Adhesive remover - what's safe on clearcoat
Manny Tranny
I had a previous post on this but I can't find it. Anyhow, I have a line of glue (must be from the protective film) on the hood. I plan to Clay this weekend. If that doesn't remove it, are these products safe on clearcoat?
Goof off - I've used this on hardwood floors and no problems with poly coat!
WD40 - Good overall cleaner, but will it harm the clearcoat?
Cheers!
Cheers!
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
Lone CL-P Owner
i say just soak the glue really, really well. i dont know about any adheasive removers. just try soap, like dawn or something since your gonna clay it anyway. your could just try to peel it off.
You will need a solvent based product to easily remove adhesives. Don't use any water based product because you tend to rob too much!!!. Go to the Home Depot and look for any solvent that's safe on the paint that can remove adhesives
With the right product, the glue should come off almost instantly.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Received 1,080 Likes
Go to any auto parts store and look near the body repair section for something like PrepSolv or Chronar. Tell them you need a lacquer and enamel cleaner. It needs to be clearcoat safe.
4drviper
09-23-2015 07:42 PM
