked awesome- or so I thought
A month later decided to try some other products to work on the micro stuff and made huge differance in the results. Like a different color car with all the contaminents removed
Now to do the final super micro scratch stuff and then seal it up good.
Ready to face another 3-6 months of torture in the outside world
Kang Ho
mada51589
05-03-2022 08:54 PM
darksky
09-05-2015 03:11 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
