My Venture for A 6mt (Type-S)
#43
Latent car nut
Received 2,005 Likes
The clutch in my car has been exhibiting signs of being tired since I first bought the car last May. So far I've driven it nearly 15,000 miles and don't quite need it yet; that said, I've already purchased a new LUK flywheel, clutch kit, and slave cylinder (which I will remove the check valve from). I have the parts on hand just in case, but hopefully the current clutch will last until the weather gets a bit more spring-like.
#44
sounds good. I noticed today on my commute to work that the third gear seems to "pop out" or at the very least struggles to shift into.
gm synchromesh will probably fix that right?
#45
Latent car nut
That said, make sure it is the ACDelco Synchromesh Friction Modified.
FWIW, my car had a very mild grind going into third and the whole "popping out" issue you've experienced. The ACDelco Synchromesh Friction Modified cured both issues.
#46
is the procedure of using synchromesh the same as the 3x3 drain and fill that is used for the base models' transmission fluid drain and fills?
#48
Latent car nut
No, the 3x3 thing is exclusive to the automatic transmissions. For the 6MT, simply drain the MTF, replace it with the Synchromesh Friction Modified, and then repeat every 30,000 or so miles. The 6MT requires 2.3 quarts of MTF.
#49
Latent car nut
We keep harping on the "Friction Modified" thing because the ACDelco Synchromech product is available with and without the Friction Modified element. The MTF not so endowed has been accidentally purchased by some of our members and it does not perform well.
#56
Latent car nut
okay so this is the one I'm looking at getting:
https://www.amazon.com/gp/product/B0...=ATVPDKIKX0DER
looks like I will need 3 of them in order to have enough for the drain and fill
#57
Latent car nut
#59
Latent car nut
I didn't pump anything out; I opened the drain plug, drained the MTF out, closed the drain plug, opened the fill plug, and filled until overflow.
#61
Latent car nut
Ahhh, I understand now. To the best of my knowledge, all 6MT transmissions used in the V6 models use 2.3 quarts (i.e. 74 ounces).
horseshoez (12-18-2017)
#63
Latent car nut
#65
Latent car nut
rockstar143 (12-18-2017)
#67
okay thanks guys!
going to do this myself as local acura and Honda dealers here want 70 bucks for the job before tax, and I have to supply the fluid LOL
#68
could I get away with just getting 2 bottles?
#71
sounds good. appreciate all the help!
rockstar143 (12-19-2017)
#73
You ruined his jokes.
I ruin jokes. That's my job. Pls don't do that again.
The following 4 users liked this post by BROlando:
#75
#77
Self adjusting clutch, so no need to replace it until it is worn down. You will know when it goes and as long as you are driving it properly there should be no damage done. Basically why fix whats not broken? You could get many years out of the clutch if you drive it properly. If you wanted to launch it from vtech then that might be a different thing...
#78
True that. I have always been a manual driver who will down shift when slowing down, usually to second and then pop it into neutral and apply brake only.
I was not aware that this is not necessary, and that "popping" the vehicle into neutral from any gear and applying solely the brake to slow down is acceptable, unless of course you will be moving the vehicle shortly thereafter. I'm speaking about coming to a complete stop....but yeah I will need to change this driving habit and it will definitely save the clutch life......
Thank god I learned this within the first week of owning and driving this car
#79
Rev-matching in the TL/TL-S is pretty easy too IMO.
As long as engine RPM's match the speed of the gearbox (hence the term rev-match), there are absolutely zero side effects on your gearbox components (clutch, syncros, etc.) from downshifting. It's a more efficient way of driving too.
#80
Yeah, if you have experience driving stick, there's no harm at all and the oem clutch is pretty robust...don't dump it though, go easy on it...like a new girlfriend. It'll last you.
I would look into removing the slave cylinder checkvalve though...I do recall having a bitch of a time taking off smoothly originally even with a lot of years of experience driving manual Hondas.
