Jacking up your TL
Old 01-06-2014, 07:43 PM
8th Gear
jotiefoo's Avatar
Jacking up your TL
Hello guys,
Ever since I found this website which has lots of DIYs, I've been doing small and easy repair jobs for my car. The next job I was going to do was drain/refill transmission fluid as well as replacing gear pressure switch. So I was looking to get myself a floor jack and jack stands. I am a little bit confused on this one.
When I get those, I was going to jack up the center with the floor jack and put the jack stands while they are high and still have the floor jack holding the front of the car. Is this proper way to do it? I'll put a piece of wood behind the rear tires so it blocks the car from moving.
Another question is, where do I put the jack stands? I believe I will have to place them where I would put the scissor stand for any kinds of emergency or is there another spot for jack stands?
I've been reading those horrors stories on failure jacks and I just wanted to make sure before I crawl under the car.
I was looking at Craftsman 2.25 ton jack and stand set for less than $70, and I wonder if these are good.
Please help me guys!
Old 01-06-2014, 08:00 PM
Wow Amaze Such TL-S
Kaiii's Avatar
I just:
1. Pull the parking break
2. Jack up the front
3. Put front jack stands on
4. Jack up the back
5. Put the rear jack stands on
In terms of where the jack stands go, here you go.
https://acurazine.com/forums/3g-tl-2004-2008-93/where-jack-3g-garage-e-028-a-553935/
Check out the garage as there might be some more helpful information as well.
Enjoy!
Old 01-06-2014, 08:09 PM
vietxquangstah's Avatar
I'll make it even easier.
The following 2 users liked this post by vietxquangstah:
Curious3GTL (03-23-2017), mkleisch (02-16-2017)
Old 01-06-2014, 08:14 PM
JTS97Z28's Avatar
^^^all good information. I jack my car up just like kaiii said above. I ONLY jack up from either the front center or rear center. I hate jacking the sides as it always gives me the impression that your twisting the car. It just doesn't seem right doing it that way. When you do it from the front or rear center it keeps the car nicely planted with no body flexing or twisting. Just my personal opinion on doing it. And if you don't think it twists a car by jacking from a single point on the side, jack the car up and look at how all the body panel gaps expand or close. Kinda scary actually lol.
Old 01-06-2014, 09:49 PM
Wow Amaze Such TL-S
Kaiii's Avatar
^yup! my thoughts exactly haha. seeing the panels flex and the gaps open/close freaks me out
Old 01-08-2014, 01:49 AM
dcmodels's Avatar
I also use BLUE practice hockey pucks on both the jack lift point, as well as the jack stands - puck placed on the jack stand top and supports the jack point on the car underbody. This prevents scratching, bending, or otherwise damaging the jack points on the car body. Just be very certain that the pucks cannot slip. They will compress quite a bit, which is why I use the practice pucks - the regular pucks are too hard, and more likely to slip.
The DISCOUNT TIRE place that I visit uses pieces of heavy foam, at the car jack points, to protect the car body, on their floor jacks. Not sure where they get it. And its not like any foam you may be thinking of - its like very heavy black dense foam that barely compresses.
Also, I would use inexpensive Wal-Mart wheel chocks instead of a piece of 2x4 - the chocks are less likely to allow the car to move. Place both in front of and behind one (or both tires), take your foot heel and slam the chocks into place firmly.
When lifting/ jacking from the front, the car will try to move forward, and then as you lower the car onto the jack stands, the car will try to move backward. That is the reason to chock both sides (back/ front) of at least one tire.
UKwrath33 (01-08-2014)
Old 02-06-2017, 10:39 AM
4drturbo's Avatar
Size:  113.7 KB This the proper place to jack the front of my TL up correct? The aluminum/steel piece with the 3 holes. Then jack stands on the support points on the side by the front wheel as posted above?
Old 02-06-2017, 10:41 AM
Received 8,709 Likes on 6,716 Posts
Correct. jack points are the pinch weld points right behind the front tires.
Old 02-06-2017, 12:42 PM
4drturbo's Avatar
I can safely jack it up on that piece with 3 holes correct?
jmichaelp (07-23-2024)
Old 02-06-2017, 12:43 PM
Old 02-06-2017, 01:00 PM
Received 16,265 Likes on 11,974 Posts
how could you not see this 4doorturbo
read; floor jack
Old 02-06-2017, 02:09 PM
GreenSpades's Avatar
That has become my preferred place to jack the car up. I usually jack it up there, put the stands on the sides and let it down on the stands. I once tried leaving the jack there as a back up but it restricts access too much so I just put it off to the side as a backup either at another joint on the frame or even just towards the sides. Better safe than sorry and I always use wheel blocks. I see that overlooked sometimes and it can stop a major accident. My car is getting all messed up right there tho because the jack kind of digs into the metal but whatever it needs the maintenance at over 150,000 miles.
Old 02-06-2017, 02:15 PM
Where else do you jack up?
Old 02-06-2017, 02:16 PM
I use a hydraulic floor jack from Harbor Freight and it doesnt dig into the metal, as it has a "padded cup"
I use the Aluminium light weight jack.
