Has anyone had their foreground cutoff shields trimmed or removed? Do you like it?
When I first got my TL, I was bothered by how the projectors didn't light the ground directly in front of the car. Turning the fog lights on helps a little, but I was wondering if anyone has had their foreground shields modified or removed and if you liked it or regretted the decision. Was there anything you didn't like after the modification?
I actually like the foreground limiter. It makes our projectors stand out from others, and it improves visibility in the far distance. If you don't sit too high in the driver's seat you won't even see it, or if you have HID foglights
robocam (05-01-2014)
How does it make our projectors stand out? If you don't see it, then it shouldn't affect your visibility right? =) When a BMW drives down the road, the ground is so bright. It has a commanding presence, but that's not the reason I'm interested in this mod. I just don't want to see that line in front of my car. It's like a black hole. It's not nearly as bad as when I drive around with H4656s, but I'd still like that gap filled.
Also, I'm not having my headlights opened up only for this mod. I just figured that since they're already opened, I'd get that taken care of.
Land of 10,000 lakes
It's been done before, but most likely not by anyone on Acurazine.
http://www.hidplanet.com/forums/showthread.php?4202-My-TL-shield-and-color-mods-**PDF**
How does it not make it stand out? It's pretty obvious it's there (to everyone except the driver). I still see it a little when driving, just barely the edge of it though. Why do you want to light up the foreground anyways? It's an illusion to make you think a projector gives you good visibility. I have no problem outshining bmws all day with my setup
[x] FWCC [x]
Are you saying our headlights' beam pattern looks special because the lower cutoff is farther away?
I want to light up a few more feet of the foreground because I like it that way. It shouldn't harm visibility because like you said, you can barely see the line, so basically, what I'd be seeing after the mod would be what you're seeing already =)
I retrofitted RL projectors into another vehicle, and they don't have a foreground shield, and I absolutely love their output.
I'm not sure if you have a clear lens on your projector or not, but if you do, the foreground limiter line gets sharper too
Actually I am thinking about getting those ZKW replicas. Is there anything you don't like about the clear lenses? Does it just make the cutoff sharper, or is it any brighter or wider?
robocam (05-03-2014)
The following 2 users liked this post by rockstar143:
Acura_Dude (05-03-2014),
Just in case anyone's wondering what I'm talking about, here's that line I'm trying to take care of. Thanks for the video rockstar
https://www.youtube.com/watch?v=DQbDol9JsBQ#t=0m20s
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
