Battery issue?
Snoozabelle
Battery issue?
So I've only had my 2014 Sport Hybrid for about 4 months now. Last night was the third time I have been stuck with the car not starting after listening to the stereo (on accessory mode) for no more than 15 minutes.
I park in the garage at work and when I arrive early I like to listen to the stereo. No problem or so I thought. The first two times I came out at midnight to find the car wouldn't start. Every light in creation was flashing
but no start. My husband came and jumped it the first time. Second time I used my portable charger and was on my way. Not thrilled that this only happens to me but that's beside the point. So last night same scenario,
arrive early and listen to the stereo. Just out of curiosity I decided to start the car before going in to work. OH NO! This time not only won't it start but I can't turn it off from accessory! The radio is now asking for the security
code and nothing works to turn it off. There has never been any code to tell me the battery is weak. Called my wonderful husband again to come get the car, thankfully it wasn't at midnight again. I had to leave my beloved
RLX "on" in accessory mode, unable to lock it, until he arrived. At least I knew noone would be driving it away! He jumped it again and drove it home and put on the trickle charger for the night.
So my question is: do I need a new battery? The car is out of warranty and I didn't buy from an Acura dealer so no help there. No codes ever told me about the battery. No other problems with the car.
Replace the battery and see if that solves the problem? It's no fun trying to jump start the car at midnight in a freezing cold garage after working a very stressful job. HELP!!!!!
It sounds like a trip to the dealer for a new battery is in order.
It is not an uncommon problem...the RLX's often sat on the lot waiting to be sold and normal parasitic loss drained the batteries during that time. Once the battery is drained completely, it is weakened and unable to fully charge and eventually requires replacement.
Sorry for your troubles, I hope you can enjoy your music once again once the battery is replaced.
The following 2 users liked this post by hondamore:
Limelight (02-19-2019),
snoozabelle (02-20-2019)
At first I thought you had a P-AWS and were running the stereo in accessory mode because you didn't want to waste gas. But then I re-read your post and see you have a Sport Hybrid.
I will often listen to the radio, make a call or check messages when I arrive at the office but since the car is warmed up by that point, I just leave the car "on" in Park vs. turning it off and then back into accessory mode. Is there a reason why you aren't doing that? Sure the gas engine might cycle on and off a few times, but it won't do that much especially if you don't have the heater on (and I find with my heated seats and steering wheel on, I don't need the heat anyway as the car has already warmed up).
That all said, as Hondamore said, I think your battery has seen better days and a replacement should cure what ails you! Good luck.
Battery my friend. Simple fix.
Stay Out Of the Left Lane
Received 1,236 Likes
I agree - sounds like a battery issue. I see you are also from MA -
Snoozabelle
I'm shopping for a new battery and thinking about getting an AGM battery rather than the standard OEM. Any thoughts or experience out there regarding the battery replacement?
I went to work today and arrived early as usual. However, I did not listen to the stereo and just went into work. Got out at midnight and luckily no problem starting the car. My husband
will be driving it tomorrow but he never has any problem so I won't be worried. I'll be driving my reliable RDX!
I'm not sure if there are any known issues using AGM batteries in hybrids, but whenever my RLX (17 sport hybrid) needs 12v battery replacement, I'll be going with Odyssey battery (Extreme Series). I have Odyssey batteries in my other vehicles (including MDX) and they are expensive but solid, reliable batteries.
The following 2 users liked this post by vtec_v6:
hondamore (02-20-2019),
Good luck and keep us posted on how things work out for you.
Fob
I have had to change my battery 3 times in 4 years - luckily all for free by the dealership. 1 time the battery went dead only a few months after the replacement.
We could not find anything wrong with the RLX itself but surmised that perhaps since I left the FOB near the car overnight, it was draining the battery. After that, I keep my FOB upstairs in my bedroom instead of near the garage & the battery has not died .... yet .....
For what it's worth, I'm on my original battery with 90,000 miles.
Odyssey batteries are great, we used them in our hybrid and solar car projects in the 90's.
Has anyone with an RLX Sport Hybrid actually replaced their battery with an Odyssey? What model did you buy? Just trying to help out snoozabelle here as on line tools give conflicting information. Would be good to get a first hand answer here on Azine!
Doc Holliday
18
09-27-2005 03:12 PM
speedjunkie
08-04-2003 08:11 AM
shaolin
07-20-2003 11:28 PM
