View Poll Results: Do you clean the brake rotor after you wash your car ?
Yes
![](https://acurazine.com/forums/images/maestro/polls/bar2-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2-r.gif)
![](https://acurazine.com/forums/clear.gif)
5.88%
No
![](https://acurazine.com/forums/images/maestro/polls/bar3-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3-r.gif)
47.06%
No one wash the brake rotor, don't waste your time
![](https://acurazine.com/forums/images/maestro/polls/bar4-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar4.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar4-r.gif)
47.06%
Voters: 17. You may not vote on this poll
Brake rotor cleaner
Brake rotor cleaner
I just change to slotted and drilled rotors on Saturday. I washed my car today and cleaned the rotors with a damp towel because of rust. I think that I should clean the rotors every time I wash my car to not let it rust.How many of you did clean the brake rotor after wash your car ? What do you use ?
I don't think you need to cause the rust should go away by driving. I recently cleaned my brake caliper with BrakeBest brake parts cleaner cause my brakes were squealing even though there were still a lot of life in my pads.
Your Friendly Canadian
Received 1,485 Likes
Yup, what everyone else said. Couple minutes of driving will get rid of it.
It's actually not new to me , I know it
. I just actually want to know who clean the slot in the slotted rotor like me
. The area around the hub like telling me to clean it , it's look so nice
Thanks for the invitation but I can not go so far to Galveston. ( I will look like a noob over there cause I'm just 18 ). I want to clean my caliper too but It's too dirty now . I don't know how to wipe everything off.
![what](https://acurazine.com/forums/images/smilies/what.gif)
What ever is labeled as "High Heat" paint.
i think it comes mostly in black, but might have other colors.
I just painted my calipers. I took the bracket off and spray painted it with black high heat.
the piston, i left hanging and sprayed it. I oversprayed onto shocks and other components....it wont hurt.
I then sprayed the hub, Some over spray was on the rotor, but it came right off when I drove and used the brakes just like the rust.
The Old Grey Whistle Test
Zinc Aero Rotors are available either drilled or slotted, an optional anti-corrosion gold zinc coating benefits those who live in cold climates, where snow and road salt are commonly encountered. Zinc coating also benefits detailers who prefer no visible surface rust on the vanes and outer circumference of rotors - Quick Stop Pro
lanechanger
10-13-2015 10:56 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
