3G RDX vs Mazda CX-5 Turbo
2019 Mazda CX-5 just came out with a 2.5 turbo engine in the top of the line Signature and a lesser GT Reserve trims. 250 hp with premium / 227 hp with regular fuel. 310 lb-ft with either fuel. The top of the line Mazda is equipped similarly to a fully loaded RDX including all the safety gizmos and things like HUD display, etc, plus it has Android Auto and power folding mirrors. Doesn't have the adaptive dampers and it's Mazda's torque vectoring vs SH-AWD in the Acura. Slightly more compact exterior dimensions by a couple of inches, but interior volume seems comparable. No formal reviews or tests out there yet, but wanted to start a conversation and see what folks think of this model vs the RDX.
You'll Never Walk Alone
If the engine is similar to the one found in the Mazda 6 or Mazda CX-9, then it's gonna be slower than the RDX despite the power and torque rating.
Here are some comparison figures:
Mazda6 2.5 GT
250hp/310lbft
Weight: 3563lb
0-60mph: 6.4s
1/4 mile: 14.9s@97mph
https://www.caranddriver.com/reviews...5t-test-review
Honda Accord 2.0T Touring
252hp/273lbft
Weight: 3419lb
0-60mph: 5.5s
1/4 mile: 14.1s@102mph
https://www.caranddriver.com/reviews...ic-test-review
That's night and day difference in terms of performance.
Also, I sat in a new CX-5 in the auto show, and its interior materials/quality are steps below the RDX. It looks nice in photos, but certainly feel a lot cheap in person.
This is not a dig on the CX-5 by any means. Given its price, it's a great buy much like the CR-V. It's sort of like the Accord 2.0T Touring vs Audi A4.
Mazda6 2.5 GT
250hp/310lbft
Weight: 3563lb
0-60mph: 6.4s
252hp/273lbft
Weight: 3419lb
0-60mph: 5.5s
Mazda6 2.5 GT
250hp/310lbft
Weight: 3563lb
0-60mph: 6.4s
252hp/273lbft
Weight: 3419lb
0-60mph: 5.5s
Mazda6 2.5 GT
250hp/310lbft
Weight: 3563lb
0-60mph: 6.4s
252hp/273lbft
Weight: 3419lb
0-60mph: 5.5s
As far as interior quality, Mazda claims to really up their game with the Signature trim - Nappa leather and real wood. I have not seen it in person, but will probably check it out in the next few weeks. I don't expect it to be as posh as the 3G RDX, but perhaps it will be on par with the 2G RDX which I own and am happy with as far as interior materials.
For sure, having more gears would help. Having said that, 6AT is not bad at all and for me, it's enough. From that point on, diminishing returns kicks in. Even with the number of gears factored in, there's a pretty significant gap in performance which suggests that the K20 is simply a more powerful motor. It's pretty well known that Honda underrate their engines much like what the German brands do these days like Audi and BMW.
Yea, having more torque means it's easier to overwhelm the front wheels. However, with the 10AT, the Accord is likely to have more aggressive gearing. The gears are like torque multiplier. The torque and power that get to the ground are probably more than in the Mazda 6. That would make sense to since you do need to put down more power to the tires to accelerate faster. Also, 1/4 mile trap speed is not really affected by grip level, it's a good indication of how fast a car is without worrying about grip.
The 30-50mph and 50-70mph tests are more about how aggressive/responsive the transmission is. It also helps that the Mazda 6 has fewer gears to go through when downshifting. After all, these tests are top gear acceleration tests, it's easier to go from 5th or 6th gear to 2nd or 3rd, rather than from 8th or 9th gear to 3rd or 4th gear.
I test drove both on the same day last Saturday and both are terrific cars, a few notes from my end:
- The RDX is about a half size bigger inside and out. Whereas the RDX can legit seat 3 in the back, the CX-5 is really a 2 person car in the back and the tunnel eats up a lot of space.
- The engines have very different characteristics which is what you'd expect. The Acura is a revver and the Mazda is a tugboat.
- The interior is flashier in the RDX and a bit nicer.
- The RDX is livelier.
In Canada, the CX-5 Turbo is the same price as a CR-V Touring (fully loaded) and if space isn't a concern then it's no contest that the CX-5 is better then the CR-V. The diff between the CX-5 and RDX is about $12K for similar trims and it's not clear to me that it's worth it - the extra room is great, the slightly nicer interior is nice but beyond that....I'm having a long hard think on this one.
7.3 sec 0-60 per Mazda. Performance figures toward the back of the document.
https://www.docdroid.net/mjZMMPd/19-cx
It's a good value, but wouldn't be that interested.
7.3 sounds conservative as most 0-60 times are measured. It's about what the much larger, much heavier CX9 manages with the same powertrain. But the focus should be on 5-60, 30-50 and 50-70 times anyway. In the real world, those are the numbers that matter. Unless you do abusive Car and Driver style launches on a regular basis, that is.
