Hi everyone just wanted some new owner tips
Old 03-30-2019, 03:03 AM
ChocoboRacerQC's Avatar
I currently drive an 04 tl base model 5s automatic and having restored some features her previous owner neglected i was hoping for few tips or what tipe of handling to expect, front suspension was redone with air intake, radiator as well as 2 front engine mount replaced oil change and other including parts to reservice accompanying what I re did to her, she has 189k km on Odom and honda service tech says transmission A1 after trying car, also brakes redone too, i Beleive in only needing a soon service of timing belt and re alignment and i think I've done all she needs, so what should I expect from here out?
Old 03-30-2019, 09:15 AM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum.
Old 03-31-2019, 12:30 PM
Jackass's Avatar
1.) Wow...that is one heck of a long sentence.
2.) Not exactly sure what all was said here. What does the front suspension have to do with the air intake?
3.) The transmission is throwing a code? Or it is ok?
4.) Two front engine mounts? I thought we only had 3 engine mounts total...front, back, and side?
There really is only a couple of somewhat common "issues" for these cars:
1.) Dash cracks...nothing you can do. When its time, its time. Some people have cracked at 5 years, others at 10+ with no cracks yet. Mine held out for 12'ish years.
2.) Auto transmissions - just keep up on fluid and replace the pressure switches
3.) LCA bushings - just inspect and replace if torn
4.) HFL module fails and drains battery
I think those are the more common issues.
Old 03-31-2019, 10:16 PM
PhilB81's Avatar
^^^ what he said, only other thing I had to do on mine was to replace the driveshafts because of vibration under throttle.
also, my drive by wire pedal position was starting to go, so I replaced it, but I don't think that's a common issue. I just felt that occasionally pressing the pedal just a little did nothing or too much, which made smooth starts with the manual tricky.
Old 04-02-2019, 09:57 AM
LoveMyTL-S's Avatar
If your battery is draining (after sitting a few days), it's either the HFL module fails and drains battery or A/C relay ($6.00 part). I unhooked the HFL and replaced the relay. A/C fans blows harder now.
Congrats on the new to you TL and welcome to AZ!!
pzhoward
11-22-2010 06:10 PM
98tlracer
11-18-2004 08:17 PM
StreetEffectz
08-20-2002 09:17 PM
Austin519
06-24-2002 08:30 AM
Quick Reply: Hi everyone just wanted some new owner tips
