How often do you guys polish/wax
So I've been reading that polishing too much takes off the clearcoat. I have a pc 7424xp and i was going to detail my TL, but I wanted to know how often do you guys put new polish and wax. Thanks
Where did you do this reading?
Evil Mazda Driver
My Santa Fe has only been washed with microfiber mitts, drying towels and using the two-bucket method since I bought it new in September. However, some slight wash-induced marring is cropping up on some surfaces so come springtime, I'm going to run over it with the random orbital, a black pad, and some Menzerna Super Finish.
I think your going to run into that with any winter washing , have you ever tried good quality sheepskin mitts?
Keep'n it clean- Orlando
polish= abrasive, hence only perform when needed to conserve clear coat.
wax= protection, you can never get enough of this on the car.
I wash often, after each or sometimes every other wash I use a quick wax while the car is wet then dry it, and every other weekend I apply my favorite sealant or wax-depending if you like the synthetics or carnubas. I really like my carnubas.
However too much wax build up can leave the car hazy or not so deep looking, at that point just use a non or limited abrasive "cleaner wax" to strip the old wax, brighten the paint, then re wax or seal your car.
Enjoy and dont over think it.
wow, I must have A.D.D, or I am a perfectionist because I wash my car every 3rd day once I see a dust build up, however I apply wax often to keep up with the washing.
I would wash my car every other week and will apply spray wax if needed. Make sure when washing a car use two buckets with grit guard and a nice MF mitt.
1. I would first start on wheels/wells first then move onto washing the car from top to bottom.
2. Then I would inspect the paint to see if it needs claying. I usually like to clay every 3-6 months.
3. I would prob polish the car every 6 months with DA using M205 with LC white flats 5.5 inch.
4. I would apply sealant top it off with wax.
5. Clean all door jams.
6. Vacuum inside.
7. Clean up the interior.
8. Windows.
9. Dress tires.
10. Maintain it by washing it weekly and putting on spray wax when needed.
6. Vacuum inside.
8. Windows.
9. Dress tires.
Last thing I'd recommend tho .. your interpritation of dust and the noobs interpritation can be far apart. I have seen a lot of people mar the heck out the paint QD'ing too heavy a dust.
lmfao....
I agree, if a easy stream of water does not leave the paint dust free, then i will not rub it ... I will wash it.
As long as the light dusting comes completely off and there is no dirt/grime stuck on the paint I feel ok using a really plush MF and some good QD.
ok thanks guys. so if i go over it once with menzerna power finish to cover up the swirls and mild scratches it shouldnt be a problem from what i understand
when i buy a new car, i usually do a full polish/correction within the first few months...then i usually do a aio polish with a white pad once or twice a year followed by a sealant atleast twice a year...
if you use nothing more abrasive then a mild polish or an aio polish, and nothing more then a white pad with a udm or pc, i dont think you could remove enough clearcoat to damage it before you burnt out your machine....
Needs more Lemon Pledge
I can;t imagine you getting through the clearcoat with a PC on your first (or tenth!) polish. Your arms would fall off from fatigue first...
Evil Mazda Driver
OculiAquilae
11-19-2018 02:24 PM
