Can I apply another coat of Zaino after a week?
I washed my car last week and applied one layer of ZFX + Z2. Can i wash my car this week and apply another layer? Is the surface of the car suppose to be really smooth after the zaino is applied? The hood is really smooth, but when I touch the fenders, it's not so smooth.
thanks!
thanks!
If you use Z2+ZFX you can apply up to three layers a day. If you use it without the ZFX (with Z1 on the first layer) you should wait about 24 hours before you apply the next layer.
If there is already a layer of Z2 with either ZFX of Z1 on the car and you only want to apply one extra layer you dont need to use the ZFX again. At least not until you get to the 10th layer
I just love Zaino, it gets better with every layer you apply. In the picture below my car has 2 layers of Z5+ZFX and one layer of Z2 on it. Im planning to apply a few more layer of Z2 the next couple of weeks...
![](http://www.pbase.com/image/27987998.jpg)
So when I wash my car this weekend, I can apply another layer of Z2? Do I need to mix the Z2 with the ZFX again? I couldn't apply a second layer on there because it got dark. I did use a layer of Z1 before I applied the ZFX+Z2.
I like that front lip you have.... do you know where I can get that?
After the first layer of Z2 with either ZFX or Z1 you only have to mix the Z2 with the ZFX if you want to apply more than 1 layer of Zaino in 24 hours. If not, apply only the Z2, let it dry for an hour an wipe it off.
I hope this helps you...
Wait, so I don't need to use Z1 if I'm mixing ZFX+Z2? No where on the Zaino website does it say that, and the instructions don't say that either....hmm..
So when I go to apply the Z2 again this weekend after my wash, should I use the ZFX again or just plain Z2? I can't leave it on for 24 hours because I'm going to need to drive my car and I don't have a garage. =(
thanks for all your help!
This is what the Zaino website says about ZFX...
This next part applies only when you dont mix the Z2 with ZFX...
If you mix the Z2 with ZFX you can apply up to three layers a day, also drying time is greatly reduced.
4. The basic products you will need are Z1 or the new ZFX accelerator additive, Z2, Z5 (optional, but highly recommended), Z6 and Z7.
5. Start with either Z-1 Polish Lok as per directions OR the preferred New ZFX accelerator additive. If you are using Z-1 it does not need to dry. Remember do not wipe off the Z-1 Polish Lok. Apply Z-5 or Z-2 directly over the Z-1. Z-5 is the Hot ticket for a swirl free, flawless paint finish. Usually one to three coats will accomplish that.
6. Let Z-5 or Z-2 polish dry at least one hour. Please NOTE: Zaino Show Car Polish works best at 60 degrees or higher. However, it can be applied down to temperatures of 45 degrees. It just will take much, much longer to dry. As much as two to three hours drying time is required if the temperature is 50 degrees or below. Also, If the humidity is high. Longer drying time is necessary. Humidity is a killer on the drying time of Z-2 or Z-5. The moisture in the air hinders drying time up to four times longer than normal. Sorry, but I can't help this. When you try to remove Z-2 or Z-5 when it is still wet. All you're accomplishing is moving it around. Kinda like reapplying it. Also you need to use a LARGE White 100% Bath size towel (please refer to my Tips & Tricks sheet on my web site for the proper towels to use) to remove Z-2 or Z-5. Smaller towels will not work efficiently.
To test if Z-2 or Z-5 is dry and ready to be removed. Wipe your finger on a hazed section. It should immediately come off and leave a crytal clear finish. If it smears, it is still wet. You can leave Z-2 or Z-5 on for hours or overnight if you desire. When it is not humid Z-2 will take anywhere from 30 to 60 minutes to dry. Depending on how heavy you applied it. I have applied Z-2 in the Arizona sun and it dried in approx. 3 to 5 minutes. I have also applied it in 38 degree temperature and it took about 2 to 3 hours to dry. Be patient. It's worth it. Different situations affect drying times. Also, remember you have Z-1 and Z-5 both on the car. That is two products that have to dry at one time. Takes longer. Z-2 or Z-5 does not cotain any oils and once it's dry will never ever look smeary or feel greasy. If you remove Z-2 or Z-5 before it is thoroughly dry and get any smears. Just wipe down the car with a damp cotton towel. This will remove any smears. Don't use Z-6 until you wipe the car down. If you'd like call me and I'll help you out with more info!
