Side Marker Lights
The 3G garage has references for this:
http://www.acura-tl.com/forums/showthread.php?t=66329
http://www.acura-tl.com/forums/showthread.php?t=80424
link here
here's a link to someone who has done it before. its more of a diagram, then a DIY.
on another note, i dont recall the manual showing you how to replace the bulb for the sidemarkers? does anyone know the exact steps and what bulbs/led they are? i dont have the manual available right now...
For side marker light replacement, you have to remove the inner fender and front fender fairing, or the trunk side trim panel, then carefully push out the light from behind the fender or trunk.
I don't know the bulb type. All the manual says is 12V 21/5W
thanks again ron a
it may be #19 from the link you sent me last time
http://www.acuraparts247.com/sunnysi...All&vinsrch=no
Originally Posted by cable
thanks again ron a
Team Anthracite #100
I've had my left rear marker light out because it works intermittantly. It appears to ba a sealed unit with l.e.d. bulbs. I'm going in for my "A" service next week. I'll have the dealer take a look at it then. It pops out rather easily once you pull back the trunk liner to get at it.
Originally Posted by Ron A
That's probably it. The manual specifies the same bulb for front turn signal/side marker/parking lights. I'm sure any auto parts store would have little problem identifying the bulb from the specs.
Originally Posted by Tedanddenise
The side markers are made of an LED panel - they will outlast the car (and maybe me).
GÜNnµ ¡Ï
since we are talking about side marker lights. anyone know how to get the rear smoke like the front. i personally think it would look good on my anthracite since its grey. i am talking about the rear ones. they are red.. does anyone sell them in same color as fronts?
Thanks for everyones input. I am totally anal about electronics. Does anyone have step by step instructions of what to do? This information if helpful, but not being an electronics person, I wouldn't even know where to start.
04 TL 6MT NAVI ABP/Q
Hey GunMetal, I know I'm severely late to the party (I'm researching Side Marker mods), but couldnt you just order a set of 2 Front Side Marker Assemblies and then install the new set in the back? Are the units the same size other than color?
I'll try and remember to check my service manual tonight, but feel free to slap me around if you dont hear anything before the weekend is out.
Shift_faster
I would like to replace the amber LED's in the front to a clear LED. I wonder if that is possible. (Just wanted it to match the clear front bulbs.
Shift_faster
WDP Director of R & D
Originally Posted by PoochaKannInc
Thanks a lot. I guess I'll wait until someone finds an easier way (if there is one). I'm a bit leery about using a Dremel on the lens housing. But I guess if it bothers me that much (and its starting to), I might just try it though.
Anyone ever check to see the cost of purchasing the front markers? I would recommend getting a set and experimenting. Once you get them the way you want, swap em out. That way you could always return to stock if need be.
To this day I still like the blue with WDP
Smitty
an Acura has-been
Yes, I was one of the first to do the mod, they are a sealed unit, and pop out by depreasing the tabs on the inside of the fender.
If someone wants to host the photos, PM me your e-mail and I will send them. I had them linked to image station, but for some reason, they do not allow linking anymore.
Units are around $82, so if you disassemble them, you better be carefull. whole unit is replacable in one pc, no disassembly was designed in by Acrua/Honda
It is easy to make them blink. Biggest thing is the time, make your relay circuits first.
Originally Posted by moahdib
Here are need4spd install pics.
Hehe, I wonder how many kilos you could stuff up there :cop:
Thats what i thought, but one of mine (front pass side) has gone out, does this mean it should be replaced under warrenty?
If you haven't done anything related with the LED panel, the dealer should replace it under warranty.
If you've modified it, the dealer may blame that your modification caused the LED to malfunction and void your warranty. If this is the case, it seems like a simple DIY fix.
I know I'm late but you DO have to remove the fender to replace these side marker lights???
Anyway I just did this mod over the weekend and all I had to do was remove three screws and one plastic clip so I could pull the fender liner far enough back to get my hand up in there and pop the lights out. No need to remove the whole liner. This is for the front lights. The backs were much easier.
ninersfgiantsfan (05-26-2012)
sockr1
10-01-2015 01:31 AM
