Random Technical Talk
Old 08-15-2016, 12:58 PM
  #801
Doom878's Avatar
Received 1,308 Likes on 961 Posts
Best place/site to get cat6?
Also where do you guys get printer ink refills?
Old 08-15-2016, 01:05 PM
  #802
Received 8,707 Likes on 6,715 Posts
monoprice.com is my go-to for those sorts of bulk cable!
Old 08-15-2016, 01:18 PM
  #803
Sanest Florida Man
#1 STUNNA's Avatar
Received 10,424 Likes on 6,316 Posts
true
Old 08-15-2016, 03:21 PM
  #804
Doom878's Avatar
Oh good. I've ordered tons of smaller cables from them.
Old 08-22-2016, 04:03 PM
  #805
Sanest Florida Man
#1 STUNNA's Avatar
Ok I'm repurposing some drives that have BitLocker on them. I'm currently unlocking the drive deleting all the data while BitLocker is still enabled and then disabling BitLocker. My question is that if the data was deleted while BitLocker was enabled then it should still look like jibberish even though I disabled BitLocker on the drive right after deleting the data, right?
They're not using the drives anymore so I want to get the data off of there and remove BitLocker and then they company can do whatever they want with the drives since they're basically unencrypted empty external drives now.
I'd rather not go through the process of doing a secure erase or low level format if I don't need to
Old 08-22-2016, 04:45 PM
  #806
Needs more Lemon Pledge
stogie1020's Avatar
Received 2,000 Likes on 1,173 Posts
stunna, use one as a test example and after you delete the bitlocker encrytped files, open the drive in Autopsy and look for a known file form prior to the delete. Heck, you could even MAKE a known file with specific text you could then look for.
My understanding, though, is that if you simply delete the encrypted data, there is no recoverable data after the simple delete. I would be interested to know if you find otherwise.
I would test it out for you ,but I dont think I have BT drive laying around...
Old 08-22-2016, 04:51 PM
  #807
Sanest Florida Man
#1 STUNNA's Avatar
I could just use recuva right? I don't have that fancy expensive stuff you got
Old 08-22-2016, 05:13 PM
  #808
Sanest Florida Man
#1 STUNNA's Avatar
I ran Recuva and it found about 90000 files, it supposedly restored a file but it was corrupt. I can't see the contents of files but I can see file names, file paths, and file formats.
So what I think happened is that I deleted all the data but hadn't deleted the MFT so that was unencrypted when I disabled bitlocker. So to clear out the MFT before disabling BitLocker I can just do a reformat and then disable BL or would you recommend a low level format?
Old 08-22-2016, 08:09 PM
  #809
stogie1020's Avatar
Autopsy is free, thats why I mentioned it.
http://www.sleuthkit.org/autopsy/
Old 08-22-2016, 08:11 PM
  #810
stogie1020's Avatar
Why not just throw a Linux boot disk into each computer and let it run a wipe overnight of the physical drive? Seems much easier AND if this is for a business, I wouldn't mess around with "trying this or that"... If you are getting paid for it, do it right. Hell, even if you aren't getting paid...
Old 08-22-2016, 11:26 PM
  #811
Sanest Florida Man
#1 STUNNA's Avatar
Autopsy
It sounds expensive...
Old 08-23-2016, 09:15 AM
  #812
Sanest Florida Man
#1 STUNNA's Avatar
Once I re-enabled encryption then reformatted the drive recuva couldn't see shit on a quick scan. I'm doing a scan in autopsy, I'll check on it later
Old 08-23-2016, 10:59 AM
  #813
stogie1020's Avatar
Autopsy is nice (and free) to be able to simply look at unallocated space, MFT, etc...
You can quickly see if the MFT is in plain text but docs are not, etc.
Don't be fooled, though, by the docX/xlsX formats whereby the compound document does not appear as plain text (the older doc/xls formats had plainly readable text at the hex level). If you are truly trying to see if the encryption/formatting is obfuscating the text after a format, I would create a new plain text doc with know-text on the drive, perform the encryption/de-cryption, perform the format, and then re-look for the known text at the hex level.
