New Wheel/Tire specs thread with pics
#921
G35 Rims
1.Brand of Rim - Rays - G35 Stocks
2.Rim size (diameter and width) - 19" x 8.5" (SQUARE = BOUGHT 4 REAR RIMS)
3.Offset - 33mm
4.Brand of tire - Michelin Pilot Sport A/S 3 (DOPE ASS TIRES!!!)
5.Tire size - 245/35/19
6.Drop Type and Amount - F&F
7.Do they rub - YES even with slight roll
8. Transmission type (use of spacers if 6MT) - 5MT no spacers
I've always liked the G35 stocks for some reason so I bought 4 rears so they are all 19x8.5 and I got them powdercoated in VOLK MAGNESIUM BLUE.
3.Offset - 33mm
.TODD (07-21-2014)
#922
2008 acura tl s
1.Brand of Rim - XXR 527
2.Rim size (diameter and width) - F 18" x 8.5" R 18" x 9.75"
3.Offset - +20 all around
4.Brand of tire - Nitto Neogen
5.Tire size - F 225/40/18 R 235/40/18
6.Drop Type and Amount - tein street advance about 2.25" all four
7.Do they rub - only fronts while turning on very steep driveways or dips, front fenders were crimped rear are rolled with rear camber.
8. Transmission type - 5AT no spacers Brembo cleared
Last edited by o8 ENVII 8o; 02-10-2014 at 01:51 PM. Reason: wrong brand of rims copy and paste mistake lmao
The following 2 users liked this post by o8 ENVII 8o:
DoomDrummer666 (07-27-2014),
Teo_cleanNlean (03-02-2014)
#925
Multiple Entries but one post!
1.Brand of Rim-Work XD-9
2.Rim size (diameter and width) – 18x10 all around
3.Offset- +18 all around
4.Brand of tire – Hankook forgot model
5.Tire size - 255/35/18 all around
6.Drop Type and Amount – Accuair w/Ksport Bags
7.Do they rub – not at preset ride height
1.Brand Of Rim- Rays Gram Lights 57dr
2. Rime size (diameter and width)- 18x9.5 f and 18x10.5r
3. Offset- +22 all around
4.Brand of Tire- Hankook Ventus v12 evo
5.Tire Size- 225/35/18f 265/35/18r
6.Drop Type and Amount- Accuair w/Ksport Bags
7.Do they Rub- Not at drive height
8.Transmission type- 5AT no spacers
1.Brand of Rim- Work VS-XX
2.Rim Size- 18x9.5f 18x11.5r
3.Offset- +19f and +7r
4. Brand of Tire- Falken 952
5. Tire size- 215/35/18f and 255/35/18r
7. Do they Rub- The rears rub even at drive height, im working on pulling the fenders for more clearance and im changing the rear tires to 245/35 for more clearance. The fronts are fine.
8. Transmission type- 5AT 15mm Spacer in the front
The following 4 users liked this post by Boogerlovers:
#926
Keep in mind that my fronts are rolled and pulled. I went Lower with my Bc.New pic coming later
#931
1.Brand of Rim - SSR Vienna Kreis
2.Rim size (diameter and width) - F 18" x 9" R 18" x 10"
3.Offset - +24 all around
4.Brand of tire - Achielles ATR Sport
5.Tire size - F 215/40/18 R 225/40/18
6.Drop Type and Amount - Extreme low BC's.. Around 23" from ground to fender until I'm on spring break.. then a little lower.
7.Do they rub - only fronts while turning...Fenders rolled quite a bit.
8. Transmission type - 5AT no spacers (for now)
I think this is the first third gen with a set of Vienna Kreis (correct me if I'm wrong). It's different from what is normally put on our cars, but I thought I'd give them a try and I love it!
All shots were from my iPhone, sorry if not up to par!
http://www.flickr.com/photos/michaelwhisker/13136506875/http://www.flickr.com/photos/michaelwhisker/13136801804/http://www.flickr.com/photos/michaelwhisker/13136626043/http://www.flickr.com/photos/michaelwhisker/13136623073/http://www.flickr.com/photos/michaelwhisker/13136803634/
#932
This guy is advertising these Aspec as off of a TL, but I think they're off one of the SUV's.
http://hartford.craigslist.org/pts/4349503275.html
Would 9.5 wide actually fit a TL ?
