Hologram effect after using the PC
Old 01-06-2008, 11:08 AM
05 DGP/Parch
ARedMoon's Avatar
I tried my new PC for the first time a couple of weeks back and recently noticed the "hologram" effect left by the polisher. Although I didn't notice it at the time the work was done, it was pretty obvious when you looked at the hood under the sun light.
I prepped the 05 DGP surface with a wash and clay bar and then applied Mothers Cleaner/Carnuba with the PC set at 2. I used a red W-7008 Mequairs pad.
Did I miss a step or use the wrong pad/wax?
What is the correct speed setting for the PC?
Should I have followed up with a second coat of something on a finer pad?
Where did I go wrong?
I am hoping that the condition can be corrected and any help or advice would be greatly appreciated.
Old 01-06-2008, 12:00 PM
Hawhyen51's Avatar
If I remember right, the Megs Red is a cutting pad, yellow is a light cut and beige is the finishing pad. You'll probably need to use a light polishing pad with a mild polish to clean it up. Speedwise, 2-3 for waxes/sealants, 3-4 for cleaners, 5-6 for polishes.
Old 01-06-2008, 02:07 PM
Former Sponsor
exceldetail's Avatar
Oh boy, I will say ya missed a step for sure! That Megs burgundy pad is indeed a cutting pad, and one of the more aggressive pads available. That cleaner wax is nothing more then that, just a paint cleaner with minimal Nuba protection.
In order for you to remove that hazing/marring, your going to need an actual polish now, and a polishing pad. I would recommend two steps as theres no telling how much swirl was introduced at this point. I would opt for Optimum Compound, with an Orange Erasure, then follow up with Optimum Polish, with either the Orange or White Erasure. The Optimum polishes and pads are available at my site in 4oz, 8oz or 32 oz sizes.
Toss the Megs #6, and put some true protection on there like Surf City Nano Seal or Four Star UPP, or 1Z Glanz wax......OR
Use a Yellow Megs pad for that cleaner/wax, then expect about 4-5 weeks protection, or about 3 washes worth......
Old 01-06-2008, 11:59 PM
2016 E350 Sport
SweetJazz's Avatar
Meguiars definitely does not recommend use of the burgundy pad with a PC. It is way too aggressive. I am not familiar with the Mothers Cleaner/Wax but the protection it provides will be minimal. Cleaner/Wax products will usually require a real protection coat as stated by Exceldetail and Hawhyen51. I have had good results using a Cleaner/Wax and a lake country orange light cut pad on speed 5. I then top it with 1-2 coats of a sealant or wax.
Old 01-07-2008, 07:16 AM
05 DGP/Parch
ARedMoon's Avatar
Folks:
Thank you all for your comments and recommendations.
Hopefully, there isn't too much damage done.
Old 01-08-2008, 02:13 AM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
Ooops!
Another option is since you're in SoCal, maybe you can take your car to excel for a correction.
Just a thought.
Old 01-08-2008, 02:46 AM
mdkxtreme's Avatar
sorry if i go off topic a little, but where is patrick located specifically in SoCal? does he have service in detailing? cause i really DO NOT trust any detailers in my area. i had my car clay bar once and they left some clay in the corners and they are now permanent.
Old 01-08-2008, 03:37 AM
_
AZuser's Avatar
Here's some info or just PM Pat.
He's in the Thousand Oaks/Ventura area usually... it seems.
Old 01-08-2008, 07:13 AM
Former Sponsor
Hollywood Saturday............
Old 01-08-2008, 08:50 AM
Jesstzn's Avatar
Thats odd cuz Mike Phillips actually sent me a burgubdy pad along with other stuff to use on my PC.
D.
02-25-2020 09:57 AM
thegipper
09-28-2015 01:01 PM
rockyboy
09-24-2015 09:48 AM
09-21-2015 08:44 AM
Quick Reply: Hologram effect after using the PC