Old 09-06-2016, 01:36 AM
  #814
Not sure if any of you have seen this but ...
https://serverfault.com/questions/29...ation-he-wants
Just tons and tons of ...
Old 09-06-2016, 06:13 AM
  #815
Go Giants
Whiskers's Avatar
Received 1,234 Likes on 823 Posts
idiot
Old 09-06-2016, 06:22 AM
  #816
Originally Posted by Whiskers
idiot
Wait, so you don't just keep all your user passwords on post it notes...?
Old 09-06-2016, 10:40 AM
  #817
Go Giants
Whiskers's Avatar
maybe..
Old 09-06-2016, 02:29 PM
  #818
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,464 Likes on 3,058 Posts
Old 09-29-2016, 09:06 PM
  #819
Sanest Florida Man
#1 STUNNA's Avatar
2.5Gbps over Cat 5e and 5Gbps over Cat 6
Here comes 5Gbps networking over standard cables | Ars Technica
Old 10-04-2016, 10:07 AM
  #820
Sanest Florida Man
#1 STUNNA's Avatar
Level 3
Old 10-21-2016, 12:52 PM
  #821
Sanest Florida Man
#1 STUNNA's Avatar
FYI DynDNS is being DDOSed so a bunch of shit isn't working.
Twitter is down and a bunch of other shit
Old 10-21-2016, 05:09 PM
  #822
doopstr's Avatar
Received 2,161 Likes on 1,187 Posts
Old 10-25-2016, 10:37 PM
  #823
mcflyguy24's Avatar
Either the auditor is really clever or really stupid. Those could be bait questions that if answered will instantly fail them on the audit. I don't see how they can get at the passwords, everything should be salted and hashed nothing in plain text, meaning that on the off chance it is then they fail the audit. He could also be a moron though..
Old 10-27-2016, 11:58 AM
  #824
Sanest Florida Man
#1 STUNNA's Avatar
86 Vine
Old 01-12-2017, 01:37 PM
  #825
stogie1020's Avatar
Trying to do something that may not be possible...
I own a APC BackUPS BG1500 UPS that is connected via USB to a desktop computer (computer1). Computer1 is running Powerchute Personal and will shutdown gracefully when the battery in the UPS gets low. I have a second computer (computer2) plugged into the battery backup outlet on the UPS along with computer1. Computer2 does not shutdown gracefully as it has neither PowerChute running nor any connection to the UPS.
I am trying to have both machines shutdown gracefully when the UPS gets to the point of shutting equipment down.
I have tried:
(a) finding a way within PowerChute Peronsal to script the shutdown process to include a netowrk command. DOES NOT EXIST
(b) installing PowerChute Business on both machines, but (1) I think they removed the ability to script the shutdown process, and (2) I cannot get computer2 to see the Powerchute server running on computer1.
Any ideas other than buying a second UPS for computer2?
Old 01-12-2017, 06:23 PM
  #826
I am #76,361,211,935
underdog's Avatar
I have tried:
I wonder if you could have PowerChute running on both computers and try running the signalling (serial/USB) cable
from the UPS to a USB hub/splitter and then run a separate USB cable from the splitter to each computer?
It might take a bit of doing to get the plumbing right (female/female USB dongles) but may be worth trying?
Old 01-13-2017, 10:45 AM
  #827
Sanest Florida Man
#1 STUNNA's Avatar
The 2nd PC doesn't have a way of knowing it's on battery power. Can you make script that constantly pings PC ! and after it drops X number of packets then it shutdowns PC 2. That sounds like a bad workaround, that could have lots of false positives. But I think you should just buy a 2nd APC, we usually do one per PC anyways.
Old 01-13-2017, 11:32 AM
  #828
stogie1020's Avatar
Yeah, that's where I am headed but I don't want the space issues of a UPS per machine...
I need to be in the SmartUPS series for multi-machine shutdown.