#933
#934
Received 3,824 Likes
1.Brand of Rim - Volk Racing TE37
2.Rim size (diameter and width) - 19" x 8"
3.Offset - 18 (Using 25mm spacers)
4.Brand of tire - Achilles ATR Sport
5.Tire size - 225/35/19
6.Drop Type and Amount - Tein Street Advance 2.6" drop
7.Do they rub - Rubs fender liner over uneven surfaces
#935
1.Brand of Rim - Fast Wheels Europa
2.Rim size (diameter and width) - 18" x 8.5"
3.Offset - 38
4.Brand of tire - Bridgestone Potanza RFT
5.Tire size - 225/40/18
6.Drop Type and Amount - stock
7.Do they rub - no
3.Offset - 38
7.Do they rub - no
#936
New Lorenzo WL030 Rims
1.Brand of Rim - Lorenzo WL030
2.Rim size (diameter and width) - 20" x 8.5"
3.Offset - 38mm
4.Brand of tire - Ohtsu FP 8000
5.Tire size - 235/30/20
6.Drop Type and Amount - Factory (for now) rear is low because of system weight in trunk
7.Do they rub - No
8. no spacers have hub centric rings 64.1mm to 72.6
3.Offset - 38mm
7.Do they rub - No
#937
1.Brand of Rim - weds cerberus
2.Rim size (diameter and width) - 18x10 in front and 18x11 in rears
4.Brand of tire -
5.Tire size - 225/35/18 front and 245/35/18 rears
6.Drop Type and Amount - idk
7.Do they rub - YEAHHH
8. Transmission type - 6 speed with +15 spacers in front
4.Brand of tire -
#938
04' tl 6 spd
1.Brand of Rim - Volk CE28N
2.Rim size (diameter and width) - 18" x 8.5" FRONT/18" x 9.5" REAR 3.Offset - 30mm FRONT/34mm REAR
4.Brand of tire - COOPER RS-3S
5.Tire size - 235/40/18 FRONT/255/35/18 REAR
6.Drop Type and Amount - KONI SP3 WITH TIEN S-TECH SPRINGS
7.Do they rub - NOPE
8. Transmission type (use of spacers if 6MT) - 6MT no spacers
#939
1.Brand of Rim -(Miro) Powder coated stone Bronze
2.Rim size - 18X9.5
3.Offset - +40 square but added 5MM spacer for the rear.
4.Brand of tire -Goodyear f1 asymmetric 2
5.Tire size -245/40-18
6.Drop Type & Height - TEIN BASIC 2'' drop F/B
7.Do they rub - No rubbing
8.Transmission type - 5AT
[IMG]
[/IMG]
2.Rim size - 18X9.5
[IMG]
[/IMG]
#940
1.Brand of Rim -TSW Bardo
2.Rim size - 19X8
3.Offset - +40
4.Brand of tire -Nexen
5.Tire size -235/35-19
6.Drop Type & Height - H&R F1.4 R1.3
2.Rim size - 19X8
3.Offset - +40
#941
1.Brand of Rim - TSW Interlagos
2.Rim size - 18X9.5
3.Offset - +40
5.Tire size -265/35/18
6.Drop Type & Height - TEIN Street Flex 13" Hub to Fender Gap
7.Do they rub - No rubbing, Slight roll on rear
8.Transmission type - 6MT, no spacers needed, tons of room for Brembos
2.Rim size - 18X9.5
3.Offset - +40
#943
None. Natural camber, 0 toe. I imagine that if I tried to fly into my driveway way too fast, that it may rub, but I'd probably also lose my front bumper too. Basically it doesn't rub under any normal circumstances that you'd encounter on a daily basis, although I haven't tried a four passenger run down a bumpy, twisty back road yet. I'll be sure to report back if it does.
VisualEchos (06-19-2014)
#944
Front wheel turned about 3/4 lock:
Rear:
So yeah, it's very close to rubbing, but just barely clears
#946
1.Brand of wheel - Miro 112
2.Wheel size (diameter and width) - 18 x 9.5
3.Offset - +40
4.Brand of tire - Conti DW
5.Tire size - 255/40
6.Drop Type and Amount - None yet
7.Do they rub - Not that I have found
8. Transmission type - AT
Better pix later.