Drive RDX and CX-5 on the same day on same roads and see the difference. I disagree with you on CX-5 handling vs RDX
The new CX-5 will be a great car, but no way can it compete with the SH-AWD in the RDX.
I can litterally take corners at 50 and not slip.
I’d say the AWD system and handling of the RDX is only second to Subaru’s.
Good to know. I drive the Vette, and am very use to high speed cornering, so when the car breaks in, I will give it a go and report back. My Vette has Michelin PS4s (fantastic tire, and don't need AS type tires here in So. Cal) and will have to see if they are available for my 20 inch rims on the RDX.
https://www.tirerack.com/tires/tires...XLV2&tab=Sizes
Just ordered a set for my Civic last week! Heard so many positive things about these tires...can't wait to put them on next spring!
I test drove a top-of-the-line '19 CX-5 Signature at 8 am this morning before heading to the Acura dealership for a 9 am appointment to test drive a '19 RDX (which I bought!). The 2 big non-starters for the CX-5 were (1) lack of refinement; and (2) the loud and grunty 2.5L SkyActiv engine. I was so disappointed with the CX-5 that I cut the test drive short. The salesman was so disappointed that he actually became rude.
I really wanted to like the CX-5 Signature. It seems like an excellent value ($10k cheaper than the '19 RDX that I bought) and Mazdas tend to be quite reliable.
I doubt most people in the market for and RDX would bother with a CX-5. If you are comparing it to a CR-V to a CX-5, then this makes sense.
That brings us to the CX-5. One of our daughters has an older, like 2014, CX-5. She's had zero issues with it and really likes it. So, we stopped by the Mazda dealer, which is right next door to the Acura dealer. We come to find out about this new Signature version which is about to be released, so I did some research. We are now in the opposite situation, where the RDX is about $10k more than the RDX. I like being married, so my wife has a lot of say with the vehicle we get for her.
Like I said, she's not really a "car person", meaning she just wants to get from point A to point B safely. The CX-5 Signature looks like it may be what fits her best.After typing all that, I'm starting to realize you are probably right. "Most" people in the market for an RDX are more than likely not cross shopping the CX-5. I've never been confused for someone who follows a pattern, though.
You're not alone man. I test drove the CR-V first, then the Rav4 hybrid as my wife wanted a Hybrid. The CR-V was close to $40k CAD, and the RAV4 hybrid is like $43k CAD. Since there's a Lexus dealership beside the Toyota dealership, we also went to test drive a RX350. My wife enjoyed the RX350 and wanted the hybrid version. Unfortunately a loaded RX450 hybrid is like $77k CAD...which is a bit too much. Even a loaded RX350 was around $70k. We then test drove the RDX a couple times, and ended up with the Elite Platinum trim at $55k, which is right around the middle of these cars.
I feel like there's a pretty big gap in quality, power, refinement, features, and luxury feeling when going from the CR-V/Rav4 to the RDX. I can quantify where the extra $15k goes to easily. While there's a bit of a step up in luxury feeling going to the RX, I'm not quite convinced the gap is worth $15k from the RDX Elite Platinum. It's a little quieter, a little smoother, and materials are a bit nicer. But I also lose the fun to drive part, the handling, and the acceleration.
I test drove the step down from the signature today, Grand Touring Reserve, as they can't keep any Signatures in stock at this point by me. I've test driven the RDX Advance several times and it obviously out classes the CX-5 "anything". That said, the thing I dislike the most is the piped in exhaust noise in the RDX. The CX-5 turbo'd 2.5l is much quieter, and slower. The Signature is a great "bang for the buck" contender in the compact SUV category. Just as the RDX is vs. the QX-5, or X3. It's great to have choices!
I'm amongst those comparing the CX-5 Signature against the RDX A-Spec - it's about a $12K diff in Canada with those trim levels while a base RDX is about $3K more than a Signature so cross shopping shouldn't be a surprise. Both are terrific cars with different selling points and I think the $12K diff is not covered strictly in what you get, there's definitely some aspect of badge value showing up there. I'm not ready to make a decision yet (planning to buy in Q1) and I'll be taking both cars for an extended test drive (a few hours) before deciding. The RDX is the nicer car all around but $12K better? Not sure about that one.
Re: CX-5 being slower. I don't think that's been proved yet - the RDX comes in at 6.6s in the 0-60 and I'd expect the CX-5 to be right around there too (the CX-9 does it in 7s and is 400-600lbs heavier).
The piped in exhaust noise is definitely annoying compared to the CX-5 if sound level matters to you (it does a lot to me). C/D has the CX-5 at 65db and the RDX at 69db at 70mph - that's a huge difference (65 is luxury car territory, 69 is family sedan territory).
https://s3.amazonaws.com/amv-prod-ca...ouring2017.pdf
https://hmg-prod.s3.amazonaws.com/fi...1534989527.pdf
I think it's more fair to be using AWD for both cars when comparing numbers. Also, the RDX tested was the A-spec version. With 20" wheels and wider tires, it's gonna be louder unfortunately. The other trims are quieter, and even more so for the advance trim with even more focus on quietness.
