Anyone know how to replace cabin filter in an 04 TL
9th Gear
I searched and found some stuff the the describtion and pictures are for the previous body TL 1999-2003 which I had in the past and have changed it, pretty easy if you see detailed instructions.
Anyone have a link to a sit ethat show a "how to" or can give me some tips?
it's me, Alan Rickman.
Wrong forum; but.. You have to remove the glove box. I *think* 06+ [or maybe 05+] has an easy access panel behind the glove box itself; for the 04 you have to remove the entire assembly.
Thread moved. There is alot of good info in the 3G Garage:
https://acurazine.com/forums/showthread.php?t=131831
https://acurazine.com/forums/ramblings-12/firewall-help-123884/
Fleshy is correct you have to remove the glove box. My 05 does not have the easy access panel. Its really pretty simple. Just a word of advise. Once you remove the cover I would make a cut out so you do not have to keep removing the cover everytime you replace your cabin filter. I used a dremel.
rockyboy
01-25-2016 06:00 PM
nanos
11-12-2015 08:41 PM
Skirmich
09-15-2015 06:41 PM
