G-100: DIY LED Interior Conversion, Part V: Cluster Console (EASIEST OF THE BUNCH!)
Fearless DIY Guy
Ok, now, just to let you guys know, if you're apprehensive about this whole 'LED Thing', well, have no fear...this is where to start. This is seriously easy. Like Geico easy.
Thanks go to dwb993 for specifying the exact bulb to use.
LET'S GO!
TOOLS NEEDED
Flat head screwdriver
MATERIALS
4 x 3mm bulb to your liking...I am used wide-angle flat headed 3mm bulbs
Solder
FLUX, I CANNOT STRESS THIS ENOUGH
4 x 560-ohm resistors
TIME
Plug-and-play method - 30minutes
STEP I - NO TOOLS NEEDED
My God, this is so easy it's insane. Lower your steering column all the way, grab from the bottom, and pull up. You suck at life if you can't do this. Seriously.
STEP II - POP GOES THE...
Pop four out, modify, and put 'em in. Yep, that friggin' simple. Follow the link above for how to prep the bayonet bases, and you're done. As always, I've made this niiiice and simple for you by noting the polarity of the bulbs...so seriously...what are ya waitin' for?!
LET'S GO!
TOOLS NEEDED
MATERIALS
Solder
TIME
Libusa (11-18-2012)
Fearless DIY Guy
Lemme know if you have any questions! GL!
Mistuh DRiiVA
finally got around to doing this mod, by far the easiest mod of the bunch. im going to work on the seat heater bulbs today and attempt the door handle ones like your other thread.
^Bulbs are burnt out. Mine on the left side are as well.
Fearless DIY Guy
Hey, if you get the chance, can you snap some pics of the switch when you have it open? I want to see what type of LEDs the amber indicator light is, although I have strong suspicion they are PLCC-2s...
Mistuh DRiiVA
this one is definitly the easiest of them all and it really looks nice when its done. i did all 4 blur first then proceeded with my LED conversion and then saw myself using alot of blue and white combos like deathmetal is doing and ended up redoing this with two white bulbs on top and two blue on the bottom. This look went great with my steering wheel LEDs being white for the cruise and mode button and the rest of the wheel being blue. i shoulda just taken deathmetals advice in the first place on this one lol
Fearless DIY Guy
UPDATE: NOTE FOR THOSE USING WHITE LEDS
I hate to bump all of the threads, but there is an important item that needs to be noted; some of the white LEDs have been burning out, which can be attributed to one thing and one thing only: thermal overload. Therefore,
IT IS HIGHLY RECOMMENDED THAT A 1K-OHM RESISTOR BE USED FOR ALL WHITE LEDS.
I have begun the process of replacing LEDs/resistors for the dearly-departed and can state that the new resistors seem to do the trick.
Mistuh DRiiVA
yeah im going to upgrade the resistors when they burn out. i really dont feel like opening up everything again right now. but its good to know that theres a fix for this myserious white LED problem.
Fearless DIY Guy
Pics are not loading
I know you posted pics but none of them show. Any other link where I can follow these directions with pics? Ive tried different browsers and a different computer. No luck.
Fearless DIY Guy
I'm closing on a new house in 3 weeks, I don't even know when the hell I could get around to this
handsom-hustla
11-13-2015 05:04 PM
