Headlights severely rock chipped....help
Old Jan 26, 2010 | 01:14 PM
pimpin-tl's Avatar
Well I went on a 1000 mile cruise and I had a nose mask so the rest of my car was safe. But my headlights look like they got sand blasted. What can I do to fix this? I can wet sand them, but doesn't that remove the clear coat off the lights and will cause them to turn yellow fast? Anyone that can help me in the steps on how to fix them would be great. I have access to many detailing supplies like Meguires 105, Portable cable all of Lake pads, etc.
This is on my 07 TL-S.
Old Jan 27, 2010 | 11:09 AM
pimpin-tl's Avatar
Bump.....
Old Jan 27, 2010 | 11:57 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Is the plastic actually chipped?
Old Jan 27, 2010 | 02:26 PM
DetailedImage's Avatar
Former Sponsor
Your best bet IMO is to polish using the PC and M105, etc. to get them looking as good as possible. If a wet sand is needed, do that as well. Your only options to repair them are to replace the lens or sand them down / polish them. If you wet sand and polish, chances are you'll remove the UV protection, but if you stay on top of it with some 303 Aerospace Protectant or something similar to add UV protection you should be fine. If you notice any discoloration afterwards, just hit it with a light polish. You're going to run into the same problem if you replace the lens and it begins to chip as well, so you might as well care for it yourself since you already have just about everything you'd need.
My $.02
Old Jan 27, 2010 | 02:38 PM
pimpin-tl's Avatar
Yes.
Old Jan 27, 2010 | 04:50 PM
dahray02's Avatar
My $.02
which pad would u use for the PC & M105....and does this not remove the UV protection as well...or am i wrong? I always wondered what the best way to clean headlights was
Old Jan 27, 2010 | 08:13 PM
mdkxtreme's Avatar
You should invest in invisible protection for your headlights. My JDM headlights are expensive so day one I brought it in and had a guy put Ventureshield film over it. It was 50 bucks for everything.
Old Jan 27, 2010 | 11:16 PM
csmeance's Avatar
Originally Posted by pimpin-tl
Yes.
your best bet is to polish and wetsand and then apply some 3M 8 mill clear-bra over the headlights to protect them
Old Jan 28, 2010 | 01:46 AM
PortlandRL's Avatar
Could we get some pics?
Old Jan 28, 2010 | 07:32 AM
pimpin-tl's Avatar
Yea I will once I get the car back from the dealer.
Old Jan 28, 2010 | 09:18 AM
Former Sponsor
I'd start with either an orange light cutting pad or if it's not too bad you could probably get away with a white polishing pad.
Any abrasive approach is going to wear down the UV protection, so once you begin to correct your headlights, you'll want to follow up with a protectant with UV protection.
If your headlights are in good shape and don't require polishing, I like to treat them with a nice all in one product, something like Klasse AIO, for the chemical polish and layer of protection it leaves behind.
Old Jan 29, 2010 | 01:33 PM
VoLLy's Avatar
Meridian
x2 this is the best way.
Old Jan 29, 2010 | 11:53 PM
SweetJazz's Avatar
2016 E350 Sport
Paint protection film is your friend. Worth every penny for protecting the front of my car.
Old Jan 30, 2010 | 12:28 PM
pimpin-tl's Avatar
^^ Not worth the money. Had 3 cars with it, and I refuse to put it on this one as it looks as bad on the front of the car after a few years and costs as much to just get the car re-sprayed on the front as having one installed.
Old Feb 7, 2010 | 03:42 PM
pimpin-tl's Avatar
Old Feb 7, 2010 | 05:21 PM
SweetJazz's Avatar
2016 E350 Sport
^^ This pic proves my point. I went the same rout with my Civic and regretted it until I put on another clear bra. Sandblasted headlight lenses and rock chipped paint is a no go for me. My TL-S clear bra is beat up but it still looks much better than sandblasted paint. The extremely soft paint on these new Acuras makes paint protection a must. It has been almost 3 years since I installed the clear bra which means I still have perfect paint underneath and it only cost me $16/month.
Old Feb 7, 2010 | 05:22 PM
pimpin-tl's Avatar
Well, my paint is fine as I install a Leather one when I take trips. The headlights took a beaten though.
Old Feb 7, 2010 | 05:57 PM
SweetJazz's Avatar
2016 E350 Sport
Yeah, I used an old school nose mask for more than 12 years on my Civic. I just could not stand the look and hassle of putting it on and taking it off anymore. Just polish out your headlight lenses and have some paint protection film installed on the lenses. Then use the nose mask to protect the rest of the front. Unfortunately, I'm one of those OCD types that wants his cars looking show car ready all the time.
Old Feb 7, 2010 | 06:58 PM
pimpin-tl's Avatar
Yep, so am I. But after having 3-4 cars with the Clear Bra on it, have come to a conclusion that it isn't worth it. It gets nicked up as well and will look as bad as your paint too after a while, then you can remove it, and it will cost as much as a paint job to put another one on. So in reality, not worth it.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
h22lude
Sep 27, 2015 06:22 PM
ceb
ILX
Sep 27, 2015 10:56 AM
AmplifiedDetails
Sep 24, 2015 02:55 PM
