FAQ: TSBs, Recalls, and Known Issues
Photography Nerd
FAQ: TSBs, Recalls, and Known Issues *updated 6/12/08*
TSBs
The following are links to pdf files of TSBs issued by Acura that pertain wholly or partly to the TSX. Note that some are recalls, some are product updates, some are warranty extensions, and some are just for the service department's information. You would not necessarily be notified of these TSBs. They are presented here for your information only.
TSB 00-037 : Brake Disk Refinishing Guidelines
Applies to all models
TSB 03-009 : 2004 Acura Paint Codes
Applies to all 2004 models
TSB 03-010 : OBD II DTCs and Their Associated Monitors
Applies to all OBD II equipped models
TSB 03-011 : 2004 TSX TQI and New Model Information
Applies to all 2004 TSX models
TSB 03-012 : Immobilizer System (Type 4)
TSB 03-013 : TL and TSX TQI of the DVD Navigational System with Voice Recognition
Applies to all 2004 & 2005 TSX models with Navi
TSB 03-024 : 2004 Acura Paint Codes
TSB 04-004 : Updating the Honda Interface Module (HIM) Model 3557-0100-00
TSB 04-012 : Product Update - Out of Specification Automatic Transmission Case
Applies to 2004 TSX with VIN in the following range: JH4CL96..4C025689 to JH4CL96..4C028611
TSB 04-021 : Warranty Extension - Audio-HVAC Display is Dim or Dark
TSB 04-024 : Buzzing from the Front Door Panels or Speakers
Applies to 2004 TSX with VIN in the following range: JH4CL9...4C000001 to JH4CL9...4C016871
TSB 04-026 : Safety Recall - TSX Rear Wire Harness
Applies to 2004 TSX with VIN in the following range: JH4CL9...4C000070 to JH4CL9...4C040281
TSB 04-041 : Moisture in the Headlight
TSB 04-042 : Rattle from the A-Pillar
TSB 05-014 : Child Seat Anchor Location Button is Missing
Applies to all 2004-05 TSX models
TSB 05-015 : Rear Stabilizer Link is Broken
TSB 05-018 : Navigation System DVD Information and Inspection
Applies to all 2004-07 TSX models
TSB 05-032 : 2006 Acura Paint Codes, Exterior and Interior Color Code Locations
Applies to all 2006 TSX models
TSB 05-041 : 2006 TSX - TQI of the DVD Navigation System with Voice Recognition
Applies to all 2006 TSX models with Navi
TSB 05-046 : 2006 TSX - TQI and New Model Information
TSB 06-001 : Audio, Navigation, and RES Unit In-Warranty Exchange, and Audio and DVD Player Out-of-Warranty Repair
TSB 06-002 : Front Subframe Removal Adapter
Applies to all 2004-06 TSX models
TSB 06-007 : Right Rear Wheel Camber Out Of Specification
Applies to the following TSX models:
2004 - all
2005 - VIN range from JH4CL9...5C000001 to JH4CL9...5C015076
TSB 06-016 : Trunk Lid Does Not Open
TSB 06-018 : Driver's Seat Squeaks
TSB 06-023 : MIL Comes On With DTC P0116
TSB 06-029 : XM Satellite Radio and Audio Accessories Play at the Same Time
Applies to 2006 TSX models with VIN range from JH4C69...6C000007 to JH4C69...6C025147
TSB 06-034 : Vehicle Pulling or Drifting
TSB 06-042 : 2007 TSX - TQI and New Model Information
Applies to all 2007 TSX models
TSB 06-046 : Tubeless Tire Repair Information
TSB 06-050 : Warranty Extension - Vehicle Warranty Mileage
Applies to all models purchased between April 13, 2002 and November 7, 2006.
TSB 06-053 : 2007 Acura Paint Codes, Exterior and Interior Color Code Locations
TSB 07-007 : Clarification of Acura Unibody Repair Policy
TSB 07-010 : Music Link (For iPod) General Information and Symptom Troubleshooting
Applies to all models with accessory Music Link installed
TSB 07-016 : Product Update - Moisture in Headlight
TSB 07-017 : Safety Recall - Fuel Pump Relay May Cause Engine No-Start or Stalling
Applies to 2005 TSX models with VIN range from JH4CL9...5C018626 to JH4CL9...5C025175
TSB 07-021 : Front Brakes Judder
TSB 07-025 : AC Leak Detection
TSB 07-027 : Updating the AcuraLink Control Unit
Applies to all vehicles with AcuraLink
TSB 07-030 : 2008 TSX - TQI and New Model Information
Applies to all 2008 TSX models
TSB 07-040 : 2008 Acura Paint Codes
Applies to all 2008 models
TSB 07-041 : Brake Pedal is Low and Feels Soft
TSB 07-050 : Service Manual Update:HFL (HandsFreeLink) General Troubleshooting Information
Applies to all 2006-08 models with HandsFreeLink
TSB 07-057 : Low Tire Pressure Indicator Stays On, But All Tire Pressures Are OK
2007 - all
2008 - VIN range from JH4CL9...8C000001 to JH4CL9...8C005018
TSB 07-059 : ATF Leak Detection
Applies to all TSXs with automatic transmissions
TSB 08-011 : Front Door Glass Squeaks When Going Up or Down
Applies to all 2004-08 TSX models
TSB 08-012 : MIL is On With DTC P1172 or P2A00
TSB 08-017 : 2009 TSX - TQI of the DVD Navigation System With Voice Recognition
Applies to all 2009 TSX models
TSB 08-020 : 2009 TSX - TQI and New Model Information
TSB 08-025 : Fuel Fill Door Is Hard To Open
TSB 08-026 : Load Carrying Capacity Reduced Label
Applies to all TSX models
TSB 08-027 : Beverage Holder Lid Will Not Open
TSB 10-025: Power Steering Rack Squeaks
Applies to all 2004-2008 TSX Models
2004 - all
2007 - all
Photography Nerd
Recalls
Tailight Wiring Seal Recall: https://acurazine.com/forums/showthread.php?t=14442
Power Steering Hose Recall: https://acurazine.com/forums/1g-tsx-2004-2008-124/stop-sale-recall-04-08-tsxs-power-steering-hose-leak-773856/
Photography Nerd
Known Issues
"The skinny on the clutch CLICKING and CREAKING problem(s)" by curls: https://acurazine.com/forums/showthread.php?t=33489
Whiskers' "Windshield Noise FAQ": https://acurazine.com/forums/showthread.php?t=20851
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
mugen_kid
11-13-2015 10:38 PM
