2005 TL-Steering Rack problem- DFW, TX
Old Feb 12, 2014 | 11:23 AM
Hmb0048's Avatar
8th Gear
Needing some advice, I just picked up a 2005 WDP TL, w/ 120k mi. Called acura of plano for the maintenance history, turns out I need to be replace the steering rack due to a leak; I was already suggested to the previous owner to get fixed (est 1200-1400 job w/refurb parts). What would be considered reasonable? Any mom and pop shops y'all recommend?
Old Feb 13, 2014 | 10:49 AM
NBP_BALLER's Avatar
Dallas Chapter Leader (Midwest Region)
Go read my comment on the DFW area thread. Also has it had tranny pressure switches, trns filter, trans drain/refill, timing belt/waterpump etc.?
Old Feb 13, 2014 | 11:51 AM
Coins's Avatar
Please please please do the pressure switches, fluid and filter ASAP if it they haven't already been done! Make sure you transmission fluid is NOT brown.
It'll be a total of $80(Pressure switches) + $20(filter, gasket, spring) + $70-80(9 quarts DW-1 OEM fluid - Honda dealership is cheaper than an Acura Stealership)
= (180 + shipping)
It'll be preventive maintenance that can avoid having tranny issues and dropping another few thousand on a transmission which is what I'm currently dealing with
Old Feb 13, 2014 | 05:00 PM
Hmb0048's Avatar
8th Gear
= (180 + shipping)
[QUOTE="NBP_BALLER;14876044"]
Hey man, heres my advice. I am a mechanic and have worked at a dealer for 5 years. There are two reasons that your steering gear would mostl likely need replacment. 1. Leaking fluid(most common) 2. Internal wear/slack. Most likely you just have a leak and it is causing no harm whatsoever just a tiny leak that will probably never even drip on the ground. REMEMBER... the dealer will try and sell you anything if its leaking or worn. I had my gear replaced but it was just leaking, I had an aftermarket warranty tho. If its just leaking, I wouldnt replace it unless a dinky leak worries you. One of us can look at it one day, or i can. No biggie man.
- Much appreciated response NBP & Coins, is there any way that you could PM me your information NBP? I may take you up on that offer if you don't mind looking at my car. As far as I know these are the Major tunes ups the car had @100k at David Mcdavid of plano:
Recommended maintenance performed
Brake fluid flushed/changed
Four wheel alignment performed
Front brake pads replaced and rotors resurfaced
Rear brake pads replaced and rotors resurfaced
Battery/charging system checked
Oil pan replaced/repaired
Washed/detailed
Timing belt/tensioner/idler replaced
agupta3224
May 23, 2017 08:30 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
