Rotor set screw help
Old 08-18-2018, 10:22 AM
nealtj's Avatar
Angry Rotor set screw help
So I was recently changing the rotors and brakes on my 2007 TL. All of the rotor set screws were stuck so I used an extractor to get the firs 3 rotors removed. While I was doing the last rotor the extractor broke inside the set screw hole and now I cant remove the last rotor. Anyone know how I can fix this issue?
nealtj is offline
Old 08-18-2018, 10:48 AM
BROlando's Avatar
Received 1,166 Likes on 877 Posts
3 options, usually...
Drill.
Hammer and chisel.
JIS screwdriver bit.
BROlando is offline
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Drill it out and then do not use a set screw when you mount the new rotor. In fact, I threw the freakin' set screws in the trash from both of my cars; they might well aid the manufacturing process, but they are utterly worthless once the car is built and a royal pain in the hind parts when brake-job time comes around.
horseshoez is offline
Old 08-18-2018, 12:40 PM
Received 8,584 Likes on 6,630 Posts
Drill it out
thoiboi is offline
Old 08-18-2018, 12:41 PM
BROlando's Avatar
A small dab of anti seize and a JIS screw driver makes it easier.
But...yeah, I suppose getting rid of them is a viable option as well.
BROlando is offline
Old 08-18-2018, 03:40 PM
3rd Gear
nova46's Avatar
I ran into this issue the other weekend when I was replacing a wheel hub. The tip of my screw driver broke off in the screw head, which took a while to pry out. I ended up buying an impact driver kit, which worked for one screw but ended up stripping out the other one. I decided to drill it out until the head was separated from the neck of the screw and popped it off.
nova46 is offline
Old 08-18-2018, 06:30 PM
WDPanda's Avatar
Spray pb blaster a few times as well
WDPanda is offline
Old 08-19-2018, 07:17 AM
frankjnjr's Avatar
IMO: Probably be difficult to drill through the extractor bit, but you should be able to, using the smallest bit you have available, drill either side, and top and bottom, of the screw, in other words, drill all around the extractor, until the screw is gone. For future reference, an IMPACT screw driver, usually works very well on these screws.
frankjnjr is offline
Old 08-19-2018, 01:22 PM
vpasla1's Avatar
I agree about the impact screwdriver. I had to change my brakes recently and the screws came out without any issue. That's with the Canadian climate and I don't think the rotors had been opened for 6-7 years or so. I do believe there was some antiseize on the screws though so I'm sure that helped.
vpasla1 is offline
Old 08-20-2018, 12:10 AM
champaned_out's Avatar
i just changed my brakes out this weekend and i completely jacked up one of the set screws by not putting enough pressure on the electric impact driver and basically rounded out the screw head
it took me maybe 5 minutes after messing up the set screw to removing the entire rotor off
i switched from my impact driver to my electric drill and used a drill bit that was just smaller than the size of the center of the screw.. i started slowly drilling a pilot hole in the center and within 3 minutes i was able to drill through the screw head then used a flat head and hammer to chisel it in for grip and was able to remove the set screw.. then used 2 M8 x 1.25 bolts and inserted them into the rotors and slowly rotated them one by one until the rotor popped off the hub
r1 e line w/black zinc coating and akebono ultra premium ceramic pads
edit: just saw the part about the drill extractor i must of glossed over that part.. what you should do is try to drill around the extractor.. your main objective is to try to disconnect the screw head from the screw.. once you've weaken the center of the screw, you might be able to try and insert the M8 bolts and break it free from the hub
champaned_out is offline
Old 08-20-2018, 12:22 PM
BROlando's Avatar
An Electric Impact driver is the wrong tool. Especially because nobody uses JIS screwdriver bits. Its not just a phillips head screw.
Unless you have a manual impact screwdriver, you need JIS screwdriver bits.
Impact screwdriver works. Its a manual tool. You literally use it by hitting it with a hammer. They're cheap at harbor freight....like under $10, IIRC. You *can* use a phillips head screw with a manual impact screwdriver because you're just forcing it to conform...with a hammer.
BROlando is offline
Old 08-20-2018, 12:25 PM
Impact screwdriver is what I use.
thoiboi is offline
Old 08-20-2018, 12:26 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
I don't know why it such a big issue for removing these screw, I had to deal with them since my Legend.
I soak them in WD-40 about 20 mins then use the sturdiest Philip screw driver I find and tap it with hammer and drive it out (it will be better if you own an impact screw driver).
truonghthe is offline
Old 08-20-2018, 12:46 PM
Latent car nut
horseshoez's Avatar
He-he, do you live in an area where salt is used on the road surfaces for upwards of six months per year?
