Gumout Multi-System Tune-Up?
Old 07-05-2014, 11:00 AM
jaredb03's Avatar
Anyone tried Gumout Multi-System Tune-Up? Its Gumouts attempt at seafoam and AAP had it for free last month. I picked some up since it was free but now im a little nervous about using it. If anyone has used it can you post your results/experience with it.
Old 07-05-2014, 07:15 PM
jaredb03's Avatar
So i went ahead and tried it. I put 5oz in the vacuum hose on top of the intake and it smoked a lot after i let it sit just like the seafoam does. Seems to be a little smoother idle and maybe a little more responsive but hard to tell since it wasn't running bad to begin with. I also put about 6oz in the Gas tank and will be putting 5oz in the oil tomorrow and drive it around for few miles then changing out the oil as its due.
Old 07-06-2014, 05:45 AM
Turbonut's Avatar
Sorry but IMHO waste of money and time.
Old 07-06-2014, 11:53 AM
pohljm's Avatar
In this case just time
Old 07-07-2014, 06:27 AM
Turbonut's Avatar
Old 07-07-2014, 02:59 PM
flyromeo3's Avatar
unless you've never ever ever ever changed your oil. I can see how this may work.
Even then, removing all that built up gunk could lead to other problems down the road.
I'd stay away from that stuff.
Old 07-07-2014, 03:38 PM
Received 16,260 Likes on 11,971 Posts
couple hours into my tear down process, yesterday.
71k miles and she's clean. VERY clean. doesnt need any kind of "cleaner" including seafoam and the gumout
Old 07-07-2014, 04:16 PM
JoshD_99EM1's Avatar
I disagree. It's all preventative maintainence. IT certainly doesn't hurt anything running it through the car every once in a while. And granted it may not do too much, if there's just a little bit of stuff built up itll take care of the carbon build up before it can become a problem. I generally use Lucas fuel stabilizer/cleaner once every other month, and seafoam once every 50k in both my cars.
Old 07-07-2014, 06:09 PM
Turbonut's Avatar
Now that's a waste of time and money. It does nothing and if you didn't use it you wouldn't notice any difference. Ever think what happens to the other two hundred million drivers that choose not to use the stuff and have no problems? Try to abstain and you'll have more money in your pocket.
Old 07-08-2014, 09:02 AM
Notice anything different, you are probably right.. and there are millions of drivers that dont, and have no problems yes. Im can say though that 6 dollars every other month doesnt hurt my wallet to badly haha.
However, to say that seafoam does nothing is not true.
Old 07-08-2014, 09:08 AM
^i dunno, my picture proves that you dont need ANYTHING other than oil changes according to the MID.
in my picture, there is no gunk and it looks brand new.
Old 07-08-2014, 09:50 AM
Im not disputing that. Your motor looks immaculate.
My only point was that it doesn't hurt anything to run a fuel injector cleaner thru it once in a while... it may not help, but it can't hurt.
Ill just leave it at that. :thumb up:
justnspace (07-08-2014)
Old 07-08-2014, 12:42 PM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Redline SI-1 ftw.
I put it in from time to time because sometimes I can't get good gas from places like Chevron/Shell depending where I go. I have to fill up at like Sams/Costco/Valero at times when they're closer. Only thing I put in my car besides your typical stuff.
I did Seafoam once and my engine had a bent rod a day later. :X Coincidence maybe
Old 07-08-2014, 01:01 PM
^whut!?
you're an automatic! you cant bend rods unless it was over heated or you went through some water.
the only reason why I'm pulling my heads is because a friend over-revved my car.
some valves are bent.
Old 07-08-2014, 01:30 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
I get what you are saying but you don't know if it works or not..........so why even bother
Old 07-08-2014, 01:34 PM
Why not?
Old 07-08-2014, 01:37 PM
^i like this guy!
JoshD_99EM1 (07-08-2014)
Old 07-08-2014, 01:42 PM
hahaha
Old 07-08-2014, 04:09 PM
nttstt444's Avatar
Personally I dont believe in any of those fix it all in a can vehicle additives. Iv never seen them improve anything or fix an existing problem of any kind. No to say they dont work, maybe they do? Iv just never seen it.
EvilVirus (07-08-2014)
Old 07-09-2014, 12:37 PM
Security Dude
Sbarbee54's Avatar
I use them in all my cars, if something might help prevent a issue, or even just gives me piece of mind it is worth 10-20$ every other month for me. Heck in my 07 F250 Diesel I run Opti Lube additive in every tank of fuel and rev x oil additive in every oil change. Better be safe than sorry....Right?
Old 07-09-2014, 12:41 PM
losiglow's Avatar
^ This for me as well.
I've used Seafoam a dozen times on various vehicles with no noticeable change in idle, power or gas mileage. It's possible that there was no problem to begin with but if I'm not seeing a difference I'm not going to spend the money.
Old 07-09-2014, 01:09 PM
Youre not going to see a difference cleaning an already clean motor lol. If you are keeping up on your maintainence, it is not going to show a drastic improvement.
Its like sweeping up an already mopped floor. Youre not going to get any dirt, but does that mean the broom is useless? No.
Im not trying to persuade anyone in any given direction. I use it primarily for ease of mind, and quite frankly I get them for a stupid cheap cost, so why not.. And like Ill say 1000 more times.. its not hurting anything!
Old 07-09-2014, 05:05 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
These products work only when you are having trouble with your car, and in all honesty the TL doesn't have much engine trouble.
I'd recommend it only for the sheer fact that I know they work to help a bumpy idle, dirty fuel injector, etc from using it on troublesome cars and having them fixed after using it.
As another member put it, it's like moping your floor. There's only so much cleaning you can do. Using it Every oil change works for most folks and gives them piece of mind.
Old 07-23-2014, 01:40 AM
sopmodm14's Avatar
some additives are snake oil, but hopefully they won't do anything detrimental to the engine
it can't hurt but help i suppose
Old 07-23-2014, 10:46 PM
Slot Machine Lubricator
1black_seven's Avatar
I have read on other forums that these products are corrosive. But I haven't done any any research.
Old 07-24-2014, 08:15 AM
Corrosive? How so?
Never heard of that myself
Old 07-24-2014, 10:44 AM
flyromeo3's Avatar
my concern would be a large piece of gunk becoming dislodged and getting stuck in one of the oil passages
EvilVirus (07-24-2014)
Old 07-24-2014, 10:45 AM
flyromeo3's Avatar
that's a nice clean head you have there lol
Old 07-24-2014, 10:51 AM
Said the actress to the bishop
Old 07-24-2014, 11:51 AM
Security Dude
Sbarbee54's Avatar
I dont see something big enough dislodging that would not be broken down by these fuel treatments. I mean things can happen, but I dont see this. Just like when the Mayan calendar ran out the world was to end, I did not see that happening either.
Old 11-23-2017, 10:25 AM
6th Gear
bpenn627's Avatar
It works
I work at an auto parts store selling seafoam all the time. I've had a customer tell me he had a clogged catylitic converter that was throwing a check engine light. He put 2 cans in a quarter tank of gas and ran it through and it cleared his check engine light. He eventually had to change the converter though but he said the seafoam cleaned it enough to get another year out of it
Old 11-23-2017, 11:14 AM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Seafoam = Huile de Serpent
Sideswipe
2G CL Problems & Fixes
07-25-2007 08:05 AM
dschwar1
04-25-2007 08:05 PM
asianmoomoo
07-12-2006 06:16 PM
Euliscool
09-16-2004 03:03 PM
BlackShadow
02-11-2004 11:28 AM
Quick Reply: Gumout Multi-System Tune-Up?
