Foam Cannons?
Old Oct 21, 2012 | 09:13 PM
07BLKTL's Avatar
Foam Cannons?
Okay, So I really want to start using one. Looks like it makes washing easier and seems like it would keep my pad's well lubed and help me cut down on swirls with the NBP.
I just don't think I can get one to work with my cheap-o pressure washer that I have.
I have seen some of the foamers for regular hoses, but do they really give off enough foam or is it just a big waste of wash/soap?
Old Oct 21, 2012 | 09:48 PM
Andy Tsang's Avatar
I bought a gilmour one from amazon. It works great with a regular hose and you can adjust the amount if foam you need.
Old Oct 21, 2012 | 11:10 PM
07BLKTL's Avatar
Does it waste a lot of product though? Looking at some of the other pressure washer style cannons it would appear you add about 8-12oz of product and it seems you typically will use it all up for a whole wash?
Old Oct 22, 2012 | 09:34 PM
Hi speed's Avatar
runnin a little boost
They don't use any more soap than you would use to wash the car 1-2 oz. My problem is once you spray the car you can't tell where you have washed from areas that are just soapy. If you spray the car off first, the foam doesn't stick and if you spray foam straight on a dirty car I feel like I'm doing more damage than a reg wash.
Old Oct 22, 2012 | 09:50 PM
Andy Tsang's Avatar
You don't use much more than you usually would use. It makes washing my car much faster.
Old Oct 23, 2012 | 10:03 AM
07BLKTL's Avatar
This is what really made me want one...
Old Oct 23, 2012 | 05:54 PM
Andy Tsang's Avatar
Just do it.
Old Oct 23, 2012 | 06:41 PM
07BLKTL's Avatar
My issue is the connection doesn't fit my pressure washer and I don't know that I want to invest in another pressure washer just for that lol.
Andy, what's your car look like after using the foamer for the regular hose? Does it look at all like that or no?
Old Oct 23, 2012 | 07:02 PM
Andy Tsang's Avatar
I can get plenty of foam with a regular hose. The gilmour one allows you to adjust the level of foam you desire.
Old Oct 23, 2012 | 09:12 PM
v|nsan|ty's Avatar
OP - Are you sure none of the attachments will work for your pressure washer? My first pressure washer was some generic 1400psi and I found the appropriate connecting piece. There is a variety of at least 5 attachments for connecting the foam cannon.
From the videos I've seen on youtube, the gilmour doesn't come close in terms of foaming or cling that a foam cannon can provide. Even with a low powered pressure washer I still get decent foam. The videos on youtube all show the gilmour as runny and don't really produce a shaving cream consistency.
Here is a shot using a couple ounces of soap. I've gone upward to 8-10 ounces in the bottle before and it clung like crazy.
Old Oct 23, 2012 | 09:24 PM
v|nsan|ty's Avatar
From that youtube video, keep in mind they don't mention how much soap they use and what pressure washer they're using.
Also, here is the foam produced from my upgraded pressure washer:
Old Oct 24, 2012 | 10:19 AM
BobbyC's Avatar
are there any cheaper ones that are decent?
ive been wanting to get one for a bit but at like $50+.... its pretty hefty for something that basically sprays water with soap in it...
Old Oct 24, 2012 | 04:15 PM
iSeeYouTwo's Avatar
Yeah, what he said^^^^
I was considering the Gilmour one until vinsanity posted.
Old Oct 24, 2012 | 06:31 PM
v|nsan|ty's Avatar
You gotta pay to play. You guys have it good paying only $50 for it in the States. I had to get mine local for $100.
Old Oct 24, 2012 | 07:05 PM
iSeeYouTwo's Avatar
Is there an alternative to the Gilmour that you would recommend for a regular hose?
Old Oct 24, 2012 | 07:53 PM
Last Acura's Avatar
RDXing
Vinsanity, that is awesome. I need a pressure washer, recommendation?
Old Oct 24, 2012 | 08:06 PM
v|nsan|ty's Avatar
Sorry not sure what else would produce foam with a regular hose.
I'm currently using this one:
http://www.homedepot.ca/product/hydr...-washer/916019
User reviews aren't great but I've had awesome success with it. Just make sure to purge out all the water form the lines after you're done every time and put it away when temperatures start to freeze. What really drove me to buy this one is the "hydrosurge" feature. This isn't a typical PW and has two hoses with two nozzles. One is the high pressured one while the other is standard pressure you would get from a garden house. This makes rinsing a car so much faster since you can have both nozzles going on at the same time.
Old Oct 25, 2012 | 11:34 PM
CU2MIKE's Avatar
Did someone just complain about how much their foam cannon cost? LOL :p jk Vince
http://www.flickr.com/photos/detailmaniac/8111526582/
Old Oct 26, 2012 | 06:05 PM
BobbyC's Avatar
not complaining about how much it costs.
just wondered if there was a cheaper alternative.
i dont detail cars for a living.
its kinda hard to justify spending that much money on a hose attachment that id use prob once every 2 weeks at the most.
Old Oct 26, 2012 | 06:19 PM
iSeeYouTwo's Avatar
I wasn't complaining about the cost either, lol. I actually found it pretty cheap compared to the foam cannons for pressure washers.
What I thought vinsanity meant by his comment was that we shouldn't be cheap and buy the Gilmour one's but buy a pressure washer with the corresponding foam cannon instead.
Old Oct 26, 2012 | 07:18 PM
CU2MIKE's Avatar
I was talking to Vince
Old Oct 26, 2012 | 07:28 PM
iSeeYouTwo's Avatar
^So was I.... now everyones confused. Lol
Old Oct 26, 2012 | 07:50 PM
CU2MIKE's Avatar
Old Oct 27, 2012 | 12:28 AM
v|nsan|ty's Avatar
Lmao look at the drama Mike has caused
I'm going to fly down there and steal your autoglos foam cannon haha.
Old Oct 27, 2012 | 01:15 AM
CU2MIKE's Avatar
OTD's Avatar
OTD
check out these foam footage!! you don't need a foam gun or foam cannon...but its good to have it.
Old Oct 27, 2012 | 10:19 AM
sy272004's Avatar
if you have power washer with quick connect attachment then home depot has foam cannon atachment for that
if you dont have quick connect then they have adaptors for most power washers but thats another $25 or so. cannon attachment is about $18 and you can adjust mix ratio
foam kinda depends what shampoo you using and what dilution with water
Old Oct 27, 2012 | 12:26 PM
quakerroatmeal's Avatar
Foam cannon is far better than the foam gun you use attached by the hose. Foam cannon is pretty kick azz..makes washing the car so fun and easy. You can use the pressure washer to do other things as well like clean your drive way and garage.
Old Oct 27, 2012 | 12:28 PM
sy272004's Avatar
its good idea to power wash the car before using wash mit. this way you wash off more dirt that can couse swirls. specialy on soft honda paint. its almost impossible to keep mine scratch free, hope cquartz goes on soon
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
cacheflowe
Sep 14, 2015 10:35 AM
