Bugs on front of my CL-S
Old Mar 31, 2004 | 02:17 PM
JPPHARMD's Avatar
How do all of you take off the bugs off from your car? I got the bug and tar removal stuff but its not working,, on a friends car I used grease remover, but do not want to use that on the CL. any suggestions? thanks.
Old Mar 31, 2004 | 02:28 PM
stejus's Avatar
Manny Tranny
The key is a good layer (several) of Zaino. This will help remove the bug with ease.
The best way to beat the bugs is to stay on top of them. Start with a clean bumper and make sure you have a good layer (several) of Zaino or some other wax. Then, keep a spray bottle in the trunk with a clean rag. Dampen the rag thoroughly and then pat the bug or bird poop with the damp rag. Then, take the dry side of the rag and tap the area dry. DO NOT RUB. If it’s a tough bug, it may require several wet rag taps. This method will keep you clean until you do a real wash (with soap).
For several bugs at once (if it’s a real mess), I usually hit the front bumper with water and soap and then dry it.
Old Mar 31, 2004 | 02:32 PM
Red-CL's Avatar
Doin' da crack shuffle
I don't use any solvents of harsh cleaners.
After I wash my car I rinse thoroughly. I repeat this step about 5 times for the front of the car to make sure all the bug juice is off.
When I'm satified with the results, I then dry it.
I also apply a couple extra coats of Z to keep them from sticking in the future.
Old Mar 31, 2004 | 03:32 PM
NSXNEXT's Avatar
I've heard very good things about this product.
einszett Anti Insekt
Scroll about halfway down the page.
Old Apr 1, 2004 | 02:42 PM
RaptorCLS's Avatar
Dromaeosaurs/Velociraptor
simple green foam is good
Old Apr 1, 2004 | 10:30 PM
JPPHARMD's Avatar
Thanks for the advice. one more question, where do i order the Zaino wax?
Old Apr 7, 2004 | 12:31 PM
VeeralS05's Avatar
I NEED MONEY!
well, u can always use the pressure washer
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
Sep 17, 2015 10:16 AM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
Gary Matthews
Sep 11, 2015 01:21 PM
08 NBP TL
Sep 8, 2015 08:49 PM
