2008 Acura TL AT - Brake/Rotor Replacement Questions
Looking to sell my car once I make the drive from LA to SF (moving for work). Over the past 6 months I've noticed significant vibrations when breaking at higher speeds. I'm assuming my rotors are warped. I was thinking of getting a full front and rear brake/rotor replacement before the drive to SF and also before I sell it (assuming I would get dinged on buyout price given this issue is super noticeable when driving at any speed). Any recommendations on which brakes and rotors to buy that wouldn't cost me a fortune? Anyone in LA know of a good shop to take my car to? Hoping you all have some recs handy. Thanks!
Some simple StopTechs would suit your needs. Do you know how to do them yourself? It will save you at least another $200-$250 depending on shop fees.
https://www.endlessrpm.com/stoptech-...-tl-automatic/
that is not his website and yes stoptech is a reputable brand.
if your selling the car, go through rockauto and save yourself a bunch of money.
Latent car nut
Received 2,005 Likes
Agreed, go the RockAuto.com route and save a bunch of money; semi-metallic pads can be had for about $13 and a set of rotors can be had for about $32. Do the work yourself and the entire front end brake job will cost you less than $60 (including shipping charges and other incidentals).
Appreciate your suggestion. Should I only do my front end brakes or should I do front and rear? I think on rockauto I can buy the complete set for ~$100 + whatever the labor would cost.
Would this be the right set? https://www.rockauto.com/en/moreinfo...40497&jsn=1050
Latent car nut
Don't muck around with ceramic pads, even cheap semi-metallic pads will have better initial bite than most high dollar ceramics. As for cheap ceramic pads, just say no.
The following 2 users liked this post by Turbonut:
horseshoez (07-17-2019),
Jackass (07-17-2019)
I'm down for that recommendation but I don't believe my issue is rotor build-up. I believe my rotors are warped which would require replacement (i've already had them re-surfaced once.
Soooooo you don't listen to what people who are arguably more experienced than you because...?
Took my car in for a brake inspection and it's confirmed that my brake pads (front and back) should be replaced, and my front rotors are warped and need to be replaced. I'm looking at these from rockauto. Found a reputable mechanic who will handle the labor if I buy the parts. Are there any other parts I would need to purchase before buying? Below is what I'm looking at purchasing.
In theory, yes. Though the underlying cause for your rotors warping could still be there - such as a sticky piston in your caliper. But if you're simply getting the car road-worthy to sell, I would say what you have in your cart is fine.
I don't mean to pressure you out of your comfort zone, but brake pad and rotor replacement is a very common DIY fix, and is more than doable for a first-timer. Granted, you may need to find or borrow some floor jacks, but there aren't really any specialized tools needed for this job. Hell, there's a video right here of the exact job you want to do.
Even if you buy the parts, a dealership or shop would have no problem charging you hundreds of dollars for something that can be done in a saturday morning. Just my two cents.
Latent car nut
horseshoez (07-18-2019),
quantum7 (07-19-2019)
if I can charge $400 for a front brake job, I will be quitting my job lol.
Latent car nut
Pads Rotors Calibers
Not your average mechanic but have own 3G TL's over 10 years. I recently picked up and 07 TL which had been sitting at least a year or two. I'll know tomorrow if my leap of faith panned out or not. Anyway, I was looking at RockAuto website but not too comfortable knowing exact part numbers for descent front/rear pads, rotors and calibers. All I plan do to is get the car in good working condition and sale it. Any recommendations which parts to go with?
Thanks,
Dan
Thanks,
Dan
Latent car nut
Thanks,
Dan
Thanks,
Dan
mark1980
06-11-2015 07:48 PM
alucardx
09-29-2009 07:04 PM
Porkipine
07-30-2009 08:12 AM
