Help with Clear Bra & rubber marks
Old Sep 10, 2007 | 11:34 PM
PsychFish's Avatar
Question Help with Clear Bra & rubber marks
I have a clear bra on my silver 07 TLS since I mainly drive highways in Texas. I have had some bad luck lately and twice now I have hit truck retreads within 4000 miles and only owning the car 2 months. The body panels, urethane and paint are not affected but I cannot seem to get the black rubber marks off my clear bra. They came off clean from the paint with a little TLC. It a Clearshield or Baerkat brand of clear bra if that matters.
Any ideas on how to get rid of the rubber blackness on a clear bra?
Old Sep 10, 2007 | 11:57 PM
exceldetail's Avatar
Former Sponsor
All clear bras are made of relatvely the same materials. Try some WD 40 or paint cleaner, shouldnt be a problem at all.........
Old Sep 11, 2007 | 07:17 AM
Macruz19's Avatar
If that doesn't work, you might need to use a PC and a minor polish. I usually can get stains off with a little elbow grease by hand with scratch-x or an all in one product.
If all fails, and if it's bothering you..then just replace that peice.
Old Sep 12, 2007 | 07:17 PM
Hawhyen51's Avatar
I've used fine grade clay on my PPF on some areas without any problems but I would be a bit apprehensive using a PC on PPF nor would I use an abrasive polish. I would try the WD40 as Patrick mentioned. IMO a plastic polish like Plexus or Meguiars Plastx would be the safer and probably the wiser choice. Since these products are also protectants, you wouldn't need to follow with a wax/sealant. 303 is another product that can be used on PPF. If you have any doubts, I would contact your installer and ask for his recommendations.
Old Sep 24, 2007 | 07:55 PM
ReD-BaRoN's Avatar
Hawhyen51, I have a question on this: You treat your PPF totally different than the paint? I.e. no wax/sealant on the PPF, and using only Plexus (or something similar)? Seems like a complicated process, that may leave the two differnet materials looking different (i.e. gloss, etc).
Old Sep 24, 2007 | 08:17 PM
Hawhyen51's Avatar
Not really a complicated process, just another step using a different product. After all, PPF is applied on top of the finish and is somewhat of a plastic product so why not use a plastic cleaner/protectant for it. Besides, I alternate every other month with UPPS and use AW after washes. I have not noticed any discernable differences between both surfaces.
hashbrown
Feb 18, 2022 11:20 AM
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
