Is this a good deal for a PC kit?
http://www.topoftheline.com/porcabpolpac.html
Package Includes:
# Porter Cable 7424 Orbital Polisher with wrench and foam pad/plate combo.
# 6" Velcro Pad Holder
# 7.5" Lake Country VC Cutting Pad (oxidation and scratch removal)
# 7.5" Lake Country VC Polishing Pad (swirl removal, polishing, one-step cleaner/waxes)
# 7.5" Lake Country VC Finishing Pad (liquid or paste wax application)
# (2) 6" Terry Bonnets (removing polishes, waxes and cleaning glass, leather, vinyl)
# 6" Flat Foam Polishing Pad (supports terry bonnets.. not shown in photo)
# 4" Mini Foam Polishing Pad (polishing in/around constricted areas)
# 4" Mini Foam Finishing Pad (applying waxes in/around constricted areas)
# 4" Velcro Pad Holder (for 4" foam pads)
Package Special: $189.95
should i do it? Or is there somthing else i should look into?
Package Includes:
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
Cheaper if you go to Lowe's and buy your Porter-Cable. They have them for $93.
Buy the 6" Lake Country pads, flexible pad holder, and terry bonnets from www.topoftheline.com.
Flexible pad holder - $15
2 Orange cutting pads - $15
2 White polishing pads - $15
2 Black finishing pads - $15
4 Terry bonnets - $10 the Terry bonnets will fit over any of the dry pads
Total cost for pads $70 plus PC from Lowes $93 = ~$163
on to the next one...
B
I'm Baaack!
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
I'm Baaack!
(By the way, I wouldn't worry about the terrycloth bonnets or the 4" pads ... I hand buffed with a MF and there weren't too many places the bigger pads couldn't get to.) might save you some coin.
teh Senior Instigator
Location: Huntington Beach, CA -> Ashburn, VA -> Raleigh, NC -> Walnut Creek, CA
agree, and I wouldn't bother w/ the terry cloth either. I have a few MF bonnets and have used them once on an excursion, so easy to remove by hand
Sellout - pads from exceldetail are really good, while you are there you can order the polish/wax/ and whatever else you need
I'm Baaack!
Originally Posted by TSX7
Wow that is CHEAP! Up here in Canada, PC polisher cost $240 + 15% tax ($276)! I guess I'll go and pick one up in Detroit in a few weeks. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Or is one ok?
Also, how many Terry Bonnets do i need if i'm only doing one car at a time?
Also, since i am not planning on using this with any paint levers or compounds, is it neccesary to get the orange cutting pads? I am basically just polishing and waxing.
So is it ok for me to get just
1 white polishing pad
and 1 black finishing pad?
Or would i need 2 for one car?
I'm Baaack!
I'll throw in my ![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
Is it neccessary to have 2 pads of each if you're only doing one car? No, I got two of the pads I thought I would be using most, but you could go with just one of each
Or is one ok? See above
Also, how many Terry Bonnets do i need if i'm only doing one car at a time? I don't use Terry bonnets, I use foam to apply and Microfiber cloths to remove
Also, since i am not planning on using this with any paint levers or compounds, is it neccesary to get the orange cutting pads? I am basically just polishing and waxing. I would get at least a light cutting pad, you may find that the polishing pad isn't aggressive enough depending on which polishes you use.
and 1 black finishing pad? See above, In fact, Depending on what glaze you use, you may not even need the finishing pad. (I use Menzerna FMJ and apply by hand)
Hope this helps!
Hope this helps!
Hope this helps!
Hope this helps!
Thanks for the info.
One more thing, Do you guys recommend the NXT paste? or the gel/liquid?
thanks
TLDude876
12-28-2016 03:18 PM
nuldabz
09-03-2015 05:49 PM