Old 02-07-2017, 03:15 PM
I have the heavy duty steel version that is 3 tons. It weighs about 75lb and I keep it on the basement lol. It is super fun I tell you. I wish id bought the light weight one but I went over kill...
The other jacking points are on the sides and the hook in the rear, which mine is slightly worn from something so I dont use. The sides I will use to rotate tires only, jacking up both on the same side with two jacks.
Old 02-08-2017, 11:39 AM
4drturbo's Avatar
read; floor jack
Yeah I saw that, I was just making sure. The generic picture looked a bit different plus it looks to be a aluminum piece. But then I saw the arrow underneath my car and I knew it was correct/ Never jacked a vehicle from the front like that before. It worked perfect. I wish all cars could be jacked directly in the front like that. I am just super cautious working on a different car for the first time is all. Thanks again for the confirmation people!
Now there is a picture to help special people like me that google search :P
justnspace (02-08-2017)
Old 02-08-2017, 11:44 AM
I bought the same steel jack!!!
but after doing a little work with it, I SOLD THAT BISH!! lol
Old 02-08-2017, 11:59 AM
Where do you usually jack up your car..?
Old 03-23-2017, 12:07 PM
Hazsun's Avatar
which aluminum jack did you buy? is it the 1.5 ton or 2 ton one? I'm looking to upgrade to a low profile jack and not sure which one to get.
Old 03-23-2017, 02:09 PM
Jackass's Avatar
I have yet to use the front or rear jacking point. Out of habit, I do the same process I have done on all of my uni-body cars prior. Jack up on the side lifting points, and place the jack stand under the mount point for the suspension or somewhere else "solid" nearby. Several of my prior cars did not have valid front/rear lifting points so I have always used the side locations. I think I tried the rear center on the TL once before, but my poor little jack wasn't tall enough to lift the tires off the ground.
Old 03-23-2017, 02:46 PM
peter6's Avatar
What about min/max height of the jack and jack stands? There is a pair of Torin Jacks on Amazon for $20. Min height is 10 inch, max 16. Will it be enough? What about Jack itself?
I'm asking as it will be my first time working with Jack. No access to the shop no more
Old 03-23-2017, 09:24 PM
I had a $20 auto zone jack I used for years and years. It was similar to what youre talking about 10"-16" range. In that price range they are generally all the same. Anyways it was good enough for my cavalier and the little rx7, and surprisingly I was even able to use it on a 2000 accord sedan. But when it came to the TL it didnt have enough height or strength. I would skip it and just spend the money on a decent one right off the bat. I still have it as a back up tho, always good to have an extra jack for safety.
Old 03-24-2017, 10:07 AM
Jackass's Avatar
I have one of the cheesy Wal-Mart special jack and stand kits that I have had for probably close to 20 years. It has served me well on my previous cars but without a doubt has limitations mostly related to the lift height. I would never recommend anyone going out to buy one of these to use on a TL. If you are planning on doing work yourself, get a proper sized jack and stands. If it is just to change/rotate your tires, the cheap will be fine. But if planning on doing other maintenance tasks, go big or go home. When my brother downsized from his house, he gave me his much nicer Craftsman high-lift jack. Much heavier, but sooooooo much nicer to use. The only time the smaller jack ever comes out now is when I must travel with it to help a friend. The Craftsman is far from portable.
This is similar to what I have:
Sorry for the image size...no idea how to resize on here.
Old 03-26-2017, 01:53 AM
Late to the 3G Party
mb.3g's Avatar
I just beefed up my own setup today and stumbled on a great deal harbor freight is having on low-pro 3 ton jacks. Cant beat em for $94. Solid too.
http://m.harborfreight.com/3-ton-low-profile-steel-heavy-duty-floor-jack-with-rapid-pump-61253.html?utm_referrer=direct%2Fnot%20provided
Old 03-27-2017, 06:05 AM
NetGnome's Avatar
Hockey pucks
I use hockey pucks on my Jack to protect the frame.
Old 03-27-2017, 08:04 PM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
read; floor jack
Don't listen to this guy on jack lesson, he is jack of all f*ck up master of redo.
Back to the topic tho, I did use both of the front and back jack point without issues just MAKE SURE you have floor jack support the car while its up.
Old 03-27-2017, 09:33 PM
sockr1's Avatar
Received 1,159 Likes on 909 Posts
3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump®
get the two ton one, it goes lower and much higher than the 3 ton one. It's about 155 I think right now at harbor freight
i need every inch to get under my car but I also need the taller height to work on my mdx
Old 03-28-2017, 11:51 AM
6spd-GERCO's Avatar
I have the same one and it works great for both low and tall vehicles!
Old 04-01-2017, 06:39 PM
Gamecock93's Avatar
That has become my preferred place to jack the car up. I usually jack it up there, put the stands on the sides and let it down on the stands..
This. I just my wife's up for the first time today in the middle and then put jack stands on the sides. I took the front wheels off and used a drill with wire bushes to remove rust on the calipers and on parts of the rotors. EZ Cheese Z.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
SUPRMN84
10-07-2015 09:46 PM
navtool.com
09-25-2015 05:15 PM
Quick Reply: Jacking up your TL
