Initial Clean/Wax/Protect - How soon?
Okay, I just picked up my TL-S on 6/18. It has a mfg date on 06/07 and arrived at the dealership on June 11. What is the 'curing' period? Should I wait 30-45 days before I apply anything to the paint? What about washing it before then? 3M IHG?
Advice greatly appreciated.
Thanks guys. I've never been sure if the 'cure' thing was bs.
What is IFO?
I've been partial in the past to 3M Finesse it and IHG. Not sure that I need Finesse It on a new finish yet, but will try a sealant before a wax. I'll probably try Klasse or 4 star.
Right track?
What is IFO?
Right track?
Paint needs to cure, its not BS. Having said that new car paint is cured in an oven at 300 degrees (this is before any trim, mouldings, etc are fitted)
Re-painted cars usually require a cure period of 10-30 + days dependant upon paint / catalyst used.
Klasse is a great acrylic polymer (was my go-to for 20+ years, now replaced wih Zaino)
IFO? Industrial fall out - emissions from power generation, manufacturing plants and combustion engines emit Sulphuric acid from their exhaust stacks etc, vehicular catalytic converters emit carbon compounds that mixed with ozone (an oxidizer) and water becomes Sulphuric acid. Nitric oxide is an additional IFO component especially around Paper Mills
Originally Posted by nsxiballer
is it okay to hand wash a brand new car 2 weeks after purchasing it?
Your dealer did on delivery didn't they?
I did the whole detail thing (except mechanical polish) on my TL-S as soon as we got a cool day. About 10 days or so after purchase.
The Clay Bar was easier than I expected. If you've never done it (I had not), the instructions/DIY here are great and it is very easy to do - not a "sticky mess" like some might be thinking.
I might have been lucky, but I got very little residual contamination off with the clay - just a very little, light brown residue. Either the dealer did a good clean up or the car was pretty well protected during transport.
My initial clean revealed little 'IFO' - at least that I could tell. Biggest thing was the wax(?) left from the protective plastic it had been wrapped in - couldn't see it visibly, but cold tell where it was from the cleaner/clay application. Came off fairly easily though.
As far as washing, you should have done it as soon as it hit your driveway for the first time.
saturno_v
Oct 28, 2015 06:57 PM
HOWELLiNC
Sep 18, 2015 11:12 PM
