Car exterior care
'04 CG TSX
Car exterior care
Hi,
what is the best way to take care of the exterior. Is touchless car wash good? Are are the touchless car washes the same or there are any different types in it. I don't want my car to get scrates due to the car wash.
Thanks.
Thanks.
Originally Posted by d-rock
i suggest reading up on the site autiopia.org theres lots of information on there to clean ur tsx properly
Not to be an a$$, but the link is actually http://www.autopia.org Also try http://www.bettercarcare.com
DONT WASH YOUR CAR WITH ANYTHING THAT DOES IT FOR YOU!
get out a bucket and a soft car washing brush and do it yourself....always in the shade.......do 1 section at a time
wax the entire car 1 time a month.....NU FINISH will do the job just as good as any other wax
clean your rims with PLAIN OLD SOAP AND WATER (use the same water you used to wash your car....only do the rims LAST)
always put armorall on your tires.....keeps the rubber healthy and looking good.......i like ULTRA SHINE myself
if you need any more detailed advice just ask me...this was a quick reply
Originally Posted by floridaowner
i recommend using armor all car wash wipes- no drying needed. have had my tsx for seven months and people think i just got it. that along with waxing is all you need to do.
car wash WIPES....as in wipeing off the dirt with a WET CLOTH...??
if that is the case NEVER DO THAT because you will put fine scratches in your clearcoat!
car washing
Stay away from automatic washes. They do alot of damage and used dirty recycled water.
Use a bucket and a soft Chenille wash mit or a microfiber mitt. I prefer the MF mitt. Rinse car well from top to bottom and then start with you favorite shampoo. I like the Einszetts Perls shampoo. Always start at the top and work in back and forth motions. Always wash in the direction the wind would flow over that panel if the car were moving. NEVER wash or wax your car in circular motions. This is what introduces swirl marks and micro marring. Forget everything you've learned about washing cars from watching the Karate Kid. I cringe everytime I see that scene. Do wheels last as they hold the most dirt. If your car has a good coat of wax then try drying with water. Simply rinse off entire car then remove the nozzle and start at the top and let the water run down the panels and sides. This should leave you with a car that is 85% dry. Next take a leaf blower and get the water out of the cracks and door jams and gas lid. A good quality microfiber drying towel will finish up nicely. Remember to always blot dry with your microfiber towel and never rub it along the paint. The good MF towels are usually made in Korea so stay away from the Costco brand as they are made in China and are not seamed with microfiber.
To finish up the tires stay away from Armol All. It has no UV protection and will eventually cause browning of the tires. The so called "spray and forget" brands usually tend to "sling" all over the car after youve done all that hard work. I like Einszetts Teifenflager or 303 Aerospace Protectant. Both leave a nice shine and have plenty of UV protection. Plus no sling.
Now for polish. If you dont expect much than Nufinish is fine. Heck, I remember when I thought Nufinish was the best stuff out there. So if you're happy with the results than by all means stick with it. If you are looking for something that will make your TSX "pop" or stand out in a crowd than try a higher end product like Einszetts or Zanio. Klasse makes a great starter cleaner /wax called Klasse AIO(all in one). This can be topped off with their SG (sealant glaze) Both can be allpied by hand if you dont have a Porter Cable yet and they give great results. The Klasse AIO is a cleaner/wax so it does the job of both in one easy step. Just wipe on and wipe off, its that easy.
Hope that helped you out a little. Let me know if I can help anymore.
TechLedr
What I found after 10 days (without any rain) was the tires still looked like "new", and did not brown or degrade the shine/look in any way.
What was also interesting is the wheels, which were "protected" by what was oversprayed from appling to the tires, did not attract brake dust as before, and just a hose down was all that was need to get 99% of the grime that did collect. A simple wipe off then was all that was need to finish. Saves me a bunch of time.
Now, 303 Aerospace Protectant can get expensive, however, in the long run, it looks like a good payoff. If you purchase in the larger sizes from the factory website, it's not that expensive (I got 16oz+32oz for about $23+ship).
Big Block go VROOOM!
You don't have to necessarily do the wheels and tires last. Tire dressing needs to be last, of course, since the tires need to be dry. But you can do general cleaning of the wheels and tires first. I do this because I figure why should I take all of the crap I just washed off of the bottom of the sills and rub it all over my wheels. If you do the wheels & tires first, however, you absolutely need to empty, rinse, and refill your buckets before proceeding on to the rest of your car. The other requirement is that you have brushes, wash mit, towells, etc... dedicated to just the wheels and tires. You should probably do that anyway regardless of whether or not you do them first or last.
BTW, since nobody else has mentioned it. Use two buckets, not one. One bucket is for your soap/shampoo and the other is just for rinsing between sections.
3rd Gear
Dishwashing soap
Is using dishwashing soap to wash your TSX a no-no ? I'm a clueless girl and my room-mate said it was fine, but my dad says it's too harsh and may damage the paint ? who is right ? Thanks.
dishwashing soap
Dawn should only be used as a stripping agent to remove old wax and build up before a major detail job. As stated above, Meguires Gold Class will be fine. DONT USE DAWN for regular washes!!
Oakes
Wash & Wax
10-12-2015 11:17 AM
