Is 50/50 water/vinegar solution safe on ..
Old 05-18-2005, 07:28 PM
xaznperswaesonx's Avatar
.. the inside of the rear windshield where the defroster is at???
Reason i'm askin is bc i think i have water spot in the inside due to dealer sucking ass in detailing ..
Old 05-18-2005, 08:29 PM
Former Sponsor
exceldetail's Avatar
You cant clean it with the normal window cleaner ?
Old 05-18-2005, 08:45 PM
that's a negative .. tried using stoner's invisible glass .. still woulndt come off ..
Old 05-19-2005, 02:52 AM
2Poor 2Furious
t0ast's Avatar
Do you have tints? I'd be carful using any chemicals on tints. Otherwise, it should be ok. Maybe try alcohol or acetone or Simple Green cuz I know that's safe for glass. I used that stuff on glass when I used to work in a cleanroom.
Old 05-19-2005, 09:04 AM
The Old Grey Whistle Test
TOGWT's Avatar
Not having seen the surface this is of course only a guess, but it sounds as if 'he' tried to use a polish, as IG will usually clean most things on interior glass.
I would second 1:1 IPA (progressively stronger as necessary) isopropyl alcohol / distilled water
JonM
Old 05-19-2005, 12:47 PM
no tints. i'm just worried the 1:1 solution of alcohol and vinegar might ruin the defroster.
Old 05-19-2005, 04:13 PM
TOGWT's Avatar
The copper wiring of the defroster is encapsulated in a thin layer of glass or acrylic so providing you don’t abrade it with a hard/sharp object you should be all right.
Try 'dabbing' a cloth soaked in the 1:1 solution as opposed to rubbing where there are defroster wires.
JonM
Old 05-20-2005, 03:50 PM
thanks for the info!!! will try it later today when washin the car
MilanoRedDashR
10-02-2015 10:49 AM
LoneRonin
09-28-2015 09:11 AM
Ratheruneeq
09-28-2015 07:41 AM
AcuraKidd
09-25-2015 11:18 PM
4drviper
09-23-2015 07:42 PM
Quick Reply: Is 50/50 water/vinegar solution safe on ..
