Remote PC access
Old Aug 22, 2006 | 01:59 PM
fsttyms1's Avatar
Remote PC access
What do you recomend for remote access. I work out of town alot and would like to remote access with my PC at work. I dont mind paying for something or free versions.
Old Aug 22, 2006 | 02:00 PM
cM3go's Avatar
PC Anywhere
Old Aug 22, 2006 | 02:04 PM
doopstr's Avatar
VNC if you can configure a firewall and know what dynamic dns is.
Gotomypc (not free) if you don't want to configure a firewall.
And there is this free gotomypc competitor.
http://www.logmein.com
Old Aug 22, 2006 | 02:16 PM
GBockers's Avatar
...I like stories...
Ask your network administrator
None of these products work if your PC is behind a firewall. Usually you would use a VPN (Virtual Private Network) connection to your job's network and then you could use PCAnywhere, VNC, or even Remote Desktop to connect to your work PC.
G
Whiskers's Avatar
Go Giants
What OS are you using at home? Where are connecting from? What type of Router do you have? What is your Social Security Number and Savings Account Number? ASL?
Old Aug 22, 2006 | 02:24 PM
doopstr's Avatar
G
This statement is not fully correct. Gotomypc and logmein work with no firewall modifcation, provided that the admin hasn't specifically blocked the sites those products access. The admin would have had to have gone out of his way to block those products.
Old Aug 22, 2006 | 02:29 PM
Whiskers's Avatar
Go Giants
Do they run over port 80?
Old Aug 22, 2006 | 02:30 PM
GBockers's Avatar
Huh?
No enterprise worth it's salt would leave unused ports opened on their firewall.
Old Aug 22, 2006 | 02:31 PM
doopstr's Avatar
The host at work makes an outbound call on port 80 to gotomypc servers. So does the client.
Old Aug 22, 2006 | 02:32 PM
doopstr's Avatar
Q Which port numbers does GoToMyPC Corporate use, and can I change the port numbers?
A GoToMyPC Corporate uses one of the several ports that are typically left open so that users can access the Internet (port 80 or 443). This means that you generally do not need to configure firewalls to allow GoToMyPC Corporate connections. If your organization uses a proxy that restricts traffic through port 80 or 443, you may open port 8200 for GoToMyPC Corporate connections. Citrix Online provides a Connectivity Test Wizard that you may use to optimize your GoToMyPC Corporate connection ports.
Whiskers's Avatar
Go Giants
Depends if they travel over commonly used ports such as 80....
Old Aug 22, 2006 | 02:34 PM
Whiskers's Avatar
Go Giants
That's how they own Secuity admins....Can't very well block 80.....But if it's not a direct link to the home PC (IE, to a central network), then you can.
Old Aug 22, 2006 | 02:36 PM
RyeCL's Avatar
I always use Remote Desktop to access my PC
Old Aug 22, 2006 | 02:39 PM
doopstr's Avatar
The entire GotomyPCFAQ is here if you are interested.
Attempting to block this is like attempting to block AIM.
Old Aug 22, 2006 | 02:46 PM
GBockers's Avatar
Firstly, the original poster wants to access their WORK pc remotely. You are right port 80 is not blocked for OUTGOING traffic. So in order for this "solution" his enterprise would have to be running GTMPC Server which is not an enterprise level solution IMHO. Otherwise your comments are spot on.
G
Old Aug 22, 2006 | 02:51 PM
fsttyms1's Avatar
I am the admin.
the computers are XP
Old Aug 22, 2006 | 02:55 PM
Bdog's Avatar
Not Registered
Our company uses GoToMyPC and our firewall is pretty stout, works really good so far.
Old Aug 22, 2006 | 03:03 PM
doopstr's Avatar
Originally Posted by fsttyms1
I am the admin.
Ok so if your router can handle VPN I would go with a VPN/Remote Desktop solution because its faster than gotomypc.
If you don't have VPN and if you are comfortable with your firewall you can open up a port and allow VNC or Remote Desktop to your machine. This is the least secure solution and I don't really recommend it. I use VNC for my home connection because there isn't really anything worth stealing on my home machine except pron.
Otherwise use gotomypc or logmein. The only problem I've seen with gotomypc is that is can be slow at times. I have friends that use logmein and like it.
Old Aug 22, 2006 | 03:27 PM
fsttyms1's Avatar
So with VNC/VPN no one has to be around to log in or accept at teh machine im trying to access?
Old Aug 22, 2006 | 03:39 PM
doopstr's Avatar
With all of the options you just leave the machine turned on and authenticate to it with a password. Make sure you have a strong password.
Old Aug 22, 2006 | 03:40 PM
fla-tls's Avatar
On the way!
No - you assign a password that is needed to connect. Make sure your PC doesn't go into sleep or hibernate mode.
Old Aug 22, 2006 | 03:41 PM
Whiskers's Avatar
Go Giants
Wait..You are the admin????
Old Aug 22, 2006 | 03:42 PM
fsttyms1's Avatar
thanks for the info. Im going to try out logmein and see how that works. Hopefully something like this works, cause i dont want to pay over 1000 a year for teh software for my laptop when i can use something like this from most places..
Old Aug 22, 2006 | 04:31 PM
mantis23's Avatar
Moderator Alumnus
netmeeting worked fine for me.
Old Aug 22, 2006 | 04:43 PM
bz268's Avatar
Because Of You
Doesn't XP already come with Remote Desktop? Why do you need to "buy" anything?
Old Aug 22, 2006 | 05:09 PM
fsttyms1's Avatar
well sorta. If thats what you want to call me. My dad owns the company, and i take care of the computer end of it (not much to really take care of) just like to improve buisness and be able to work on the road and not have to fork out tons of money on additional software that we would have to purchase to work on the road
Old Aug 22, 2006 | 06:30 PM
leftride's Avatar
i want to ride my bicycle
just look into Remote Desktop it will do everything you need for free.
Old Aug 22, 2006 | 07:34 PM
fsttyms1's Avatar
Would if i knew how to set it up
Old Aug 23, 2006 | 07:29 AM
leftride's Avatar
http://www.microsoft.com/windowsxp/u...bleremote.mspx
http://www.microsoft.com/windowsxp/u...p_03may16.mspx
http://www.microsoft.com/windowsxp/u...ity/rdfaq.mspx
eastcoastguy
Oct 29, 2015 03:00 PM
steve
Sep 30, 2015 09:23 PM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
lowgrowl
Sep 26, 2015 05:18 PM
