05 tl swapped subframe wiring harness engine to ecu steering column
Old 12-23-2018, 02:08 PM
6th Gear
Dan Meredith's Avatar
I swapped subframe from tl type a 07 with harness to inside car steering column and even ecu what else needs to be done or is that all I need the motor ran before ecu swap just minor things were not functioning but car did run and drive just not very well so I swapped interior harness and ecu and column and before I start it up my question is does the interior chassis and accessories harness need to be swapped?
Old 12-23-2018, 02:09 PM
6th Gear
Type s
handsom-hustla
03-21-2016 06:50 PM
08A-SPEC
04-23-2014 01:40 AM
lookinco
07-24-2006 05:04 PM
Un-Kut
1G TSX Problems & Fixes
12-02-2004 01:22 PM
Quick Reply: 05 tl swapped subframe wiring harness engine to ecu steering column
