2005 Acura TL transmission reset: any risks?
Old 09-18-2017, 04:26 PM
edlupo99's Avatar
Hi,
I'm looking to reset my TL's transmission. I know you can floor the gas pedal for 30 seconds and it will reset it. I'm just curious if it is safe to do this. Are there any risks involved? Can I somehow break my transmission by doing this?
Old 09-18-2017, 04:52 PM
peter6's Avatar
In simplification : This procedure just resets computer that responds to gas pedal position. There is no way that it can break anything, and it will not fix anything.
The only advantage is that car feels more 'sporty' for short amount of time, until it 'learns' normal driving habits (and in city/highway traffic, it means 'slow and boring').
Old 09-18-2017, 06:25 PM
edlupo99's Avatar
My car has been downshifting rough at speeds under 35mph lately. That's why I was thinking of doing this to see if it would help. Sounds like it won't?
Old 09-18-2017, 06:27 PM
Received 8,584 Likes on 6,630 Posts
Your transmission sounds like it's on its last legs
Old 09-18-2017, 06:28 PM
A better option is to try and replace the pressure switches and do a fluid change. If those don't alleviate the issue.
Old 09-18-2017, 06:32 PM
edlupo99's Avatar
It upshifts fine and downshifts fine with speeds above 40mph, so it could be the pressure switches? Hopefully not a new transmission.
Old 09-18-2017, 07:01 PM
CenturionTL's Avatar
if that doesn't work pull the ECU fuse and back up fuse from under the hood for 30 minutes to 1 hour.
Old 09-18-2017, 07:15 PM
peter6's Avatar
By rough you mean that you can feel car slowing down when it shifts? If so then it's fine.
Do pressure switches and atf anyway.
Old 09-18-2017, 07:16 PM
https://acurazine.com/forums/third-g...2006-a-729149/
DIY
Old 09-18-2017, 07:22 PM
edlupo99's Avatar
Yes, it almost feels like the car is burping or something when it downshifts with speeds under 35mph. It's hard to explain. It's just a rough downshift, you can feel it jerk.
Old 09-18-2017, 07:23 PM
edlupo99's Avatar
Thanks, thoiboi, I'll probably do that this weekend.
Old 09-20-2017, 11:08 AM
jroca's Avatar
Did it happen in 3rd gear? My green "d" light kept flashing one day and it turns out it was the 3rd clutch pressure switch? Don't know the exact name but was having the same problem as you. Thoiboi right as awlays - pressure switch