I test drove both an A-spec and Elite platinum trim and the difference is fairly noticeable.
Just wondering for your pricing, are you including taxes or something? CX-5 Signature is $43k CAD, and RDX A-spec is $52.5k CAD, both with PDI included. $9.5k difference. I'm asking because the $3k difference in mentioned between the RDX base and CX-5 signature is right at $3k, before taxes. So ya, I wanted to point it out just so you actually have the right numbers haha!
Have they tested the signature CX-5 yet? From what I see on C/D, they had the 2017 CX-5 GT AWD at 67dB and the RDX A-spec at 68dB:
I only looked at the sound levels for the 2017 FWD GT (https://www.caranddriver.com/reviews...wd-test-review) which they had at 65db, didn't see the AWD test which you've cited. Based on the data you cite, there's reason to believe that the two cars have similar sound levels with the RDX likely being slightly higher but not significantly. A better set of tires not the RDX A-Spec or the Advance/Platinum Elite trim would probably close the diff.
re: Pricing - The $12K is after taxes - I was flip flopping on pre/post taxes. My bad. FWIW, financing is also a lot worse - the CX-5 is ~2.65% and the RDX is 3.9-4.9%. Mazda's loyalty discount also applies to anyone who owns a Mazda while Acura's only applies if you're actively financing an Acura/Honda or within 1 year of being financed (I own both a Mazda and an Acura but only Mazda gives me the loyalty rate). It starts really adding up if I choose to finance (which I'm 99% certain I will).
So corrected Canadian (BC) pricing comp for CX-5 vs RDX (taken from Mazda sales guy and Acura website), listed as pre-tax and post-tax (rounded to the nearest hundred):
CX-5 GT $42,500/$47,600 (there's no Reserve trim in Canada)
CX-5 Signature $43,100/$48,300
RDX Base: $46,200/$51,700
RDX A-Spec: $53,000/$58,800
All listed models are AWD trims (no FWD available in Canada for these trims). 5 year financing rates are 2.65% (Mazda) vs 3.9% (Acura) as of this week.
Some early reviews of the CX-5 Signature are coming out and the reviewers are pretty positive about it and the RDX gets brought up as an apt comparison.
https://driving.ca/mazda/cx-5/review...cx-5-signature
https://www.theglobeandmail.com/driv...-turbocharger/
All three of these reviews make comments about it being comparable to a RDX or to German crossovers selling for $10K more.
I'm planning to take both cars out for extended test drives at the end of the year - the Mazda dealer says I can take it overnight as well. Looking forward to a back to back comparison over a full day.
Yea the CX-5 would definitely be the better value. This pretty much applies to the CR-V, Rav 4, etc too. It's like how the Accord 2.0T looks like a really good buy versus the Audi A4 2.0T. I think it comes down to whether you'd like to go for the more luxurious experience.
Any new experiences or feedback on this comparison? I haven’t test-driven the Mazda yet but do like the clean exterior (basically unchanged since 2017). No extra bling like the RDX chrome. A bigger selling point for me, though of course not everyone, is the fact that the Mazda is 8” shorter so much closer to my Gen 1 RDX that I’m still soldiering on with. I’m somewhat garage challenged so the shorter length helps.
Before you plunk your money down, and after your research and initial test drives, drive them both in the same day, preferably one after the other. All new cars are impressive to drive, so put the final two back-to-back. Examine how you feel when you are in them.
Good point. And the dealerships are only about 5 minutes apart so no problem doing that. Head vs. heart though. I’ve had Acuras since my 1996 Integra so will likely prefer the RDX. Fitting an RDX in the garage (and even parking spaces) is going to be a bigger problem than the Mazda.
I’m a fan of the CX-5.
When I did my test drive, I had no idea they were going to add the turbo.
Had I known, the decision would have been tougher.
The only negative for me with the CX-5 is noise. I was riding in one with my family this week and the rear wiper sounded like a meat grinder.
Love my RDX, but the Mazda is a great choice overall especially if you’re interested in a vehicle that’s slightly smaller.
I've been also looking at the CX-5. As far as refinement goes, it's not a fair comparison to the Acura and the other luxury brands. They seem to need a lot more work on their tech/driver enhancements (e.g. infotainment, camera quality).
That being said, the cost difference is also a factor as they do give you "more bang for your buck".
Here is CD's take: https://news.yahoo.com/depth-photos-2019-mazda-cx-182300751.html
Note that they have 0-60 in 6.2s and they specially called out RDX!
As for screen quality, although RDX does have higher resolution but it's backup and surrounding (360 view) camera are disappointing, Mazda camera quality is of the same.
Overall CX -5 is doing what Acura does to the German. The interior, while feels quality, does lack the high tech look of Acura's. I would say it's more BMW like than anything else on the market. It probably took inspiration from it, it's not very original.
However the value you get from this car is really unbelievable. I thought Acura was amazing but Mazda really out did them in their own game!
in mind this is rated IIHS safety plus just like the Acura RDX!
