Ideas for removing ink (pen marks) from parchment dashboard?
Old Jan 9, 2012 | 11:24 AM
acurapex's Avatar
3rd Gear
My manager from work periodically rides with me and has inadvertently marked up my parchment dashboard with ink pen. Any ideas on how to remove it without damaging the dash? I tried lexol and goof off--It got a bit lighter but is still very noticeable. Any help is appreciated.
Old Jan 9, 2012 | 11:42 AM
Bearcat94's Avatar
AZ Community Team
Moved to "Wash & Wax". Hopefully the cognoscenti here can help.
Old Jan 9, 2012 | 11:54 AM
potmilkz's Avatar
mr clean magic eraser!
Old Jan 9, 2012 | 01:59 PM
acurapex's Avatar
3rd Gear
Has this worked for you? I've used the Mr. Clean Magic Eraser successfully for lots of things but don't want to blaze any trails because I don't want to damage the dash and devalue the car.
Old Jan 9, 2012 | 03:11 PM
potmilkz's Avatar
use some type of interior detailer with mr-clean
reason why i say this is because you need some type of liquid on the surface area so that the eraser doesnt burn through the leather.
you can use dishwashing soap, just alittle, put it on the area, and work it with the eraser.. it should take it off.
Old Jan 10, 2012 | 07:18 AM
acurapex's Avatar
3rd Gear
Thanks for the help. I'll give this a try.
Old Jan 11, 2012 | 05:38 AM
TOGWT's Avatar
The Old Grey Whistle Test
Avoid using abrasive products as you'll remove the protective coating. Instead use Iz einszett 'Plastik-Reiniger' an intensive, non-corrosive, non-acidic two-phase deep cleaner for urethane covered upholstery and vinyl trim, that removes grime build-up thoroughly and effortlessly, these chemicals restore the original texture, tactile feel and resiliency; use to clean all coloured and clear water-based acrylic polyurethane covered automotive upholstery and vinyl; this product is biodegradable, silicone and formalin-free as well as being environmentally friendly.
Sep 17, 2015 10:16 AM
Shank009
Sep 17, 2015 12:53 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
