WIFI Issues?
Old Aug 31, 2013 | 06:42 PM
r3mix3r's Avatar
WIFI Issues?
Hi Guys,
Just curious if anyone is familiar with wireless connection issues...I'm in a new spot now, and using a NETGEAR WG111 V2 5Mbps Wireless USB 2.0 adapter that I got from work for free.
I plugged it into my computer, and I'm using the Wireless assistant that came with it. The internet seems to be pretty good speeds, and according to the "Signal" it seems pretty strong.
Here is my results from SpeedTest.net:
<a href="http://www.speedtest.net/my-result/2936850555"><img src="http://www.speedtest.net/result/2936850555.png" /></a>
The issue is when I'm watching a YouTube video/streaming music it seems to hiccup and stop. I also seem to drop connection every so often (maybe once or twice a hour), and then it will come back in a few minutes. The connection seems to either work perfect, or totally hiccup. I just tried to D/L a 100mb file, and it keeps failing mid way in during one of the quick hiccups.
I have the USB plug in the back of the computer, and this house has AT&T U-Verse. The router/transmitter is in another bed room on the other side of the house, although all on the same floor.
Is there any diagnostic programs or anything I can do to see what's causing the hiccups? Anything I can do to keep the connection stable, and stop breaking every few minutes?
Thanks!
Old Aug 31, 2013 | 11:14 PM
NSXNEXT's Avatar
I think your roommates need to stop downloading porn so you can.
Old Aug 31, 2013 | 11:38 PM
#1 STUNNA's Avatar
Sanest Florida Man
Youtube sucks for everyone. You can have gigabit speeds and youtube will still crawl. You can get as much as youtube will give you.
Try running the test at http://www.pingtest.net/
also run a ping test to your router from a command prompt. for example type in
ping 192.168.0.1 -n 50
but replace that IP with your routers IP. let that test run and if you have any dropped packets then you got issues.
Old Sep 1, 2013 | 12:39 AM
AZuser's Avatar
_
Eggplant-EX is OP's room mate? What a small world.
Old Sep 1, 2013 | 02:56 AM
Whiskers's Avatar
Go Giants
USB Wifi adapters are not the best.
Old Sep 2, 2013 | 08:00 AM
2001AudiS4's Avatar
Uverse internet is also terrible. It is much slower on the internal network than those speed test show. I switched from it not long ago to cable internet and its so much better. I also found out that all the ports were suddenly closed on Uverse and you have to pay for support to unblock them. BS.
Old Sep 2, 2013 | 11:48 AM
maharajamd's Avatar
I love my Uverse internet service...
Old Sep 2, 2013 | 11:51 AM
2001AudiS4's Avatar
You forgot the red text
Old Sep 2, 2013 | 11:58 AM
Ken1997TL's Avatar
Get a plugin for your browser that allows Youtube to buffer properly. There are dozens out there.
Old Sep 2, 2013 | 11:59 AM
Ken1997TL's Avatar
Here's an example for Chrome
Old Sep 3, 2013 | 08:17 AM
maharajamd's Avatar
No. I have ZERO complaints about anything from Uverse. My internet FLIES at home and in 14 months I haven't had a single minute of downtime.
Old Feb 3, 2014 | 09:57 AM
r3mix3r's Avatar
Does anyone recommend a good budget friendly Wifi adapter to use for a desktop PC other than a USB plug-in? I'm thinking there's gotta be a better one out to pick up a stronger more steady signal.
Thanks!
Old Feb 3, 2014 | 10:10 AM
TeknoKing's Avatar
Did you check your signal? What's the dB? They have USB with antenna, but if you want more power either get a wifi repeater or a pci card
http://www.newegg.com/Product/Produc...82E16833320173
But it all depends how far you are from your wifi router, your dB level, router's settings and channel you are using.
If you have android, download Wifi Analyzer
for pc/mac, you can download http://www.inssider.com/ this will tell you in detail about your wifi and give you recommendations to fix it.
Old Feb 3, 2014 | 10:29 AM
r3mix3r's Avatar
How do I check the dB? The Inssider program looks great, are there any free versions available?
Old Feb 3, 2014 | 10:45 AM
Mr. Maker's Avatar
Kevin, the wifi's out..
Old Feb 3, 2014 | 10:48 AM
stogie1020's Avatar
Needs more Lemon Pledge
Make sure power management for the USB device is not enabled. If it is, the computer may sense a lack of activity and power down the USB device periodically.
Control Panel>Device Manager>Network Adapter>(Right click on your USB WIFI adapter)>Properties>Power Management
For a non-USB solution for a desktop, take a look at something along these lines:
http://www.newegg.com/Product/Produc...140203164838:s
Old Feb 3, 2014 | 10:53 AM
TeknoKing's Avatar
It's free for like a week or so. Just install it and it will give you all the info including your signal strength, all interfering wifi signals and it will recommend you what to do.
Old Feb 3, 2014 | 03:56 PM
r3mix3r's Avatar
Thanks!
The Power Management first box was actually checked, and I just unchecked it. Great tip, hopefully this helps?
Old Feb 9, 2014 | 12:00 AM
r3mix3r's Avatar
I can't seem to find a free version even for a week, it's $19.99 download only?
Additionally, I tried buying a different USB adapter, and bought the Belkin N150. The performance was actually worse than the old NETGEAR WG111v2 54Mbps Wireless USB 2.0 adapter I was using. I now switched back.
This morning I tried to download a 50MB excel file that I need, and I literally tried about 25-30 times. It kept getting to 25-35mb range and then I got the "Failed - Network Error" message on each download in Chrome. I also tried FF and IE and same/similar issue. Sometimes it would error out even before 1MB. I tried using GetRight, or a download manager, but it's a secure file so it won't work.
NETGEAR WG111v2 Wireless Assistant is showing a signal of 55% or higher at all times. I tried moving the USB adapter from the back of computer to front, although not seeing any changes. The Mbps in the assistant program ranges from 11Mbps-18Mbps and then sometimes drops to 1Mbps or 2Mbps.
Does anyone have anymore ideas? Internet surfing really isn't too bad other than the occasional hiccup, but I literally can't download a file bigger than 5mb without a problem.
Thanks in advance to anyone who has experience in this. Greatly appreciated!
Brad
Old Feb 9, 2014 | 06:47 PM
stogie1020's Avatar
OK, here is how I would test it, if you can...
1. Plug into the router with eth cable and see if the router is working via eth.
2. Try a different laptop of tablet computer via ONBOARD wifi and see if you have connectivity issues.
3. purchase and try a different model/brand usb wifi adapter.
basically, try to isolate the cause to the router, the router wifi radio or the specific USB adapter you are using.
Old Feb 12, 2014 | 05:45 PM
whudini3000's Avatar
Sounds like your suffering from wi-fi interference or possible overlap which is really common on the 2.4GHZ spectrum. Cell phones, house phones, microwaves and etc. will interfere with your connection. My advice, scan the area with the wifi analyzer app and switch to a less congested channel. Otherwise, replace the network adapter and purchase a 2.4/5ghz network adapter with an antenna.
-Best
snorf
Nov 4, 2019 06:44 AM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Frathora
Sep 28, 2015 11:29 PM
tristann616
1/2G MDX (2001-2013)
Sep 22, 2015 11:40 PM
carz0159
Sep 20, 2015 06:11 PM
