Remote Desktop Protocol
Old Jul 17, 2010 | 06:25 PM
stogie1020's Avatar
Needs more Lemon Pledge
Anyone have any suggestions for troubleshooting why a RDP connection sometimes keeps its connection for a few hours, and more regularly loses connection every five to ten minutes (not regular interval)? Sometimes the connection only last for a minute or less.
Connection is over VPN which does not indicate any problems in its logs, and in order to reconnect the RDP session, the VPN must be disconnected and then re-enabled.
VERY frustrating...
Any thoughts?
More than one user with different internet connections have similar complaints.
VPN: Sonicwall
RDP: Server 2003
Clients: XP, Vista, W7
Old Jul 17, 2010 | 06:34 PM
Beelzebub's Avatar
I have had this problem with my office connection and the juniper client.
We had a problem with software that is on the client machine, namely the Bonjour service.
Old Jul 17, 2010 | 06:49 PM
stogie1020's Avatar
Interesting... I have that running...
Old Jul 17, 2010 | 06:54 PM
stogie1020's Avatar
Just terminated that process. Let's see how it goes...
Old Jul 17, 2010 | 11:09 PM
#1 STUNNA's Avatar
Sanest Florida Man
bonjour is used to share iTunes libraries across the LAN. Why would you have iTunes installed at work?
Old Jul 17, 2010 | 11:13 PM
subinf's Avatar
One on the right for me
My firms VPN sucks balls on my computer.
I just needed to say that
Old Jul 18, 2010 | 02:30 AM
stogie1020's Avatar
It's on the home computer that I use to RDP into the work computer.
Also, I have whatever I want on the work computer.
Old Jul 18, 2010 | 06:24 AM
Beelzebub's Avatar
Also we have work provided Ipads, therefore Itunes.
Old Jul 20, 2010 | 01:22 AM
stogie1020's Avatar
Bonjour disabled and problem persists.
Problem = I connect to VPN, then RDP to my work desktop. I then lose the RDP connection and when I go to reconnect, the computer (work desktop) cannot be found.
HOWEVER... If I disconnect from the VPN and then try to reconnect the RDP session, the computer is found and connected to right away.
Any ideas?
Old Jul 20, 2010 | 01:27 AM
#1 STUNNA's Avatar
Sanest Florida Man
port forwarding? At work we open a random port for example 50000 on the public side then route it to 3389 on the private side and to your computers IP. you have different random public ports for each PC but the same 3389 but of course different IP on the private side. So
port 50000 = PC A
port 51000 = PC B
port 52000 = PC C
etc.
Old Jul 20, 2010 | 01:31 AM
stogie1020's Avatar
Based on the need to reconnect the VPN in order to find the RDP machine, I am thinking the problem lies with the VPN...
Old Jul 20, 2010 | 05:58 AM
Beelzebub's Avatar
What home router are you using, and is it at the latest firmware.
Old Jul 20, 2010 | 08:03 AM
rza49311's Avatar
Are you using hostname to connect or IP?
Old Jul 20, 2010 | 08:09 AM
doopstr's Avatar
How old is this Sonicwall? If your client software is old, upgrade it.
If you can no longer get software updates for it ditch it and go Cisco. I ran into similar issues with a SOHO3 3-4 years ago. As new OSes came out the client software just wasn't up to the task at hand.
If the Sonicwall has intrusion detection try turning it off. I'm sure you have done this, but try rebooting the Sonicwall.
Old Jul 20, 2010 | 11:13 AM
stogie1020's Avatar
Linksys by Cisco WRT320N flashed with DD-WRT (Bld12982M).
Old Jul 20, 2010 | 11:14 AM
stogie1020's Avatar
Hostname.
Old Jul 20, 2010 | 11:15 AM
stogie1020's Avatar
Will have my associate reboot the SonicWall. It does have IDS, but I would rather forget the VPN than turn that off.
Old Jul 20, 2010 | 11:17 AM
rza49311's Avatar
Hostname.
next time the connection drops, try to reconnect with the IP just for giggles.
Old Jul 20, 2010 | 11:23 AM
stogie1020's Avatar
OK, will give that a shot.
Old Jul 20, 2010 | 11:32 AM
Beelzebub's Avatar
up the firmware on the router. you should be running v24 sp2.
that is what ended up totally fixing the problem for me. even though I kept saying to the tech that that couldn't possibly be the problem.
