A good tar remover??
~Whatever~
What product would you all recommend to remove road tar? I purchased that Bug and Tar remover spray and it really didn't do much of anything.
(They're doing some road work where I reside and I try to avoid going near them but there are no alternative routes to get to work.)
The Old Grey Whistle Test
Tar (Asphalt) Removal:
The reasoning for the use of solvents for the removal of road asphalt (tar) is that it dissolves it as a means of removal as opposed to rubbing it. Asphalt (tar) is very sticky and its presence on your paint means that harder particulate matter (dirt/grit) has also stuck to it. By agitating or rubbing the dirt/grit that is contained with the asphalt will cause surface marring or possibly scratching, dissolution alleviates any potential damage.
A solvent (Stoner™ Tarminator) can also dissolve a variety of oil and petroleum based products. It's safe to use on all types of paint, plastics, synthetic fibres, carpet and upholstery. If used on vehicle paintwork re-apply a protect rant after use.
Other uses - it will dissolve chewing gum and adhesives. Use to de-tar wheel rims after cleaning, will also remove shoe scuffmarks from vinyl trim, and can be used to remove tree sap or fuel stains from paint surfaces.
JonM
JonM
cycdaniel
12-17-2019 10:58 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
