Check my order
Old Jun 1, 2004 | 12:33 AM
NYDesi80's Avatar
Check my order
Please correct me if I'm worng. I was goign to use these products in this order:
1. Wash Car with Mr. Clean Auto Dry System
2. Then use Mother's Pre-Cleaner Wax
3. Clay Bar (Dont know which brand yet)
4. NXT Tech Wax
WOuld this be ok or should I make ne modifications?
Old Jun 1, 2004 | 05:50 AM
Bxscig's Avatar
I think
Old Jun 1, 2004 | 08:16 AM
NSXNEXT's Avatar
Originally Posted by Bxscig
Wash with Dawn to remove any fillers from the PCW
I think
So close...
Or you could just skip the PCW altogether. Once you clay, the paint should be in good shape.
Old Jun 1, 2004 | 08:27 AM
Bxscig's Avatar
Old Jun 1, 2004 | 03:14 PM
groebuck's Avatar
Keep the dawn in the kitchen - your steps are fine but you might be making too much work for yourself. Claying will get rid of on surface contaminents, the Pre-cleaner will do that and remove oxidation, old wax and possibly some minor swirl marks. If your paint has no oxidation and such, then you can just clay. If it does then you can skip the clay and use the pre cleaner wax. Since you car is a 2003 I would wash, pre cleaner wax then follow up with NxT. If you want to go the extra step get Meg's Deep Crystal Polish (#2 in their three step line). It is almost exactly like MEg's professional Show Car Glaze but much easier to apply and remove. This will add a layer of depth and shine that the NxT will then seal in and give you awesome results.
Hope that helps.
Old Jun 1, 2004 | 03:48 PM
dj5's Avatar
dj5
Hope that helps.
Agree,
I always finish mine up with a once over with Meguair's Final Detail. And don't forget Meguair's Endurance for the tires.
Here is what I did this weekend.
1. Washed with NXT wash.
2. Applied Meguairs swirl remover then removed
3. Applied Meguairs show car glaze then removed.
4. Applied Meguairs NXT and removed.
5. Finished up with Meguairs Final Detail.
My black TL-S has a great shine (sorry no pics).
Old Jun 1, 2004 | 10:01 PM
Dare_IL's Avatar
Need a WHAmbulance
I would recommend that anyone that hasn't used a claybar on their car to do that before using a polish. Those little specs of metalic brake pads, usually from railroad cars, will scratch a clear coat in a heart beat when caught in a polishing pad.
Old Jun 2, 2004 | 08:33 AM
NSXNEXT's Avatar
If NXT is anything like Zaino, you need to strip any non-polymer finish from the paint before applying it. Zaino and I assume NXT like a very clean surface to bond. Since it's a polymer, it does not bond to a carnauba. You can certainly top it with a good wax, but I would not apply it over top of one. I'm sure the shine is great either way, the longevity will surely be reduced.
Old Jun 2, 2004 | 10:20 PM
9th Gear
you are correct . . . gotta be bare . . .
Old Jun 3, 2004 | 07:15 AM
groebuck's Avatar
not really
if you are going to polish then you are going to be removing oxidation, correcting swirls and what not...your lifting a layer that includes the embedded rail dust (or what ever). All clay can do is remover "surface" contaminations...don't take those diagrams to heart where you see the contamination "jammed" into your clear coat -.
Old Jun 3, 2004 | 07:52 AM
Mr Hyde's Avatar
That Mr Clean stuff leaves a residue on the surface of the paint that helps the sheeting action. I would NOT consider that a clean enough surface to Clay or polish your paint.
mada51589
Jan 9, 2025 04:40 PM
braveheart
Sep 25, 2015 08:20 AM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
Tsov Tom
Sep 20, 2015 07:31 PM