Elemental. by VisualEchos, on Flickr
Elemental II Desktop by VisualEchos, on Flickr
3.Offset - +40
Better pix later.
#947
As promised, better pix. All in all I love this combo. The rear sits perfectly for what I was wanting, it's only the front that is out because (for whatever reason) Honda chose to make the front wheel gap ½" taller and the negative camber .7 less. Now I just have to figure out how to fix those things .
ATLS_666 (06-24-2014)
#948
wow
Sick.
New entry...Work XC8's are sold and gone!
Now
1.Brand of Rim - Advan RS
2.Rim size (diameter and width) - 18 x 9"
3.Offset - +29
4.Brand of tire - Kumho Ecsta
6.Drop Type and Amount - Tein SS maxed low
8. Transmission type (use of spacers if 6MT) -6MT (no spacers)
Now
3.Offset - +29
#950
[QUOTE=Boogerlovers;14882684]Multiple Entries but one post!
ok I'm trying to put deep dish wheels on my tl but I'm confused on offset do you have negative or positive offset and rowdies (+) or (-) effect your lip on the wheel ?? please help anyone!! thanks
#952
Bakers, the size of the dish or lip is dependent on the offset and width mainly. Some designs, I.e. high disk and low disk can further change these settings but that's probably a little deeper than even the above average wheel buyer needso to know.
1. Stock offset is like 45ish on most cars.
Offset is where the wheel hub sits in relation to the entire rim or barrel. A 0 offset has the hub dead center of the rim or barrel.
A 45 oem offset puts the hub closer to the outside lip losing most of the dish.
Meaning a +25 or 25 offset will have a decent lip over the same wheels with 45 offset.
If you go negative offset you will likely have CRAZY dishes seeing as how even people with 10 or 15 can have pretty large lips.
2. Width. There is only so much lip a 8in wheel can have. Upgrading to a 9in wheel allows for a possible extra 1in lip.
Example. My wheels are 8in wide with 38 offset. The lip is about an inch. If I upgrade those lips to 2 inch lips the offset will go down to about 13 offset with a 9in wide wheel.
Rule of thumb. Lower offset more dish.
The 100% right way to do it is both wider wheels and lower offset. Just be sure you don't go too low and too wide at the same time because the two together can result in a lot of poke... like the tl you quoted on the vsxx.
#953
1.Brand of Rim - Prodrive GC-014i
2.Rim size (diameter and width) - 19x8.5
3.Offset - +43
4.Brand of tire - Bridgestone RE-11
6.Drop Type and Amount - stock type s
7.Do they rub - no rub
3.Offset - +43
#955
2.Rim size - 18X9.5
3.Offset - +40
2.Rim size - 18X9.5
3.Offset - +40
im not usually a fan of the all black wheels with no contrast on cars but this looks tough great wheel design choices looks real dark knight like I also think the black head lights would set it off even nicer nice work
ATLS15 (12-11-2016)
#956
1.Brand of Rim - STR 607
2.Rim size (diameter and width) - F 19" x 8.5" R 19''x10
3.Offset - F 30mm R 35mm
4.Brand of tire - F Pirelli P ZERO R Michelin Pilot Sport A/S 3.very quiet
5.Tire size - F 225/35/19 R235/35/19
6.Drop Type and Amount - STOCK for now
7.Do they rub - NOT at all
#957
3.Offset - 33mm
3.Offset - 33mm
listen to this man THESE ARE THE QUIESTEST SOFTEST TIRES I HAVE EVER OWNED. hard to believe but the ride is better than stock. on 19s HIGHLY RECOMMENDED. PILOTS ALL THE WAY you will not regret it specifically the a/s series
#958
Road Racer / Solo Addict
Rota MXR-R 18x9.5 +38
1.Brand of Rim - Rota MXR-R Hyperblack
2.Rim size (diameter and width) - 18" x 9.5"
3.Offset - 38mm
4.Brand of tire - Dunlop Direzza DZ101
5.Tire size - 245/40/18
6.Drop Type and Amount - Eibach Pro Kit, 1"-1.5" can't recall exactly
7.Do they rub - No, had rolled rear just in case
8. Transmission type (use of spacers if 6MT) - Automatic
Attachment 105647
Attachment 105648
Attachment 105649
3.Offset - 38mm
Attachment 105647
Attachment 105648
Attachment 105649
