If upgraded from 04-06 to 07-08 3G, do fog lights make night vision brighter?
Quick question
If any of you have sat in both or owned one than the other,
Do the fog lights in the 07-08 make a big difference in night time driving?
I like my HIDs but think it's too dark at night, I'm hitting potholes all the time cause I don't see them early enough.
Rev High; Drive Happy
I'm surprised you are having issues seeing at night with the bi-xenons.
Lower fogs help a little... but it's nothing too dramatic. At least judging from other cars with halogen fogs. Your bi-xenon 'over power' the fogs anyway.
Why don't you try to get brighter bulbs for the integrated fogs?
Getting something such as the Nokya 2500K bulbs help visibility and show signs better--at least so I've noticed.
Or... you can just get Hella fogs or do a retrofit in the lower fogs.
That would help a lot more than stock-halogen-fogs.
Area on my XM
I haven't driven a 07-08 model, but the 04-06 fogs intregrated in the headlamp housing put out excellent light that complement the xenons quite nicely. I replaced my stock bulbs with Nokya yellows, which made even a bigger difference. If you are having issues seeing what is ahead of you at night, you are not alone. The cutoff was way too short for me, and I was only able to see about 100 feet ahead of me. I ended up aiming my headlamps up quite a bit to where I can now see about 300 feet ahead of me. The additional light from the fog lamps brighten up the side of the roads enough to where I can see at least 10 feet clearly side to side for about 50 feet ahead of me.
Make note that I drive a lot of rural roads, and this set up has worked out well. I must have hit the sweet spot on my headlight aim, since my normal beams have yet to be mistaken for high beams by oncoming traffic. I made this adjustment last winter.
From my experience with lower placed fog lights, the light output from OEM units have been minimal at best. My wife's Mazda3 with HID headlamps completely drowns out the light from her fogs like they aren't even on. My Miatas had low-placed fog lights, and I experienced the same results even with standard halogens. Perhaps this is a normal trend with Mazdas, I don't know.
Try changing out the fog bulbs with yellow ones and see if you notice any difference. At the very least, it will look nice.
I have 07-08 lower fogs w/ 4300K HID kit on my 05. The 04-06 fogs, and 07-08 fogs are each wired independently so I can turn them on whenever without the bi-xenons.
The 04-06 directs the light output with a cut off, the 07-08 scatters the light somewhat without a cut off. The only thing better about the 07-08 is that the light is directed more to the sides. The 07-08 does widen the visibility.
It would be best to use a projector for the lower 07-08 fogs. At the price Acura sells the fog housing for, you think they use a projector lol.
I need a car in
1 Post
i currently love my set up with alot of lights
i have the accord fogs which shoot to the sides.
the oem fog which shoot to the ground
and the lower beam shoot normally.
all of them have a hid kit. the stock low beam has a 8k bulb. the stock fog has 3k bulbs, the accord lower has 8k.
Quick question
Stay Out Of the Left Lane
Received 1,236 Likes
I'm Craig
But fogs+xenons in the dark on back roads=awesome.
the fogs help somewhat ... but like others have said try adjusting your lights, that will probably solve your issue and be much more effective compared to adding on fog lights in the lower part of the bumper
This thread has been great.
First I learned that I can turn on my "fog lights" which I never knew existed
ohhhh mannn
I just got the car about 6 weeks ago, so dang!!! this is great news.
I wanted it to be brighter, because compared to my friend's super bright oem '01 Lexus RX300 'regular' lamps, it was a lot dimmer
I turned on the "fog" lights today, and though they're yellow and take away from the mystic beautiful white exuding from the xenons in 'normal' mode, they do add a touch of brightness that makes the view good enough for me.
I may do the additions you guys did on your cars, depending on cost, and etc.
Thanks for the help everyone.
ohhhh mannn
The lights in my car must've been adjusted previously because I too drive on a lot of rural roads and visibility is GREAT. However, oncoming traffic flash their brights at me fairly often. I flash mine back to let them know my brights aren't on, but still. Seems like you have to be very careful when adjusting the headlights so you're courteous to other drivers.
Or is there an adjustor for the brightness? Please elaborate
Former Sponsor
The OEM Osram HID bulbs are worth sh*t in my opinion. If you want brighter then upgrade to Philips 85122+ bulbs. Old Osrams are probably producing around 2800 lumens, new Philips 85122+ would produce around 3400 lumens each, compare that to a standard halogen bulb which produces 1100 lumens. So basically upgrading to the Philips would yield you total light output comparable to having one extra halogen bulb in the front.
I'm Craig
Yes, adjusted as in the angle. Mine might be a bit too high up based on the number of people who flash their brights at me but then again the 3G TL's xenons are very bright to begin with.
Thanks -
06 WDP/Ebony MT NAV ASPEC
Former Sponsor
The best way to get more light is to upgrade the HID bulb, as stated in my above post the Philips put the Osrams to shame and you would only know that once you have used the Philips.
Here is a short video showing light output at night, its HD and the camera is pretty good at showing ACTUAL light.
http://www.youtube.com/watch?v=5FL61bcfVmk
Wow how can anyone think the TL's lights aren't bright enough? I've had people flash their lights at me because they think I had my high beams on even though I didn't.
Yeah all i did was put the screw driver in the hole and just point them up a little more to project more and i was surprised at how much more i could see. i thought something was wrong with my headlights
For the 04-06 USDM TLs the lamps adjacent to the projectors are most commonly known as fogs but indeed they are auxiliary low beams. They enhance the low beam by throwing light towards the corners to give you a wider range of light. I personally use Sylvania Ultra Silverstars in my headlights.
So assuming I was going to upgrade my HIDs as you suggest, where is a good place to get them. Do you have any opinions of the Nokya bulb fog light upgrade?
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
