Foam pads "mushrooming "
When I'm using flat LC pads they sometimes distort into a "mushroom" shape after a few uses - especially the yellow cutting pads - wonder if I'm applying too much pressure ( backing plate is marked & pad is always still spinning ) or not keeping the pad flat enough? Not changing pads often enough? Looking for input from Jesstzn or one of you guys with experience with this. Am I doing something wrong? Don't want to chew up my pads too fast!!! (Using GG orbital, 5" LC backing plate & 5.5" pads & usually Optimum compounds & polishes by the way )
BenWa03tl (07-17-2015)
I've detailed for years. I've never used Lake Country, but I have used meguiars, 3m and griots foam pads. After having used meguiars microfiber pads, I will never use foam pads again. They're durable and easier to clean (while detailing) than foam pads imo.
Still pretty new to polishing but I just tried optimum m/f pads & I liked them - cut well, no deforming & like you said, easier to keep clean. Still trying different combinations to see what works & what doesn't. Still working on technique too
I primarily use LC CCS pads and at first, I had overheated a few to where they were concave in the middle of the pad. After further experimentation, I actually melted the velcro backing. Lessons learned: clean often, change often, do not use too much pressure.
08_UA7_Gr33k
02-11-2016 02:17 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
