Vibration after coilover install
Old 12-01-2012 | 06:55 PM
TLtypeSex's Avatar
So I dropped my car on BWR coilovers today. It rides fine besides minor rubbing. But under acceleration I get a pretty shitty vibration.
I'm thinking axles dues to my car having 90K on it at stock height.
Anyone have any input?
Old 12-01-2012 | 07:26 PM
TWiSDiT's Avatar
Chapter Leader (Mid-Atlantic Region)
How low did u drop?
might be, try raising it up and see if the vibration is still there
Old 12-01-2012 | 07:29 PM
TLtypeSex's Avatar
I dropped it about 2 1/2 in the front then raised it a half inch and it still vibrated.
Old 12-01-2012 | 07:31 PM
TLtypeSex's Avatar
PS I tried searching on here and online in general and never found a good enough answer. My alignment is straight and my wheels are balanced lol
Old 12-01-2012 | 08:25 PM
05_NBP_TL's Avatar
HE>i
Members have had this happen after lowering their cars. Some raised theirs slightly and it reduced the vibrations. I think Rockstar143 replaced his axles and it solved his vibration problems. I do have a slight vibration from 20-25ish mph when acceleration but its not really noticible. I'm also lowered around 2.5 inches on coilovers
Old 12-01-2012 | 09:01 PM
TWiSDiT's Avatar
try raising it up a bit more and see what happens lol
I had the same problem (~76k Miles on oem axles). Found out one of my axles were going bad ( joints had a lot of play ), despite balanced wheels and in spec alignment.
Switched to raxles and raised car about an inch, and no more vibration..
Good luck
Old 12-01-2012 | 10:20 PM
TLtypeSex's Avatar
I think I'm going to change my axles and see what happens. Thanks for the help guys.
Old 12-02-2012 | 05:51 PM
RU_JELLY's Avatar
Redwood Original
dude what the hell you just need an alignment
Old 12-02-2012 | 05:52 PM
RU_JELLY's Avatar
Redwood Original
unless you aligned it after you dropped it.....
Old 12-02-2012 | 08:48 PM
TLtypeSex's Avatar
I actually just raised the front a 1/4 inch and it went away. I posted before that the alignment was good lol.
Old 12-02-2012 | 08:55 PM
TWiSDiT's Avatar
I used to be slammed and never had vibrations
so are you gonna keep it at that height?
1fatcrxnem1
22
06-01-2018 01:23 AM
udelslayer
1G RDX Problems & Fixes
05-06-2016 12:27 PM
BoricuaTL
04-08-2016 01:08 PM
james357
02-13-2016 02:37 PM
thisisnotdave
4G TL Problems & Fixes
09-08-2015 10:02 AM
Quick Reply: Vibration after coilover install
