V3 ENDLESS J pipe ( Attached high flow )
LINK -----> https://www.endlessrpm.com/endless-e...8-incl-type-s/
EndLessRPM J pipe for all 2004-2008 TL's (Base and TYPE-S)
NOW FULLY IN STOCK!
Have rasp? Need an upgrade? Your stock or aftermarket J pipe hanging too low? Answer is here: Integrated HIGH Flow third cat that is one of the highest tucking long tubed J pipes utilizing stock style crush gaskets and stainless steel.
Features:
* Improved ground clearance over stock an aftermarket pipe
* Less restrictive air flow and replaces the factory restricted j-pipe
* Better exhaust scavenging
* Longer equal length primaries for better low end air flow/hp and torque
*Thick nickle platted flanges
*Uses lap welds which are one of the strongest type of welds known (may not look the prettiest, but being a pipe under the car that gets abuse, lap welds are the best choice for the job).
*Uses OEM style gaskets (crush style gaskets). Unlike flimsy aftermarket gaskets, crush style give one of the best seals. Crush gaskets uncluded in the J pipe kit.
Fitments:
* fits 2004-2008 base
* fits 2007-2008 base and type-s
* fits 2003-2007 honda accord v6
Having Rasp from PCD? Want a "one and done long tubed J pipe" with no rasp in itself and help sold some rasp from PCD? This is it!
Warranty carries all manufacture defects. It does not cover scraping / bends / damage other than manufacture defects.
With equal length runners and ground clearance that tucks higher than the subframe, power and ripping the J pipe off / bending the J pipe is no more of a worrie for TL owners with this EndLess J pipe.
These use crush gaskets, just like the stock does for a long/tight seal.
Mandrel bends, plug and play (no repacing sensors or anything of that sort), equal length runners for max air flow and on presale till they're released.
EndLess ERPM J pipe v3 w/ High-Flow, All 2004-2008 (incl Type-s)
NOW FULLY IN STOCK!
Features:
Fitments:
Joseph Licata (03-02-2020)
nvidiaclocker
02-02-2017 10:10 AM
Lefty2Guns
21
07-22-2014 08:48 AM
Atlas.46
34
02-12-2012 02:21 AM
LastBoyScout
1G TL (1996-1998)
08-08-2008 02:54 AM
