DIY LED Vanity Lights 04-08 TL
Old 11-14-2013, 01:36 AM
BxTrini_TL's Avatar
This was pretty easy, took me like 10 mins tops. Pretty simple all I used was a flathead screwdriver. Hope this helps some of you guys.
Vanity Lights
You will see where the flathead should go
There is a lil tab you will push then slowly pry down the cover. Note* Dont pry too hard you could break it.
Get the cover out
Remove light from harness by pressing tab and pulling
Theres a little cover you will take out.. Very easy to come out with the flathead
My bulb released very easy. Some may be hard to come out, use flathead to take it out. Be careful not to break bulb in there
Install LED bulb. Dont forget the little clear cover! Then put light back in same way it came out
And your all set.. I did LED conversion to the whole car, very bright, im very happy with them.
Hope this helps. Good Luck!
Ride It Low (11-14-2013)
Old 11-14-2013, 01:46 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
i didnt need to take off the clear cover when i did mine. just use pliers to pull the bulb out
BxTrini_TL (11-14-2013)
Old 11-14-2013, 09:10 AM
My first ricer
350's Avatar
Yeah I don't recall taking anything apart and the bulbs I put in look identical, plenty bright for that application. Does anyone else think it's stupid that the light isn't next to the mirror? When you flip the cover up it blocks most of the light... every other car I had the lights are on each side of the mirror.
BxTrini_TL (11-15-2013)
Old 11-14-2013, 09:30 AM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Unless you are putting on make up on; I never use the sunvisor mirror.
Old 11-14-2013, 07:21 PM
LoveMyTL-S's Avatar
Have to agree. Why is the light shining down which causes shadows, instead of having a light shine directly into your face?
LoveMyTL-S's Avatar
To the OP, nice write up and pics. I was wondering how to pop those covers off.
Old 11-14-2013, 08:49 PM
d4rkv's Avatar
Please, use some gloves next time (light bulbs), nice write up though.
Old 11-14-2013, 08:54 PM
Ride It Low's Avatar
Thank you. will be doing this this weekend.
Old 11-14-2013, 10:21 PM
Cubsfan2154's Avatar
What is there size? and where did you buy them from?
Old 11-14-2013, 10:37 PM
Noober's Avatar
easier to take out the stock bulbs by using some tape.
Old 11-14-2013, 11:03 PM
BxTrini_TL's Avatar
The bulbs are 2825
The 2825, 168, and 194 are all the same size with different wattage
I got them from ebay.
Old 11-15-2013, 01:17 PM
2013 TL SH-AWD TECH 6MT
just1nsama's Avatar
I just pulled on the bulb ... i dont see why you are removing that plastic thingy .. anyway, good job on DIY, nice pics.
BxTrini_TL (11-20-2013)
Old 11-20-2013, 03:40 AM
BxTrini_TL's Avatar
Thanks bro. I pulled out the plastic cover because for some people the bulbs are hard to come out and to avoid breaking the bulb they should take that out.
Old 12-29-2013, 07:54 AM
0007Type-S's Avatar
Thanks definitely doing mine tomorrow.
cycdaniel
12-17-2019 10:58 AM
oyayjoe
01-01-2019 10:17 PM
acura_dipset_tl
01-01-2016 03:02 PM
oyayjoe
09-12-2015 04:40 PM
drewdeezy03
09-03-2015 08:04 PM
Quick Reply: DIY LED Vanity Lights 04-08 TL