Note: If you are using the New ZFX accelerator additive drying time is greatly reduced.
7. After removal of Zaino Z-2 or Z-5. You should wait 24 hours if the outside temperature is under 70 degrees and 6 hours if over 70 degrees, before applying the next coat of Z-5 or Z-2.
I used the ZFX+Z2 on top of the Z1, do you think I should start all over by taking the wax off or apply Z2 right over it after washing?
Hi.... the answer above is correct.
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
Zaino is by far the best product I've ever used on my cars. To bad it is very difficult to get some here in the Netherlands. There is a distributor in Germany but the prices are ridicules!
To bad Sall doesn't ship to European customers
Hey Dutch, how much are they charging you over there? Are the prices on the zainoproducts.com site cheaper for you? I would have no problems shipping some through USPS global priority (about $10-$15, depending on how much stuff) for you. Whatever you want to order, add 8.95 to have that shipped to me and then however much it will cost to ship it to you in the netherlands. I have a paypal account if that makes it eaiser.
Homer- I bought the zaino stuff online from zainoproducts.com
I was wondering water wasn't beading off like it should after I waxed it. Must wax again!!!
thanks guys.
thanks guys.
A bottle of Z2 costs about 25 dollar over here, shipping from Germany to the Netherland will cost another 20 dollar!
Right now I have enough Zaino products on the shelf, but if I need any in the future I jmight just take you up on that offer
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Dj - that explians that . ..it is one reason they took so long to set up e-comerce. Customers need info . ..
Dutch . .. Z2 is $25 - is that US dollars? Its 19.95 Canadian list . .the last shipment I made overseas was in canadian dollars also . .. what currency do you deal in?
I live in The Netherlands so the currency we use here are Euro's. A bottle of Z2 is 20,95 Euro which is about 25 US Dollar.
Here is a list of the prices we have to pay for the Zaino stuf...
Z1 17,95 USD
Z2 25,15 USD
Z3 25,15 USD
Z5 32,35 USD
Z6 19,15 USD
That is double the price you guys pay overthere, an shipping from Germany isn't exactly free either
Do you ship to Europe Homer2, if you do I think I know some people that would be interested
Z1 17,95 USD
Z2 25,15 USD
Z3 25,15 USD
Z5 32,35 USD
Z6 19,15 USD
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Dutch . .. distributors are supposed to sell with territories only . . . I have made the odd "out of the ordinary" shipment for special customers . .. . Thanks for asking . . .
Question. I've read Zaino's literature but there is no mention as to what's the best way to accomplish the following:
Assume car is washed clayed. Also, assume car has some fine scratches and swirl marks.
No Z1 is needed because ZFX is going to be used for first layer.
Because there are scratches on the car do you start off with a layer of Z5 (with ZFX) first? If swirl marks/scratches still show, repeat? If repeat do you use Z6 in between layers?
And finally end with Z2 (use ZFX if time is critical).
Or can you start with any combination of Z2 and Z5?
OK - first suggestion . .deal with the marks.
If you have the ability - use a swirl/scratch remover - often needs a polisher.
If you wont be doing that - then try to hide them with multiple layers of Z5... keep going up to about 9-10 in total, because after that, you arent really changing anything any more . ..
Otherwise, many users will intermix a Z2 and Z5 sandwich . ..
And yes, its better to do the Z6 inbetween layers - BUT, if you dont - the paint wont come off , the neighbours wont know . . only you will . . . .
Dennis
Dennis
mada51589
05-03-2022 08:54 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
