clear coat help
clear coat help
so im trying to paint a shit bumper i had off my tsx. i sprayed it with 3 layers of paint and then i put clear coat over the paint. now the bumper is rough. my question is how do i go about getting that gloss shine back in the paint? any products and methods would help greatly.. hopefully this thread is in the right section. thanks.
Needs more Lemon Pledge
This is kinda like me asking how to stitch up my own abdomen after removing my own spleen. Something I am clearly not qualified to do.
Maybe wetsanding? Don't do it if you don't know how, though, or you will make the bumper worse.
Yikes, what made you do this to your bumper, or is this a spare bumper?
Former Sponsor
I would try wet-sanding it using very fine sandpaper
does it matter if im using shit paint from advanced auto, the aerosal stuff.. i didnt want to spend the money on a spray gun and good paint because im never going to use the bumper, just trying to learn something.
From experience, light rubbing compounds work best (heavy ones cut too much). However, not all cheap clear coats are compatible. Some rubbing compounds will ruin the finish on some cheap brand clear coats.
A combo that I found worked really well before was DupliColor's Professional Clear Coat and PaintScratch's Light Rubbing Compound (can get both for about $20 total from PaintScratch.com). I've tried that same rubbing compound on the OTC DupliColor (cheap $5 ones) and it works okay too, just the gloss is not as good.
The Old Grey Whistle Test
The best thing you could do with this is to learn how to wet-sand. The bumps you feel in the paint are called 'nibs' (which are actually dust/dirt specks)
thanks for all the feedback. i really appreciate it. is there a technique to wetsanding? i think i might have the hang of it but knowledge is power. thanks
Sorry for the earlier sarcasm speedlimitz. I thought you were working on your own car and fixing it the "cheapo" way! Now I am interested in what you are doing. Take some pics to share as you do it so we can how it goes!
Will chop for food...
What we have here gentlemen is a simple case of "orangepeel." Ideally, rubbing compound or a wetsand should have been done prior to the clear coat being sprayed, but you should still be able to use either of those techniques to help smooth things out.
I'll try to find the article I used when I had my Integra for you...
MrHeeltoe
20
02-23-2023 01:54 PM
IBankMouse
06-13-2020 12:53 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
