drying materials
drying materials
what do you all use for drying your car?
i have a chamois towel that i bought for around $16 bucks a while back, don't remember the brand though.
should i use something else? or is chamois bad?
someone told me to use terry towels but they leave too much lint and fuzz. any suggestions?
I use a MF waffle weave for drying like the one pictured. 24 x 36, very absorbent, no streaks, leaves no lint behind, no ringing necessary and one towel does it all. Off course I have 2-3 on hand.
Yes it is!
I used to use a deerskin chamois, and that worked pretty well, until I got this The Absorber thing. It's a synthetic chamois of sorts, available anywhere. Works great. It even comes with a storage tube, so I can stick it in my trunk and use it in emergencies.
The only issue I have with it, is that it leaves the smallest trace of lace-pattern water spots on the windows.
Former Sponsor
Waffle Weave drying towels.......such as Danny posted will reduce drying time, and allow the user a safe, affordable, and long lasting tool for quick drying there cars.
Still Lovin my 06
Yes it is!
Originally Posted by bradykp
my dad's been using "the absorber" for years. just bought one for myself. i always thought that it wasnt for windows though...
Just dial 1911
1 Post
The Old Grey Whistle Test
•Use a low-pressure, high volume water flow to `break' the surface tension of the water laying on the paint surface with the Ultimate Nozzle™ (or if you prefer remove the nozzle) you will see the water `sheet' off, move the hose down to "feed" the sheet as it flows down the panel, this will keep the `sheet' wide and it will carry away more water.
•The remaining water can be removed using a 24" x 30"waffle weave towel (Sonus Der Wunder Drying Towel) by pulling it across the panel or using a blotting motion, do not rub This gets rid of all the remaining drops and leaves only a little moisture, which can be removed with the towel. Use the blow side of a vacuum cleaner to remove water from crevices, wing mirrors, license plates, etc
•Use a water blade to remove water from glass surfaces
•Dry doorjambs, sill area, seams and crevices of hood and trunk with a Waffle Weave towel
[each one / teach one, then student /becomes teacher]
Just dial 1911
1 Post
What concerns me with this method is the user stirring up dust with all that wind.....It has to fall somewhere....
MrHeeltoe
20
02-23-2023 01:54 PM
mlody
12-04-2019 02:11 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
