Using non 850Mhz phones with Cingular?
Will non 850Mhz phones still work with Cingular in the NYC area? Will there be problems?
A few years back I had a T610 that I used with Cingular and it worked fine.
in the nyc area you will not have good reception with just 1900. the reason your t610 worked fine without 850mhz is b/c cingular was using t-mobiles towers then and all t-mobiles towers are 1900mhz. now you will be using cingulars towers and at&t towers. all at&t towers in the nyc area are 850mhz.
Slooo97CL - you are right about that, but in nyc its worse b/c in some areas there are ONLY 850mhz towers so you will get bad reception outdoors as well.
Originally Posted by TLXLR8S
this is true with t-mobile and. but cingular have many 850mhz towers.
Originally Posted by Raheel
Even T-Mobile is adding 850 to there line of towers, all of there new phones have 850 band
mlody
Dec 4, 2019 02:11 PM
RenoTL
Sep 17, 2015 07:45 PM