Old 08-21-2018, 09:01 AM
truonghthe's Avatar
Yes, my old legend spend 15 years of its life in CT and the Accord spending all its life in CT, the corrosion so bad that I punch a hole through the rear caliper piston (when I tried to rebuilt the seize rear caliper) or the wheel stuck to the hub and I have to use a rubber mallet trying to get it off. Even on my TL-S (spend its entire life in CT) when I first bought I had to do the all rotors and pad with no issue on the rotor screw.
I never had an issue with remove that rotor screw tho, I mean its take extra time out the main job but its not like impossible to remove.
Old 09-04-2018, 08:46 AM
wusty23jd's Avatar
I replaced the brake pads and rotors on my wife's RDX this weekend. I was able to get all four rotor screws out from the rear rotors. The front ones were a different story. It took about three good soaks with PB Blaster, lots of heat with my MAPP torch, and about 30 min each with an impact screwdriver. I was just about to call it quits and drill them out, when all of the sudden one of them slightly broke free. It was like I won the lottery.
wusty23jd is offline
Old 09-04-2018, 10:16 AM
BROlando's Avatar
Y'all really should consider the advice regarding using JIS screwdrivers.
BROlando is offline
Old 09-04-2018, 10:48 AM
My impact screwdriver set came with a JIS bit if it's any consolation
thoiboi is offline
Old 09-04-2018, 05:48 PM
BROlando's Avatar
MASSIVE respekt.
BROlando is offline
Old 09-04-2018, 08:04 PM
DesertMistTL's Avatar
what worked for me was just dremeling a flat line across the head and using a big flathead to turn it.
DesertMistTL is offline
Old 09-06-2018, 11:40 AM
peter6's Avatar
I work as a car mechanic, so dealing with those screws is really common for me.
80% of the time "impact screw driver" works great, just pick anything (I really like Capri Tools one):
Amazon Amazon
Just don't hit it too hard. If you feel like screw is not getting lose:
rest of the time, heating the screw red hot and then using the impact screw driver works
Once, everything failed and screw just stripped off, I needed to drill it out. Real pita, especially after you heated it and made it harder.
Decent drill bits, some oil, and some patience are required for this step.
peter6 is offline
Old 09-06-2018, 01:46 PM
BROlando's Avatar
Heating it red hot??
But there's a wheel bearing behind there....
BROlando is offline
Old 09-06-2018, 02:01 PM
peter6's Avatar
Heat it quick, hit with impact screw driver, cool down with water.
If you aim acetylene at the screw, it will glow within seconds. Rest of the rotor is not getting hot, so I doubt it will hurt the bearing.
And you are throwing out the rotor anyways.
peter6 is offline
Old 09-07-2018, 10:28 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
If you use an impact screwdriver
Spray it down with PB blaster, sit for 20 mins
Tighten on first few impacts
Then loosen
And FFS, don't replace them
You don't need the retention screws to hold the rotor in place
They're added as part of the assembly process
Majofo is offline
Old 09-07-2018, 03:30 PM
BreezyTL's Avatar
I was told by someone they help so the rotors don't warp............ I physically couldn't wrap my head around that idea!
BreezyTL is offline
Old 09-07-2018, 05:24 PM
BROlando's Avatar
Originally Posted by breezytl
i was told by someone they help so the rotors don't warp............ I physically couldn't wrap my head around that idea!
wat?!
BROlando is offline
Old 09-07-2018, 06:11 PM
Latent car nut
horseshoez's Avatar
Utter and complete fertilizer.
Old 09-08-2018, 11:22 PM
thoiboi is offline
Old 09-10-2018, 07:55 PM
1KLRTOY's Avatar
Just drill the heads off and replace the screws with allen flat head screws with anti seize, no more problems.
1KLRTOY is offline
Old 09-11-2018, 11:12 AM
Originally Posted by 1KLRTOY
Just drill the heads off and don't put anything on there because as established, they provide no value whatsoever, no more problems.
Fixed it for you.
thoiboi is offline
The following 3 users liked this post by thoiboi:
BreezyTL (09-11-2018), horseshoez (09-11-2018), Joecop67 (09-11-2018)
Old 09-11-2018, 12:35 PM
Majofo's Avatar
Majofo is offline
Old 09-13-2018, 03:05 PM
djw88's Avatar
there is no need for the screws they were intended for the assembly of the car so no one gets a falling rotor to the head. take them out and trow away.
djw88 is offline
Old 09-13-2018, 03:06 PM
I think this horse is dead
thoiboi is offline
DiaBando
17
07-19-2008 03:43 PM
rockyfeller
05-19-2008 07:59 PM
simean
10-09-2007 01:56 PM
noobiecl
09-28-2004 07:22 AM
TxTLtypeS
08-30-2004 11:45 PM
Quick Reply: Rotor set screw help
