1.5 floor jack
Old 02-21-2018, 08:04 PM
3rd Gear
humbe guy's Avatar
1.5 floor jack
Can a 1.5 ton floor jack lift the front tires off the ground? i want to do a lock to lock on my steering wheel on a 2005 acura tl. Some say yes and some say no. Can anyone give me the correct info? Many thanks.
Old 02-21-2018, 08:21 PM
Iggy's Avatar
whole car weighs 3500lb.
1.5 ton = 3000lb
So yeah, lifting the nose should no problemo. You don't even need the front wheels completely off the ground for lock to lock, just take some weight off them. In fact, if you are on concrete you can drive the front wheels onto some pieces of cardboard, they will act as skid plates.
Old 02-21-2018, 08:56 PM
3rd Gear
humbe guy's Avatar
1.5 Ton Floor jack
Thanks so much Iggy for the info i won,t have to buy a jack now, i am bleeding my power steering so i,ll just get me some cardboard and drive the front wheels onto it....thanks again.
Old 02-23-2018, 10:40 PM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
This thread has been moved to the model specific forum for better response.
Old 02-24-2018, 08:49 AM
Turbonut's Avatar
Put 2 pieces, one on top of the other, and place them under the tires.
Old 02-24-2018, 02:16 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
I would put at least 3 pcs of cardboard since the Acura is FWD so all the weight is up front (Unless you plan to do this in a NSX)
Old 02-25-2018, 08:00 PM
kamiltl's Avatar
If You are placing jack in front or back ( not i middle ) then wont be more than 500kg.... You are not lifting whole car...
I am using home depot 2000kg jack which is more than enough
https://www.homedepot.com/p/Husky-2-...-BLK/203328272
so dont worry You are fine to lift even hummer.
Old 02-27-2018, 07:41 AM
08KBP_VA's Avatar
Technically dont even need to lift the car to bleed power steering Not sure what it actually does for you. Not like your gonna be doing this for hours.
Old 03-01-2018, 02:36 PM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
You lift the front wheels so it doesn't stress the pump and rack when it's dry.
TL-Syndicate23
05-07-2017 11:18 AM
NCTL05
12-06-2016 09:52 PM
BluNosr2
11-10-2016 10:52 AM
sixsixfour
10-14-2016 07:29 AM
Quick Reply: 1.5 floor jack