Maybe I wil just fork over the cash for a APC APC Smart-UPS C 1500VA LCD 120V-Newegg.com
Old 01-13-2017, 12:02 PM
  #829
I think that'd be a smart decision
YeuEmMaiMai (01-28-2017)
Old 01-13-2017, 12:07 PM
  #830
stogie1020's Avatar
I just need to figure out how to make it smartly shutdown two PCs and a Synology NAS....
Old 01-13-2017, 12:10 PM
  #831
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
I've had good service from the CyberPower 1500VA UPS'. I've been running 3 for about 4 years and I'm just now getting a battery warning on one of them. Got them all on sale for ~ $125
stogie1020 (01-13-2017)
Old 01-13-2017, 12:28 PM
  #832
nfnsquared's Avatar
I just installed one of these at a client location
http://www.apc.com/shop/us/en/produc.../P-SMX2000LVNC
And for good measure, they added one of these:
http://www.apc.com/shop/eg/en/produc...wer/P-SMX120BP
Got my weight training done while working
Old 01-13-2017, 12:36 PM
  #833
stogie1020's Avatar
Dayuuum.
Do you do any of the software setup for the connected machines?
My confusion arises from how to get the UPS to shut down more than one machine if there is only a USB or Serial connection available on the UPS. Does the directly connected device send a signal to other connected devices running the UPS software (via network) to shutdown and then shut itself down when the battery reaches a low level?
Also, not sure how to get a Synology 8 bay device to shutdown gracefully withOUT the APC (or Cyberpower) software running on it. Would I connect the serial (rj45) to the controlling workstation and then the USB control cable to the Synology?
Old 01-13-2017, 12:47 PM
  #834
How to have single UPS shutdown multiple servers? | Smart-UPS & Symmetra LX / RM
This may help
Old 01-13-2017, 01:03 PM
  #835
stogie1020's Avatar
Thanks Thoiboi, that looks to be the solution for all the computers. I wonder how to ALSO make it work on the Synology NAS...
Old 01-13-2017, 01:07 PM
  #836
Hmm....
This post might be the answer to all your woes..
https://forum.synology.com/enu/viewt...=79201#p297134
Typically, a UPS will have several outlets that JUST have surge protection, and several outlets that will remain powered, even in a blackout, until the battery in the UPS runs out.
You plug the Synology into one of the battery-backed-up outlets.
What you want is for the Synology, in the event of a blackout, to gracefully power itself down, before the backup battery in the UPS runs out. How does the Synology know that there's been a blackout? A compatible UPS will tell the Synology, via a USB cable connecting the UPS to the Synology.
So, the sequence of events is: Power goes out; Synology remains powered by UPS battery; UPS tells Synology that the power has gone out; Synology shuts itself down without an ugly crash.
As an added benefit, if you connect ONE Synology device to the UPS, that Synology device can then tell all your other Synology devices when there's been a blackout, and they can ALL shut down gracefully, provided they're connected to the UPS, or to another UPS with battery backup.
As yet another added benefit: You can run free software on your PCs and Macs that will ALSO be alerted by the Synology that the power has gone out, and which will shut the PCs and Macs down gracefully. (Again, provided they are connected to a battery backup, or, alternatively, if they are laptops, which of course have a built in battery.) The PC software is called WinNUT.
Old 01-13-2017, 01:28 PM
  #837
stogie1020's Avatar
Holy shit, that looks cool! I never would have thought to use the NAS as the controller for the PCs!
Thank you thank you thank you.
Old 01-13-2017, 01:36 PM
  #838
So long as the UPS is listed as compatible with the NAS, you should have no problems!
Sometimes you just gotta think outside of the box
Old 01-13-2017, 01:47 PM
  #839
stogie1020's Avatar
That is a whole different issue... Synology has not re-tested newer UPS devices for at least a few years, it would seem...
Old 01-13-2017, 02:00 PM
  #840
Looks like that SMC1500 you posted is listed as compatible though!
Quick Reply: Random Technical Talk