Old Jul 20, 2010 | 11:52 AM
Belzebutt's Avatar
I'm the Firestarter
Do you know for sure it's just RDP that's the problem? Do a continuous ping to the PC and see if everything drops or just the RDP session.
Old Jul 20, 2010 | 02:15 PM
stogie1020's Avatar
Will give it a shot.
Old Jul 20, 2010 | 04:08 PM
imasquirrel's Avatar
Anyone seen my nuts?
I've had this issue before, and resolved it by changing the MTU size
http://www.howtonetworking.com/vpn/mtu1.htm
Old Jul 20, 2010 | 04:26 PM
stogie1020's Avatar
^EXACTLY what my admin guy just suggested!
Old Jul 20, 2010 | 04:36 PM
MWalsh9152's Avatar
all work and no play
I have an easy fix Geoffy......stop trying to work from home in your banana hammock you lazy bitch!!!
Old Jul 20, 2010 | 07:28 PM
stogie1020's Avatar
What's wrong with my banana hammock? I wear it to work on the outside...
Old Jul 20, 2010 | 09:52 PM
MWalsh9152's Avatar
Old Jul 28, 2010 | 01:08 PM
stogie1020's Avatar
So this seems to be working, although I also am connecting via IP not hostname and also updated the DDWRT firmware.
Old Jul 28, 2010 | 01:30 PM
srika's Avatar
Moderator Alumnus
Any ideas?
guessing there's probably a reason but I have to ask - why do you need VPN if you are able to connect RDP without it?
and, have you considered TeamViewer? That's what I use now. I use to do RDP back until a couple of years ago when I finally got fed up with its frequent tendency to not work. TeamViewer is great, connects 99% of the time. Once in a while there is a hiccup of sorts but overall fantastic.
Old Jul 28, 2010 | 03:46 PM
stogie1020's Avatar
Srika, I need the VPN to be able to RDP. Might not have been clear on that. WHat I MEANT in the "however" section, was that I needed to disconnect and then reconnect the VPN to re-enable the RDP. My bad.
I will check out TeamViewer, thanks!
Old Jul 28, 2010 | 05:53 PM
srika's Avatar
Moderator Alumnus
oh ok. well, yeah, not the biggest fan of VPN. if this is for your work I don't know whether TeamViewer will be a good thing. It's designed more for remote support purposes where you *need* to connect - that is, getting connected is more important than security concerns. but maybe something to try.
Old Oct 4, 2010 | 04:14 PM
stogie1020's Avatar
Changed MTU size, connecting via IP not hostname, still getting dumped. Other users are having the same problem.
REALLY frustrating.
Old Oct 4, 2010 | 04:38 PM
litesout's Avatar
Oliver!!!
I wonder if its dumping your connection when someone else establishes their connection to the VPN. Basically, you log in, surf your porn, all is well. Someone else logs in, RDP drops you, they surf their porn, all is well. Until you log back in, RDP drops them, etc. Not a solution, but a possible insight into where the problem might lie.
Old Oct 4, 2010 | 04:40 PM
stogie1020's Avatar
It may be, but I get dumped at times I am fairly certain no one else is connected. Other people who log on odd hours have the same results...
Old Oct 4, 2010 | 04:51 PM
Whiskers's Avatar
Go Giants
REALLY frustrating.
Either the VPN connection is shady or there is something that runs and disconnects it on the host (like a virus scan)
Old Oct 4, 2010 | 07:52 PM
#1 STUNNA's Avatar
Sanest Florida Man
Check and see how many simultaneous VPN connections your setup can handle.
Old Oct 4, 2010 | 08:00 PM
whynot's Avatar
X spots the mark
Consider upgrading to Cisco or look into Citrix?
Old Oct 4, 2010 | 08:11 PM
Jonesi's Avatar
fire Whisklars! get new IT guy.....
Old Oct 4, 2010 | 08:39 PM
Whiskers's Avatar
Go Giants
Old Oct 4, 2010 | 08:51 PM
#1 STUNNA's Avatar
Sanest Florida Man
Is it a set interval, like you always get disconnected after 15 minutes. Or is it different everytime like one time it's 4 minutes and the next time it's 45 minutes?
