Timing Belt
Team SSM Queen
Timing Belt
My '04 5AT has over 225,000 miles on it. I didn't do the second timing belt/spark plug change because I was planning on buying a TLX in June. Now I see production has been pushed back to August, so I might not be able to get my new car until Sept. or Oct. depending on availability.
I drive 2,500 miles a month. I don't want to put any more money in my car since I'm getting a new one soon. Do you think I'm playing Russian Roulette not changing the timing belt?
KCCO
You could potentially be putting another 15,000 miles on your car before you trade it in. That means you could have 240,000 by that time. 30,000 over the recommended change interval. I think it's a crapshoot. You might be ok, but look at it this way. Spend the money now and you'll have a car to trade in.
If you don't get it done and it lets go, you won't get much for your car for a trade because of the repair bill.
I am still new to the Acura. A friend of mine recently got a Audi A6 and he mentioned that with his car if the timing belt breaks it isn't as simple as replacing the belt. For his car a broken timing belt would mean a broken engine.
With an Acura is this the same also?
Yes I know I am super vague...sorry!
Certain engines with overhead camshafts have timing belts that have a limited lifespan. Car makers use these belts instead of more durable chains because chains are noisier andcost more to manufacture. Your vehicle owner's manual will recommend at what mileage the timing belt must be replaced. These intervals range from every 60,000 miles to every 105,000 miles. To see what is recommended for your engine, click on the link at the bottom of this article.The job of the timing belt is to turn the camshaft(s) at exactly 1/2 the speed of the crankshaft while maintaining a precise alignment. This means that the crankshaft will make two revolutions for every revolution of the camshaft. Engines will have at least one camshaft, or as many as four camshafts in some of the V-type engines. The camshaft causes the intake and exhaust valves to open and close in time with the pistons which move up and down in the cylinders. The valves must open and close at exactly the right time in relationship to the piston movement in order for the engine to run properly.
[QUOTE=justnspace;14993373]any car that runs off a timing belt, which both the acura and his audi have will have catastrophic engine damage if the belt snaps.
/QUOTE]
I do not think that catastrophic applies to 100% of engines using timing belts. There are some that can just freely spin down if the timing belt breaks (non-interference engines). Others, have the potential of crashing valves and pistons if the belt breaks, or even slips a few teeth (interference engines). I believe the TL is a Interference engine so a broken timing belt could be a huge bill/scrap the car.
/QUOTE]
triax37 (05-05-2014)
I think you'll be fine.
Team SSM Queen
aIRpeACE I would love to keep my TL as a second car, but I pay $4,000 a year on insurance and my garage space so it's not practical to have 2 cars.
Drei this is the original transmission and it has never given me any problems. This car has been amazing. I've only changed the timing belt, tires, and fluids in the 10 years I've had this car. I still have the original brakes!
Next time I have my oil changed I'll have them look at the timing belt and see if it looks worn. Thank you all for your feedback!
One other thing to consider is how you plan on selling your TL. If you are intending to sell it privately, service records including recent timing belt service might help to move it or get you a bit more $'s. If you plan on trading it in, the dealer probably won't adjust the price any.
06 Anthracite TL
You'll probably be fine. That said, it is a little like playing Russian roulette, so you can't say you weren't warned if it breaks. As others have said, you might not get much for it in trade in or even if you sell it yourself, but you should disclose to whoever takes it that the TB needs to be done.
Team SSM Queen
93SHOcar I'm going to trade it in. I know I'll get more if I sell it privately, but I don't want to deal with the crazies.
Drei I'd say 90% or more of my driving has been on highways. I do travel in rush hour on some of my trips, so I'm in stop-and-go traffic twice a week.
lol.
BlkTxAcuraTypeS
10-18-2015 08:05 PM
asahrts
09-04-2015 05:55 PM
