04 tl foglights
04 tl foglights
`what kind of foglights can i install on the bumper, ive seen many people say honda accord but what year accord? are there anyother ones i can put on, links would be appreciated
Fearless DIY Guy
2003 - 2005 Honda Accord Sedan Fogs. Get OE as the lenses are glass if you intend of going the HID route, otherwise, the eBay knock-offs will suffice.
Since you're probably going to ask this next anyway, you will need to cut the lower grilles to fit the bezel, bumper removal is not required but makes attachment easier. Most kits come pre-wired, you will simply need to attach the pos to the battery, neg to chassis, and route the switch cables throuhg the firewall; there is an OE hole you can use in the middle. Switch installs perfectly in the blank located on the VSA/mirror panel by your left leg.
'13 Hyundai Sonata
Yes, many people on here have the ones in the headlights running with the low beam and the ones that they put in the bumper.
Some have deleted the fog light in the headlight and ran the wiring to the accord fog lights.
9 mpg.
So, I'm tempted to do this mod so my TL would look "newer" per se'. But I'm confused. If I install lower foglights, what do I do with the ones in my headlights? I want it to be set-up so my 10k's shine through the headlight and my nokya yellows come from the foglight housing in the bumper.
quanaman
01-09-2023 07:33 PM
shinybluecls
11-16-2005 12:00 PM
ST2000
08-14-2003 02:47 PM
